Oil capacity on E39 m5 - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 47 Old 28th May 2010, 01:46 PM Thread Starter
richardspeed
richardspeed is offline
post #2 of 47 Old 28th May 2010, 03:01 PM
reds2
reds2's Avatar
reds2 is offline
The Following User Says Thank You to reds2 For This Useful Post:
jclyman (28th May 2010)
post #3 of 47 Old 28th May 2010, 05:07 PM
vantaam5
vantaam5 is offline
post #4 of 47 Old 28th May 2010, 06:16 PM
Quinten
Quinten's Avatar
Quinten is offline
post #5 of 47 Old 28th May 2010, 06:25 PM
bono
bono's Avatar
Often they give you a bit left over so that after 10 miles when it complains how its burnt a litre of oil you can top it up again heh
Matt
E61 M5
E39 M5
MV F4 1000R
bono is offline
post #6 of 47 Old 28th May 2010, 07:49 PM
jclyman
In Memoriam
jclyman's Avatar
In my experience (7 years), the dealers almost ALWAYS overfill by one quart. Once, I even pointed out I only wanted 7 quarts in it, and they still put 8 in.
- Daniel Boorstin
jclyman is offline
post #7 of 47 Old 29th May 2010, 12:37 AM Thread Starter
richardspeed
I will still have to buy two 4 litre tubs, the spare 1.5 can be used at a later date.
post #8 of 47 Old 29th May 2010, 03:02 AM
DLite
DLite's Avatar
DLite is offline
post #9 of 47 Old 29th May 2010, 04:43 AM
TMcNasty
TMcNasty's Avatar
Do you want to know what amount you need to do an oil/filter change or the TOTAL capacity of the oiling system? As a man who left his lower oil pan off for a week I can assure you that the system holds more than you think!
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline
post #10 of 47 Old 29th May 2010, 06:00 AM
kosmo
kosmo's Avatar
i put some oil in the filter (about 1/2 qt) then 6 then check then top off.
2002 M5 Lemans Blue
kosmo is offline
Fuel Tank Capacity M5 London E39 M5 and E52 Z8 Discussion 16 30th October 2009 03:32 AM
Towing capacity of M5 daytonaM5 E34 M5 Discussion 10 15th October 2008 01:48 PM
Question on engine oil capacity.. alan6888hk E60 M5 and E61 M5 Touring Discussion 6 12th May 2008 09:21 PM
Oil Capacity Mark E39 M5 and E52 Z8 Discussion 6 15th December 2001 07:03 AM
Fuel Capacity BAHNBOMB E39 M5 and E52 Z8 Discussion 5 29th September 2001 12:46 PM
