Open bonnet,remove pollen filter housing(don't forget to disconnect bonnet switch) in order to get to the brake fluid reservoir.
Remove bolt(Phillips head) of carpet side panel and slide it backwards to remove it.
Remove plastic panel under dash board(Phillips head and T10 screws)
Remove screw of bonnet lever(Philips head) and the plastic bolt behind it(flat head).
Pull up the inner plastic rocker cover and remove it.
Pull the whole dead pedal unit backwards out.Disconnect trunk switch.Remove the assembly completely.Is a bit PITA to do...
Remove the plastic cap in the carpet behind the clutch pedal and pull the carpet away.
Get the car front on jack stands,remove plastic tray under gearbox.
Remove the nuts from heat shield(10mm socket) and pull it down abit in order to get a bit space.
Remove slave cylinder from gearbox(13mm socket), remove circlip of the clutch line connector with screw driver and let the fluid drip in a bucket.
Remove circlip of the line on the master cylinder and put some paper towels there to catch brake fluid.
Push old line out through the whole in the fire wall behind accelerator pedal.
Insert new line ffrom underneath the car with the protection caps still on.
Have to also pull it a bit from the inside in until it is in position.Connect line on the master cylinder.
Connect line on the slave cylinder and dont forget the bracket!
push rubber gromet in the fire wall(another slight PITA).
Install slave cylinder and bleed the clutch system.
Check for leaks and assemble the rest.
Get a cold beer......
__________________ 2003 M5 "The Matte Black Money Pit"
ALPHA-N by EVOLVE,Power remapped-modified heads-Schrick cams-modified throttle bodies and velocity stacks-modified rods and crank-EVOLVE headers -Willans 4-point harness -CAI with custom built MAF delete tubes fed through fog light covers -lighter oem flywheel-Sachs performance clutch-clutch stop-Drexler differential stock ratio-electric fan with control unit-545i SSK-HEL braided teflon brake lines-IATS reloction-Bilstein PSS9-HD sway bar links-M3 swaybar brackets rear-CF bonnet with vents-subframe reinforcement-40mm wider fenders front and 25mm rear-aluminium ///M pedals and foot rest-CF roundels-LED AE-foglight delete-AP BBK kit 6piston calipers front-CF strut bar front-full suspension rebuild-camber plates with uniballs front-Dinan sway bar-illuminated inner door handles-Alcantara roof liner-M-Audio system- Hamann HM2 10x19" wheels 275/30 front and 295/30 rear
Carbon black/black sport interior/titanium trim,37k miles,bone stock -20cm of the trunk and quarter panels missing...
-rebuild in winter 2011/2012
-"submarine edition",a bit boost and some M5 parts...
Drew,sometimes the pedal is a bit too soft.But you see only from underneath if it is sweating.Worst case is the line blows and the pedal stays on the floor.Have to change anotherone next week,also a few members had theirs changed yet.
Costs about 30$ and an hour labour.
Better than getting stranded somewhere....
Here is another thing to change soon,O man.. my list for the 100k maintenance is growing long
Vantaa.. can you post the part no. and save us some search ?
Regards
__________________ The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
__________________ 2005 Mercedes E55 ///AMG Kompressor - Black/Black Black Birdseye Maple Trim Bi-Xenon Active Headlamps DVD Navigation w/ iPod Integration Harmon-Kardon Premium Sound
Thanks,everyone for the comments!
Part number is:21526751171
Peter,had a problem with the connection on the master cylinder side with the braided hose I built.Ordered a different connector which might take another two weeks until it is here
I did not want to take chances with my old line and the new OEM part is so cheap.You know I am a bit paranoide on failing parts,so the whole last week each time I used the clutch,I waited for the pedal to stay on the floor
Have now more relaxed driving with the new line in until the rest for my braided line comes.
