Mysterious Driveline Noise, Upon acceleration and deceleration - BMW M5 Forum and M6 Forums
post #1 of 5 Old 24th March 2010, 04:23 AM Thread Starter
willsauter
I've fixed many a drive line noise before, and this one has me stumped. To breifly explain, the clanking noise started after a spirited drive with a friends Z06 last Summer. In Sept 09, the car developed a clicking, tapping on the driveshaft sound when accelerating hard or decelerating hard. The intensity of the noise changes with engine load. When barely accelerating, as done by the cruise control + key, the noise is barely there. For the few miles the car has covered since the development of the noise, it has been very difficult to acclerate at all without some noise present. The interval between the tinks changes with wheel speed/driveshaft speed, and is not related to gear engaged (happens in all gears forward and reverse). The only exception to this is that driveline torque is much greater in lower gears than higher gears, i.e. when you press 1/2 way down on accelerator in 2nd gear, the noise is very loud; when you press 1/2 down while in 5th gear, the noise is not as loud; I presume because the driveline is not under the same load.
I started to think that the rear CV on the driveshaft was causing this, and the loud tink tink noise is due to the resonating through the hollow driveshaft. If you have ever removed a BMW driveshaft and knocked the wrench on it accidently while unfastening the guibo, you know the pitch I'm talking about.
So last September, I put it on the lift to inspect the situation. I found 6 loose rear CV bolts, Most of them were between 1 turn and 2 turns from full torque spec. As the nuts were replaced when the joint was replaced, I expect that I failed to meet the torque spec, which is hard to do, as a crowsfoot is required to make them tight. After I got that sorted, I figured the problem was fixed. I put the exhaust back on and went for a test drive. Noise still there.
I parked the car for 1 month; bought an 01 740IL as winter was approaching. Figured I would deal with the problem after winter.
Fast forward six months to last night. Drove the car home with no noise in the driveline whatsoever 3/22/10. No tink, nothing... Took it very easy, as if the car still had the problem. I did my best to not exacerbate the issue, and succeeded.
This morning, 3/23, went to work. No noise until the last 1/2 mile of a 5 mile long 45 MPH commute. Tink ,tink, tink, etc. Seemed to only do it when turning left or right (which makes NO sense at all).
After work, car was tinking on all acceleration and deceleration. Total mile driven since first hearing the noise in Sept 2009 is probably 15 or so.
I recorded the ride home tonight with my iphone sitting on the rear driveshaft hump in front of the rear seat. Take a listen real close, and see if you think a driveshaft replacement will fix this issue.
I need to get this fixed, as I just got it out of the garage after a 6 month hibernation. For some reason, it didn't fix itself while it was in storage
Any ideas would be AWESOME.
Car is an 03 M5, 88,000 miles.
Service History (Related to Driveline)
77,000 miles - New Flywheel/Clutch, Driveshaft Center Bearing, and Rear CV Joint on Driveshaft, and Guibo. New Diff Bushings.
Moving back and forth in my driveway
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Driving through the subdivision, no faster than 25 MPH, taking it easy.
+ YouTube Video
THANKS
Will
willsauter is offline
post #2 of 5 Old 28th June 2010, 08:14 PM
springer454
springer454's Avatar
springer454 is offline
post #3 of 5 Old 28th June 2010, 09:09 PM
E55AMG2
E55AMG2's Avatar
E55AMG2 is offline
post #4 of 5 Old 28th June 2010, 11:03 PM
gzig5
What you describe sounds almost exactly like what I had going on with my car shortly after getting it and doing some "spirited" driving. I thought it was the CV and changed it to no avail. Finally took it to my indy because it was two below zero in my garage, and he found a couple of broken teeth on the ring/pinion in the differential. Supposedly very rare, but it happens. I ended up going with the Dinan 3.45 diff because it was on sale at the time and available. There are other options. It would be pretty easy to drain the diff and pop the back cover off to confirm. You probably need to change the "lifetime" fluid anyway. I hope for your sake that it is something less expensive, but it's not the end of the world. Good luck.
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is online now
post #5 of 5 Old 28th June 2010, 11:38 PM
vantaam5
I would rather suspect differential issue.
Can you move the input flange on the diff up and down or back and forth?
vantaam5 is offline
Mysterious noise... sdietric E39 M5 and E52 Z8 Discussion 6 23rd May 2009 04:52 PM
Abnormal noise from rear during acceleration Valkman E39 M5 and E52 Z8 Discussion 3 22nd February 2009 11:19 PM
thumping noise on acceleration Alin10123 E39 M5 and E52 Z8 Discussion 18 21st June 2008 02:00 AM
Engine stuttering during deceleration? Brother Methias E39 M5 and E52 Z8 Discussion 3 10th September 2007 03:56 AM
Squeaking Noise When Starting Acceleration mswartz E39 M5 and E52 Z8 Discussion 2 27th March 2007 03:09 AM
