We all know how annoying the warnings are in our car. Since my t-stat was replaced I was getting, "bing" Check Coolant Level. Didn't look dangerously low so I put it off for a week. Was at the dealer yesterday and they topped it off for me, engine was warm. This morning, "bing" Check Coolant Level. Looks like the coolant is back down to where it was before adding some yesterday, even when the engine is warm.
Only thing I can think is the t-stat has a leak. But the coolant level doesn't seem to drop below a certain level. And I haven't seen any liquids on the ground where I park my car. Just trying to get rid of the annoying "bing". Suggestions?
2001 ///M5 Jet Black Current
Dinan CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning
Ground Control Coilovers, Beastpower Rear Sway Brackets, Linea Corse Z2S 19" wheels w/ Continental DW tires, Custom Leather/Alcantara steering wheel,
35% window tint, Valentine One Hardwired, ACS style splitters, E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior,
BSW subwoofer kit, Competition 6.5" front speakers in custom baffles, DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs,
AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk Planned
Custom leather race seats, Headers, SS x-pipe, Custom CF power dome and vented hood,
larger clutch kit, radiator and electric fan, U/D pulleys, Forced Induction system =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= DIY Accelerator Pedal Removal . . . . . . . . . . . . . . . Shadow Chrome: A closer look My Custom covered steering wheel . . . . . . . . . . . . .E39 M5 DIY for Dummies Plastic Screwhole Fix . . . . . . . . . . . . . . . . . . . . . . .Definitive Dinan CAI filter size My plug-n-play LED light upgrade . . . . . . . . . . . . . .$6 DIY headrest in-car camera mount Center Console Swap (pics) . . . . . . . . . . . . . . . . . .DIY adding AC and USB power outlets DIY fix squeaking steering wheel adjustments
Have you pulled the dipstick to see if the oil looks milky? Hopefully you dont have a blown headgasket.
Drew,did you change the t-stat by yourself or let a shop do it?
Most likely one of the o-rings in the t-stat housing was torn at install.
__________________ 2003 M5 ALPHA-N by EVOLVE-Schrick cams(currently out) -100 cell race cats -ECU Evolve Power remapped-Willans 4-point harness
-CAI with custom built MAF delete tubes fed through fog light covers - X-pipe -Alcantara steering wheel and illuminted ZHP shifter -lighter oem flywheel-Sachs performance clutch-Drexler differential stock ratio-electric fan with control unit
-Bilstein PSS9-8+9x18" BBS RS745 on PS2s
mods not yet in:
-big bore throttle bodies-Brembo 4-pot calipers front with 2-piece discs-sleeved block-equal length headers
-and a bunch of other engine stuff...
-custom built radiator
I had a shop do it, the one that messed everything up and I really don't want to go back.. but looks like I'll have to get them to take a look at it again. Just when I thought I had everything fixed..
Is there an easy way to inspect if the t-stat is leaking? from above it looks fine, should I try to feel down under it?
Try following the three hard lines that exit the rear of the T-Stat housing and go into the manifold. If you are leaking there then there's a good chance you'll see some dried coolant residue in the area.
Also, check the coolant level when the car is cold. Make sure it's filled to the KALT line. There's a good chance that the system burped some time after the T-Stat and sucked a significant amount of coolant out of the overflow and into the system.
There's also a good chance that the cap isn't holding pressure anymore and you are losing coolant to the atmosphere.
Otherwise it could be any number of hoses, connections, or even the heater core.
'11 F10 550i Dark Graphite / Oyster-Black (wife's car -- on order)
'11 M3 Coupe Silverstone/Black
'06 330i Sapphire Black/Black (outgoing...)
'03 M5 Sedan Imola Red/Black
'93 M5 Sedan (3.6) Sterling Silver/Black
Past: '08 M5 Sedan | '10 M3 Coupe | '07 M6 Coupe | '07 Z4 M Coupe | '02 M5 Sedan | '95 M3 Coupe -- x2
The Following User Says Thank You to AMP For This Useful Post:
So if there doesn't seem to be any leaks, it could be a cap problem? How do I check if the cap isn't holding pressure?
update: yesterday and today the car was warm and I could hear the pressure release when unscrewing the cap. I'm hoping its just a "burp" and it just needs some more coolant. Is there a coolant I can use from Autozone/Adv. Auto Parts?
If you haven't lost much then I would just add some distilled water to make up the difference.
Check with your shop to find out what kind of coolant they used and then get that for any major top-ups.
Caps can be pressure tested and there's a chance that an auto parts store can do this for you... otherwise your mechanic can do it. Off the top of my head I can't remember the specified pressure. I've seen vehicles where the cap is letting go a couple of psi below the spec causing issues like this. They still hold pressure, but not enough pressure.
You need to bleed the system per TIS. Top off coolant, turn heat on high, fan on low, run until you reach operating temperature, then shut of and let it cool down. Top off and repeat process until it no longer needs to be topped off. This happened with mine following a thermostat change, and the TIS bleeding process works like a charm.
--Peter
__________________ The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and Custom-Bored 52mm Diameter "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Stoptech Trophy Sport Brakes (6-Pot Front/4-Pot Rear; 355 mm Rotors All Around), Dinan 3.45 Differential, Rogue Stage 3 280mm Clutch with Custom 850 CSI Slave Cylinder and JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement, GC Coilovers (550 7" Front/325 10" Rear), Dinan Front and Rear Swaybars, TC Designs Rear Sway Bar Brackets, Dinan Monoballs, Dinan Rear Wheels (18 x 9.5) All Around With 10mm Spacers and 90mm Wheel Studs, Michelin PS2s 275 35 18s All Around, UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, TC Designs Roll Bar, Zionsville Super Duty Cooling System, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, OKD Plasma Ignition Coils and Plug Boots, Kenne Bell Boost-A-Pump, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Clarion DRZ9255 Head Unit (Custom Installed by Timmay77), Two Alpine PDX-5 Amps, HAT L1 Pro Tweets, HAT L3 Mids in Custom A-Pillars, Illusion Audio ND-8 Mid-Basses in Custom Door Panels, and Two Dynaudio MW190 Subs Running IB in Rear Deck, PLX Digital Gauge, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, EAS Competition Steering Wheel, Leather Eurodash, Schroth 4-Pt Street Harnesses, Dinan Foglight Delete Kit, and Various Other Bits and Pieces
Coming Soon!
Hankook R-S3 285 35 18s All Around, Full Leather Doorcards, Stoptech Carbon Ceramic Rotors, Quad Head Laser Interceptor, Balanced and Blueprinted S62 Built by Bavarian Solutions
Maybe Down the Road
Stand-Alone Engine Management
The Following 2 Users Say Thank You to herrubermensch For This Useful Post:
