Ticking noise from clutch? - YouTube video inside... - BMW M5 Forum and M6 Forums
post #1 of 9 Old 3rd June 2010, 11:45 PM Thread Starter
deejaywasp
deejaywasp's Avatar
Lightbulb Ticking noise from clutch? - YouTube video inside...
Hi guys!
I have a ticking noise while resting foot on the clutch pedal.
As soon as a start pushing the pedal down further the ticking stops.
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Any ideas?
deejaywasp is offline
post #2 of 9 Old 4th June 2010, 12:34 AM
nightkrawler
nightkrawler's Avatar
nightkrawler is offline
post #3 of 9 Old 4th June 2010, 02:00 AM
Verruckt
Verruckt's Avatar
Verruckt is offline
post #4 of 9 Old 4th June 2010, 03:05 AM
blackxs
blackxs's Avatar
blackxs is offline
post #5 of 9 Old 4th June 2010, 04:29 AM
Jabberwocky
ive noticed that on mine too, but i think its when the car has just been started up. i believe mine happens when the clutch is all the way pushed to the floor.
btw, how much pressure does the clutch require? do you guys push the clutch all the way down?
Jabberwocky is offline
post #6 of 9 Old 4th June 2010, 06:06 AM
Cereal
my car does this also, but is a 540
have been told it is a sign of the throwout bearing... thats what my buddy/mechanic says
mine pulsates the pedal slightly if i barely press on the pedal and the noise goes away if clutch pedal is more than 1/3 way down
my noise has gotten slightly louder recently and can notice it while driving around town now... before it was only noticeable sitting in food drive thrus and at red lights... very annoying
Cereal is offline
post #7 of 9 Old 4th June 2010, 12:21 PM
nightkrawler
every manual tranny bmw i've ever driven has this pulsation through the clutch pedal. it has to be runout of the pressure plate and or the whole assembly. this is the same principal as brake pedal pulsation, the runout of the rotor pushes the piston which moves the fluid through the system and is felt at the pedal.
the noise however is definitely not normal, i'd get under there and for the hell of it check the slave cyl. make sure its bolted tight to the bellhousing.
post #8 of 9 Old 4th June 2010, 12:27 PM
vantaam5
What nightkrawler said!
If the foot is off the pedal and it makes noise that stops once you press the pedal,it is the throw out bearing...
vantaam5 is offline
post #9 of 9 Old 4th June 2010, 07:48 PM Thread Starter
deejaywasp
deejaywasp's Avatar
To clarify things.
I never rest my foot on the clutch
I don't feel any pulsating in the pedal.
The sound is not present when clutch is fully engaged or disengaged.
You can only hear it while putting a slight pressure on the pedal while in neutral.
As soon the the pedal comes to that point where the clutch starts engaging the sound disappears.
Ticking/Creak Noise During Right Turns captain_anonymous_2003 E39 M5 and E52 Z8 Discussion 11 26th June 2014 11:51 AM
What is this rattling noise? (Working Video inside....) Mfreakin5 E39 M5 and E52 Z8 Discussion 8 25th March 2010 02:23 AM
Ticking noise from the engine compartment SACM5 E39 M5 and E52 Z8 Discussion 8 24th February 2007 02:23 AM
Ticking noise from the shifter area MPULSV6 E60 M5 and E61 M5 Touring Discussion 8 28th April 2006 08:48 PM
What's that ticking noise? Angel E39 M5 and E52 Z8 Discussion 15 26th June 2002 08:47 PM
