DIY - O2 sensor change - Page 4 - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 7th July 2010, 22:40   #31
HarvesterOfBeer
HarvesterOfBeer's Avatar
Garage: 2000 M5 Carbonmetallic, 1998 M3/4/5 TiAg
Man, changing the sensors on the Beast is sooooo much easier than my E36M3.
HarvesterOfBeer is offline   Reply With Quote
Old 12th September 2010, 17:48   #32
ArgM8y
ArgM8y's Avatar
Garage: 2003 M5 (Jet Black)
Originally Posted by TMcNasty View Post
These photos are of the drivers side (USA) post-cat O2 sensor, but all four sensors attach the same way. The only exception is the pre-cat O2's wire is not held to the body by the metal clips.
Get your car on ramps/jackstands/a lift: (Ken edit)
That's all there is to it really. Good luck!
@TMcNasty - Just replaced my O2 sensors (pre and post) using your directions. Worked beautifully, and I found it easier to break free the sensors with the beast up on a lift, vice on jacks. I just couldn't get the proper leverage. THANKS AGAIN - I've saved your directions for the next time. Cheers!
ArgM8y is offline   Reply With Quote
The Following User Says Thank You to ArgM8y For This Useful Post:
TMcNasty (12th September 2010)
Old 12th September 2010, 21:46   #33
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Arg...glad it worked easily. The hardest part of this job imho is coughing up the $ for the parts. Yeah a lift makes removal much easier I'm sure, but luckily with a little patience and tweaking of breaker bar positioning it can be done on ramps.
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline   Reply With Quote
Old 16th September 2010, 13:10   #34
jmlag
jmlag's Avatar
Garage: BonitaBeast '03 M5 Schwarz II/Caramel
Just did my pre-cat O2's. Took all of 15 minutes with a lift! Thanks TMcNasty for the write up and the pics.
It made the preparation that much easier. I had all the tools ready and it was as easy as lift, disconnect, connect and drop. Done.
The Stable:
2003 DINAN E39 M5
2003 MB G55k....KLEEMANNIZED!!
BMW CCA NJ #416647
Mostly stock......looking
The Other Stable:
2012 Indy Fab Ti FLW
2011 Indy Fab Ti FLW MTB 29er
2007 Indy Fab Steel Deluxe SS 29er
1990 Gary Fisher Advance SS
jmlag is offline   Reply With Quote
The Following User Says Thank You to jmlag For This Useful Post:
TMcNasty (24th September 2010)
Old 21st October 2010, 18:54   #35
doe
doe's Avatar
Garage: 2002 Sterling Grey M5
Sales Feedback: (6)
Originally Posted by Hawkwind View Post
This worked well on the pre-cat sensors.
3/8" Offset Oxygen Sensor Wrench
Do you need any additional for the post-cat sensors?
I plan on doing all 4 this weekend and want to make sure I have everything necessary.
Dustin
doe is offline   Reply With Quote
Old 22nd October 2010, 00:04   #36
ArgM8y
ArgM8y's Avatar
Nope, that socket worked great when I replaced all 4 of my O2 sensors. I'd suggest having a breaker bar handy if to assist if needed.
Cheers!
Old 4th December 2010, 04:02   #37
M55555
M55555's Avatar
Garage: 2001 Carbon Black M5
Sales Feedback: (10)
Extremely easy DIY. I'd rate this at like 1/10 difficulty level. Took me about 15 mins to remove both, including time to jack up car and place jackstands. Installation took another 15 minutes. My INDY quoted me $340 OTD.
I ordered my Bosch 13477 (Pre-Cat) from Amazon for $53.03/each. They do come with anti-seize putty already on the threads.
Amazon.com: Bosch 13477 Oxygen Sensor, OE Type Fitment: Automotive
I did it with a jack and jackstands. One side at a time. Tools used were a big 22mm open-ended wrench, hammer, and a 10mm socket. I would say 2-3 taps of the hammer loosens the O2 enough to unscrew by hand.
Here's another useful thread:
HOWTO: Replace O2 sensors (w/pics)
I attached a pic of my pre-O2s at 69k miles.
2001 Carbon Black ///M5
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete
Custom Software Tune
Bilstein PSS9 Coilovers
Ground Control Camber Plates
BBS CH in Custom Satin Black
Hankook Ventus V12 255/35/19, 275/30/19
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser V1
SLIMM Front Splitters
SLIMM 3.5" Fog Light Air Ducts
SLIMM OEM Euro Armrest
M55555 is offline   Reply With Quote
The Following User Says Thank You to M55555 For This Useful Post:
dantedorazio (4th December 2010)
Old 5th December 2010, 02:24   #38
Vector57
Vector57's Avatar
Garage: 2001 M5 Anthracite
Good to hear that it went easily. Judging by the heavy soot on the senor bulbs, I thought I'd raise the question of
your thermostat not regulating to the minimum 79 degree C. It sure appears to be running excessively rich.
Either that or possible cracks around the O2 sensor bungs.
What temps are you seeing at freeway speed with Test #7 (KTEMP) displayed?
Just a thought,
Alan
Vector57 is offline   Reply With Quote
The Following User Says Thank You to Vector57 For This Useful Post:
M55555 (7th December 2010)
Old 7th December 2010, 05:56   #39
M55555
M55555's Avatar
Just a thought,
Alan
Alan-
Good observation. O2 sensor bungs are brand new as its on my brand new SS header connector pipes. I will check this tomorrow and report back what readings I get for #7. Hope it hits that 79 temperature.
Old 8th December 2010, 20:28   #40
sneal4600
Garage: 2002 M5 Bluewater-no mods
This is one of the first things I will be changing when my car arrives from Cali. It looks very simple, esp with a lift. But damn these sensors are expensive. I thought $35 for my Jag was high. I am looking at over $300 for all four from Bimmmerzone. Are the post cats just as important as the pre cats to change?
sneal4600 is offline   Reply With Quote
02 sensor DIY? SoCalJD E39 M5 and E52 Z8 Discussion 28 17th August 2009 21:00
DIY oil change? Jamie140 E60 M5 and E61 M5 Touring Discussion 28 9th January 2008 19:38
DIY TPS Change?? Richbob E39 M5 and E52 Z8 Discussion 3 18th December 2007 21:06
DIY oil change dick bergen E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 4 7th February 2002 04:19
DIY Oil change teezm3 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 7th January 2002 01:22
