Originally Posted by havasusteve03Beast
Doe,
You didn't say, but was that $260 for Pre-CATS or all 4 sensors (Pre-CAT & Post CAT's)? Amazon has the Pre-CATS for roughly $110 last time I checked. I would only replace the pre-CATS since they are the ones that have the history of going bad. Post-CATS dont go bad very frequently.
My 2 cents
Steve
True, but I thought it was post CATS that measure the efficiency code by comparing the values from the pre cats to allowable values the post cat "sees". If the post cat sees too much flow (from say headers), then it gets a measurement outside the allowable range.
But for the OP, pretty unusual for BOTH post cat O2's to go bad at the same time and since you didn't trip a code after installing the revised exhaust system, I would look for a more common issue, as suggested above.
