Old 25th March 2002, 03:02   #1
steve adams
steve adams's Avatar
Garage: '02 Porsche 996 C4S
slight oil overfill
recent oil change by dealer put in the 15w-30 ... they overfilled according to dipstick by about maybe 1/4 qt ... worth taking back in for adjustment to oil level?
thanks ..
steve adams is offline
Old 25th March 2002, 03:06   #2
atomic80
M5 Extraordinare!
atomic80's Avatar
Garage: 2007 Cobalt Blue Porsche 997TT
Before I knew how to read the oil dipstick properly I would unknowingly overfill my oil. When one of the service technicians checked the oil, he showed me how to check it properly. He even was nice enough to drain the excess oil quoting that it was not good for the engine to have too much oil. It might be worth a trip to the dealership.
Jason
'05 Range Rover w/mods
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 25th March 2002, 03:12   #3
greg
greg's Avatar
Garage: 2000 Anthracite
quarter of a quart shouldn't be any problem.
greg is offline
Old 25th March 2002, 03:18   #4
atomic80
M5 Extraordinare!
atomic80's Avatar
I should have noted that I had about 1 quart too much oil at the time!
Jason
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
atomic80 is offline
Old 25th March 2002, 05:04   #5
Jim Dolan
Jim Dolan's Avatar
Garage: 2006 M5 Silver Grey Metallic
How to read your dip stick is in the owners manual. It is important to not overfill but a 1/4 of a quart shouldn't be a problem. Too much oil can cause pressure on seals and gaskets and force oil into the cylinders.
Jim
2006 Silver Gray Metallic over Black
The "Wolf in Sheeps Clothing" is back in the USA again
1971 2002 Colorado(Light Orange)
1976 2002 Inka(Red orange, a classic)
1982 528e Blue metallic
1984 533i Burgandy
1987 325i Alpine white
1988 535is Salmon silver
1993 525iT Calypso red
1999 528iT Titanium silver
2000 M5 Titanium silver
2006 M5 Silvergray
Jim Dolan is offline
Old 25th March 2002, 05:12   #6
Noka
Noka's Avatar
Garage: '03 E39-M5 Sterling Gray/Black
Owner's manual says let idle for "at least 15-sec" and then after "approx. 1-min" pull dipstick and check. What happens if you wait 1-hr or 1-day before you pull dispstick? I tried it a couple of times and didn't really notice a difference as I recall. Would it perhaps read too high if you wait longer?
Rdgs,
Norm
Noka is offline
Old 25th March 2002, 05:35   #7
TCM
TCM's Avatar
Noka:
I beleive the only reason they say to let it idle for a couple of seconds is to get the oil circulating to get an accurate measure. If you check it when the car is cold all the oil has drained back down to the engine base and you will not get a correct measurement. I do not think driving it around for a long time would cause any difference in oil level from the 15 second idle.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 25th March 2002, 06:09   #8
Bart Carter
Bart Carter's Avatar
Garage: 2002 M5 Bluewater/Caramel
The purpose of the procedure is to measure the oil when warm and when it has time to drain down properly.
I would guess that BMW felt having a procedure to check the oil when warm was better than checking when cold.
This is best accomplished for me when getting gas. I have the timing down so close when I go to the pump that I don't even bother counting seconds anymore.
-Bart
2002 Bluewater/caramel
Any other car is a compromise
Bart Carter is offline
Old 25th March 2002, 06:52   #9
Noka
Noka's Avatar
Thanks for the replies. Not sure I understand the concept behind it ... but will comply, of course.
Rgds,
Norm
Noka is offline
Old 25th March 2002, 08:55   #10
steve adams
thanks for the advice .... it looks like about a 1/4 qt over .... i need to stop by the dealer on monday anyway ...
hendrick bmw in charlotte has done a pretty food job of service on the M5 ... they had to replace the brake rotors and disks twice and the car has only 6K mi. on it ... I have not driven it excessively .. no track time ... seems the first set of brakes had the disk pads misaligned from the factory .. they are not sure what caused the problem the 2nd time ... but have been very helpful in repair under warranty ..
the clutch is starting to slip a bit... they are recommending waiting till the slipping really becomes obvious ... probably not wanting to raise a flag with BMW NA on warranty repairs on this car ... they'seem like good folks ...
partial- quart oil overfill... not bad? Brother Methias E39 M5 and E52 Z8 Discussion 4 7th November 2003 21:43
Oil Analysis...Recommended more frequent oil changes drallen E39 M5 and E52 Z8 Discussion 40 8th September 2003 22:10
Checking oil, back to basics? kwalls E39 M5 and E52 Z8 Discussion 25 29th April 2003 02:04
Dealer oil overfill Rcl4668 E39 M5 and E52 Z8 Discussion 3 8th August 2002 16:03
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.16367 seconds with 11 queries
