"No Drill" License Plate Bracket - Which to choose? - BMW M5 Forum and M6 Forums
Old 20th May 2010, 21:06   #1
Lordrandall
Lordrandall's Avatar
Garage: 2002 M5 Titanium Silver metallic
Well, I finally passed a bored bike cop this morning on my way to work, so it's time to contribute to the city coffers and take care of my fix-it ticket.
I'm loath to drill into my bumper cover, so I went looking for some no-drill options.
These look like my 3 best choices:
Keep the center look - Skene Design License Plate Mount
Offset w/ Aluminum post - Rho-plate
Offset w/ steel post - http://www.wstoshop.com/servlet/Detail?category=BMW%3A5+Series%3AE39+5er+%2896~03% 29%3AExterior&no=1358&searchpath=32423
Offset (Thanks wentouch!) - BMW Parts and BMW Accessories | Bavarian Autosport - Search required, no direct link.
Has anyone tried one or more of the above? Any feedback regarding quality?
They all cost about the same, so I'm not worried about that part.
TIA!
Last edited by Lordrandall; 20th May 2010 at 21:41. Reason: Added additional version.
Lordrandall is offline   Reply With Quote
The Following User Says Thank You to Lordrandall For This Useful Post:
M5 Authority (17th May 2011)
Old 20th May 2010, 21:11   #2
Stack
Stack's Avatar
Garage: 2003 M5 - Alpine White
There is also the Go Mini Go
Euro Dyne || GoMiniGo :: The 'NO HOLES' License Plate Bracket - Bimmerforums - The Ultimate BMW Forum
2003 Alpine White M5 - 371 WHP & 355 TQ
-Euro Hellas
-Blacked out Roundels
-Magnaflow 14816 Exhaust
-Angel IBrights
-Hoen Color Match Fog Lights
-Blacked out Kidney Grills
-Vosteiner CF Rear Diffuser
-StopTech ST-40 BBK on all fours.
-Dinan Front Strut Brace
-Hamann Style Front Lip (Body Color on top CF exposed on bottom)
-JailBreak Tune (91 Octane)
-19" BBS LMs wrapped in PS2's (15mm Spacer/Front 10mm Spacer/Rear)
- Dinan Rear Sway Bar
- Ground Control Street Coilovers
- Dinan Cold Air Intake
Panerai Central
Stack is online now   Reply With Quote
Old 20th May 2010, 21:16   #3
Lordrandall
Thanks, that's the one they sell at WSTOShop.
Old 20th May 2010, 21:35   #4
SidekickChuck
SidekickChuck's Avatar
Garage: 2001 M5
Sales Feedback: (4)
Are you just trying to get the fix it ticket cleared then remove it?
I have received many front license tickets and I just take a small piece of double sided foam tape and press my fingers all over it to get my oils on it so it isnt too tacky. Then around the corner from the CHP office, press it onto the front bumper cover and get it signed off. Then remove it once leaving the CHP lot.
SidekickChuck is online now   Reply With Quote
Old 20th May 2010, 21:35   #5
wentouch
Garage: 03 E39 M5 JB/B/Al
BavAuto offers one for $50 which appears to have a better design (material quality unknown): BMW Parts and BMW Accessories | Bavarian Autosport. Search: License Plate Locator (doesn't link directly).
Choosing between the center mount (fixed) versus hook mount depends on whether your mounting basis is either temporary or permanent. If you're looking for just temporary to get correction cleared, wouldn't hurt to go the tow mount route first and see if it clears.
Fortunately, OC isn't cracking down as hard as LA on front plates yet and I've been lucky in LA. I received only a warning in LA; knock on wood, but if you travel via flying, might as well stick to the center plate, since a missing front plate is almost always ticketed at the airport.
wentouch is offline   Reply With Quote
The Following User Says Thank You to wentouch For This Useful Post:
Lordrandall (20th May 2010)
Old 20th May 2010, 21:44   #6
Lordrandall
Thanks, I'll add that one to my original post.
I haven't decided if I'm going to keep it on or not. I guess the smart thing to do would be to leave it in place so I don't get another ticket, but front plates are so tacky. I drove my last car for 4 years with no plate and never got a ticket.
Old 20th May 2010, 21:50   #7
SidekickChuck
Garage: 2001 M5
Sales Feedback: (4)
Could just be Burbank PD needing to step up their quota for the month....
I live close, in La Crescenta and the only times in the past were in other vehicles (not the M5) and it was always for something else like tint or exhaust and they just threw in front license for good measure =]
I will always use my method as a fix it ticket is quick and easy, but still a hassle to deal with. But if you are looking, or thinking of keeping your plate on for a fixed amount of time over a few minutes to write off the ticket, the above options are good ones. Anything beats drilling into the cover.
Old 20th May 2010, 21:56   #8
wentouch
There's also the infamous Home Depot route, or Choose-Your-Own-Design, as SideKickChuck mentions.
If I had time, was a machinist or cared, I would have designed a bracket that mounts under the center bumper in front of the grille similar to stock or the first option that holds a buckle of sort, which allows for a piece which the front plate mounts to, that can be detached quickly. Center mount with removable bracket for CA. There is a retractable/pull out design available, but not offered for the M5 nor would it fit.
Old 20th May 2010, 21:59   #9
Lordrandall
The double sided tape is a good option, I could even use it on the OEM bracket I have, just stick it to the bumper cover with that tape instead of screws. Cheaper too.
Old 20th May 2010, 22:04   #10
wentouch
Cops will either laugh and sign the ticket off, or laugh and kick the mount off, with the referred method. True story. Heh.
Perhaps, it also possible to mount a rail mount, similar to a drawer rail/mount under the front bumper, mount the plate to the end of the rail and slide the mount on/off when necessary.
Front license plate in Mass. Do drill our not to drill? Point8 E39 M5 and E52 Z8 Discussion 27 20th August 2009 22:23
Barter (2) "Cosmo Racing" License Plate Frames FREE Krasch47 Parts / Other For Sale or Wanted 0 23rd July 2009 23:18
paging m5: TX license plate - "ITS XTC" cvp911t Sightings / Spotted M5 around the world: was it you? 0 18th September 2006 20:53
Fixing Front License Plate Drill Holes sarends E39 M5 and E52 Z8 Discussion 13 14th June 2005 17:51
