Seat Belt Twisted - BMW M5 Forum and M6 Forums
Old 28th March 2010, 06:51   #1
M5Prospect
M5Prospect's Avatar
Garage: 03 M5 Titanium Silver
Seat Belt Twisted
Thanks for taking the time to read this.
Basically, when I buckle my seat belt, the belt itself is twisted. I've tried to undo the twist manually, but the part where the belt goes through the buckle or male part is real thin.
Any suggestions? I have no idea how it go that way.
I have did multiple searches and could not find much. Usually, its people replacing seat belts for new sporty ones or its removing the whole seat.
M5Prospect is offline   Reply With Quote
Old 28th March 2010, 07:34   #2
Need4Spd
Need4Spd's Avatar
Are you sure it's "wrong"? How did it happen? Was it OK before? Did someone else drive the car? If it's ok to begin with, it should be really hard to get it wrong.
Anyway, it's a bit hard to describe how to fix this but you need to sort of fold the belt in the correct orientation and in a triangular shape so it enters the slot in the buckle with just a small triangular corner, then once you get it started, pull that fold through the slot. It takes some amount of effort, which is why I say it's hard to have happen just by happen-stance. Usually I find this has happened on cars that aren't mine; somebody doesn't understand the way the belt really goes and thinks it's "wrong," so does the triangle/fold trick I describe above to make it "right," only it's really "wrong." Or, the belt gets a bit tangled with a fold in it, which fold gets caught in the slot, and instead of un-tangling it first, the wearer just pulls hard on it and ends up turning it 180 degrees. If the belt buckle is properly on the belt, when hanging on the pillar the tongue of the buckle should face into the interior, not away towards the pillar.
Before you do this, btw, sometimes the buckle is actually on correctly but the belt got twisted somewhere inside the pillar. Try first un-reeling the entire belt out of the pillar. That might correct the orientation of the buckle. If it doesn't, then do the fold/triangle trick.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is online now   Reply With Quote
The Following 3 Users Say Thank You to Need4Spd For This Useful Post:
jclyman (28th March 2010), M5Prospect (29th March 2010), Mike S. (29th March 2010)
Old 28th March 2010, 15:04   #3
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
If it turns out your buckle is really wrong fold your seatbelt thusly:
Pull the buckle over this fold. It will be a little tough. Doing so effectively flips the buckle 180 on the belt eliminating your twist. This is what Need4Spd was describing, but he doesn't have my wicked sweet graphic now does he?
P.S. I made this pic like a year ago for my R32 forum when the same thing happened to my passenger seatbelt. Just didn't want you thinking I made it special just for you.
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline   Reply With Quote
The Following 6 Users Say Thank You to TMcNasty For This Useful Post:
gsfent (28th March 2010), jclyman (28th March 2010), M5Prospect (29th March 2010), Mike S. (29th March 2010), Need4Spd (28th March 2010), Vector57 (21st April 2011)
Old 28th March 2010, 17:31   #4
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
A picture is worth a 1000 words!!
gsfent is online now   Reply With Quote
The Following User Says Thank You to gsfent For This Useful Post:
Old 28th March 2010, 23:52   #5
Need4Spd
Need4Spd's Avatar
More like 182, according to my word counter! Yes, that pic is perfect!
The Following User Says Thank You to Need4Spd For This Useful Post:
TMcNasty (29th March 2010)
Old 29th March 2010, 02:31   #6
M5Prospect
M5Prospect's Avatar
Jawsome
Fellas,
Once again, thank you all for taking time out to respond. I will try the folding trick.
Not too sure how unreeling the whole seatbelt works, but I will try both.
Now I will "M5 Board" Thank you all.
I will try to update pictures if possible.
Thanks,
Vince
Old 29th March 2010, 05:56   #7
sullym5
sullym5's Avatar
Garage: M5 Sterling Grey 2002
If it doesnt work out they are replaceable for under $200.
sullym5 is offline   Reply With Quote
Old 29th March 2010, 17:57   #8
JustinM5
Garage: Carbon black M5
I always wondered why some belts were 'wrong', and never thought you could fix it without unbolting something!
JustinM5 is offline   Reply With Quote
Old 30th March 2010, 23:24   #9
ger
ger's Avatar
Garage: M5 Le Mans Blue
The belt itself should lay 'flat' between the 'B' post (ie where it comes out) and where it attaches to the seat, if this is not the case then it might have got twisted inside the pillar (pull it all out in the hope the 'fold' comes with it, if not it trim removal time!) or someone's removed the end from the seat and re-fitted it incorrectly, easy to correct as long as you have a Tx50 bit.
The buckle's chrome bit should be facing the middle of the car (with everything in 'rest' position), if not, the belt has been pulled through it as described above.
HTH.
11/2000 M5 Le Mans Blue
My car's thread
ger is online now   Reply With Quote
Old 30th March 2010, 23:34   #10
blackxs
blackxs's Avatar
Garage: M Roadster
Happens on my truck all the time. When retracting it just gets caught up sometimes, sometimes will get stuck at the fold and sometimes will just go right through. Fixing it is very important because a seatbelt with such tension folded wrong can cut you during an accident. In my truck I just fold it and push it back through the buckle so it set correct again, never had the exact problem on my M5 so I cant help too much but wish you good luck!
Car modifying is about improving things
Not just changing them
Please mod responsibly
blackxs is offline   Reply With Quote
Twisted Drivers Seat - anyone experienced this? LEENA1 E39 M5 and E52 Z8 Discussion 35 28th May 2012 05:33
Seat belt pretensioner VUK E39 M5 and E52 Z8 Discussion 0 8th October 2009 19:18
02 e39 M5 seat is all twisted up RJScotti E39 M5 and E52 Z8 Discussion 11 20th August 2009 05:52
driver's seat belt gillie E39 M5 and E52 Z8 Discussion 5 8th February 2007 02:37
Seat Belt. BURTON E34 M5 Discussion 6 17th February 2006 15:14
