Old 14th March 2002, 03:09   #1
Rave E55
Garage: Porsche
Send a message via AIM to Rave E55
Exclamation STOP TECH's are on!
A big Thank you to DZ for mounting them, they look a feel great.
S4 996 Turbo
Titan 4x4
Rave E55 is offline
Old 14th March 2002, 03:26   #2
BostonRocket
BostonRocket's Avatar
Rave,
Congrats buddy! Whenever you can, could you post some pictures? Thanks!
'Rocket
BostonRocket is offline
Old 14th March 2002, 04:42   #3
01M5
01M5's Avatar
Garage: 01 LeMans Blue M5
DZ,
Please tell us how the installation went and your opinion of the kit especially vs. Movit.
Thanks,
Najeeb
01M5 is offline
Old 14th March 2002, 05:13   #4
DZeckhausen
DZeckhausen's Avatar
Garage: 2001 540i 6-Speed, Alpine White
Send a message via AIM to DZeckhausen
Originally posted by BostonRocket
Rave,
'Rocket
I'm sorry I don't have a ton of photos. (Or any photos, for that matter!) This was the first StopTech kit I've installed and I was focused on getting the installation technique down and totally forgot to take any shots. StopTech doesn't have any real nice photos of the kit on their website either.
First impressions of the kit:
The folks at StopTech do know the meaning of the word "ergonomics". The way the kit is boxed up is fantastic. Reminds me of unpacking a Dell computer. The rotors are mounted to a stiff cardboard backing plate and sealed in plastic film. There are handles that make it easy to lift the rotors out of the box. Very nice touch. All components are very nicely labled, which is great for the novice installers. There are comprehensive instructions, although I did spot a few errors and areas for improvement.
Ron's kit came with Pagid blue pads that were the same form factor as the rear Porsche 993 TT pads on my wife's 540i/6. They are 62.5 square centimeters. This is slightly less than the mov'it front pads which are 75.5 square centimeters. It wasn't obvious from holding it in my hands. I had to go look up the numbers later.
The calipers are very nice looking units and have slightly smaller piston sizes than the mov'it. In theory, that should mean that the pedal feel is stiffer. We took the M5 on a 30 minute drive to break in the pads and rotors, but the traffic was too heavy to do anything other than scare or piss off a few fellow highway drivers. (I wish I lived in New Hampshire again!) We weren't able to do enough cycles of 80 to 5 mph braking, so the brakes didn't really feel that strong. I'm sure they will get better after Ron has put them through their paces. I've been through this before and there is a big difference when the pads are bedded in and the rotors seasoned.
StopTech has a patented bridge design that they claim stiffens the caliper by 30 percent. I believe them. It's a substantial looking piece that's held in by two bolts and it's obvious that it adds structural support to the caliper. Unfortunatly, the bridge bolts are inserted from the inboard side and the lower one interferes with the M5 lower ball joint. This means you need to unbolt the caliper bracket and swing the entire assembly up before you can remove the bridge bolts. This could easily be fixed if StopTech would simply reverse the direction the bridge bolts were inserted into the caliper. Doing that would greatly speed up pad changes. As it is, it's a a bit of a pain. But unless you track the car, you should get at least 50,000 miles per set of pads.
Bottom line - the StopTech kit is a serious competitor to the 320mm offering from mov'it. Pricing is identical, unless you consider that the mov'it kit includes rear lines and the StopTech kit does not. Rear lines are available from StopTech as an extra cost option.
Aesthetics are always a consideration here. Until recently, the mov'it kits had the "Porsche" logo on them. Not any more. Porsche put their foot down and now all mov'it brakes carry their own tasteful logo. The StopTech logo needs some work. The rectangular outline of the logo clashes with the organic form of the caliper and the graphics look dated. I'm hoping that StopTech simplifies the logo and makes it smaller and more complementary to the flowing lines of the beautiful caliper.
The choice of brake kits may come down to wheel fitment issues. The StopTech kit uses a slightly smaller caliper than mov'it and the rotor hat and bracket seem to position everything just a bit more inboard. This means that the StopTech brakes work with stock M5 wheels without spacers. StopTech is better in terms of caliper to wheel spoke clearance. However, the larger diamter 355mm rotor (vs 322 for mov'it) positions the caliper futher out and that means it is more likely to interfere with the barrel of many 17" wheels. I tried to test fit a BMW Style 32 (radial spoke) wheel and it interfered with the inner diameter of the wheel. This wheel won't even work with spacers.
When I get some time, I'll do more test fitting and put together a web page of what works and what doesn't for each kit.
My wife and I enjoyed the chance to get to know Ron (aka Rave M5). He's an interesting guy and a clever inventor with some great product ideas. I hope our paths cross again soon.
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
DZeckhausen is offline
Old 14th March 2002, 05:17   #5
Gustav
Administrator
Gustav's Avatar
Really?
Annoying. That was one thing I enjoyed about the Movits.
Gustav is offline
Old 14th March 2002, 05:37   #6
Rave E55
Garage: Porsche
They sure will, thanks again. DZ is by far the most capable engineer/mechanic I've ever had the pleasure of meeting, and his wife likes cars, way to go DZ!
S4 996 Turbo
Titan 4x4
Rave E55 is offline
New wheels and Stop Techs Miami M5 E39 M5 and E52 Z8 Discussion 21 17th July 2003 18:20
Gave up on the UUC Big Boy clutch stop! XrayMD E39 M5 and E52 Z8 Discussion 0 3rd May 2003 18:19
Paint rear calipers to match front Stop Techs? Cerberus E39 M5 and E52 Z8 Discussion 5 21st June 2002 07:17
Paint rear calipers to match front Stop Techs? Cerberus E39 M5 and E52 Z8 Discussion 0 21st June 2002 00:00
Page generated in 0.13664 seconds with 11 queries
