e39 Wheel Alignment Questions - BMW M5 Forum and M6 Forums
post #1 of 14 Old 21st February 2010, 12:58 PM Thread Starter
TimInNOVA
TimInNOVA's Avatar
I took my 2001 M5 (79,800 miles on it) to a tire store to get the wheel alignment checked and I have a few questions post-results.
Now the car went down the road true and straight, but the outer-edge of both front tires are showing considerable wear. Back in August I replaced the thrust-arm bushings due to steering wheel shimmy over 40MPH, and that solved that problem. I thought the wearing on the outer-edges might have been caused by the worn thrust-arm bushings (that is one of the symptoms as I understand it), but I thought it could also be caused by a bad case of toe-in.
1st question: Is the camber and caster on our e39 M5's adjustable? The tire store service writer claims that is not. I'm pretty sure this is not true, but I thought I would ask the M5 forum knowledge base before I call BS.
2nd question: What would cause my right-front wheel's caster to be out of spec? A worn bushing?
3rd question: For those alignment wonks out there, please look over my before and actual alignment values and tell me if there is anything I need to get taken care of (see attached image).
Thanks everyone.
TimInNOVA is offline
post #2 of 14 Old 21st February 2010, 02:37 PM
Easy E
On a stock car, you can adjust three things: front toe, rear toe, and rear camber.
Right front....hit any curbs lately?....maybe it's not so bad....you're very close to spec.
3rd question: For those alignment wonks out there, please look over my before and actual alignment values and tell me if there is anything I need to get taken care of.
Looks like they only made it worse? They should have been able to correct the rear.
Did you watch them do it? Did they do anything? Did they take the 'before' with nobody in the car.....then just get one of their guys to sit in it for the 'after'/'actual' reading?
Easy E is offline
The Following User Says Thank You to Easy E For This Useful Post:
TimInNOVA (21st February 2010)
post #3 of 14 Old 21st February 2010, 03:23 PM
wsfm5
wsfm5's Avatar
Just had mine done. Also, make sure they weight the car per BMW spec. Typical alignment shops give you a blank look on this one, but a good indy shop or a dealer will know exactly how to do it. Procedure includes weight in the front, rear and the trunk. Specs are out here, just do a quick search.
wsfm5 is offline
The Following User Says Thank You to wsfm5 For This Useful Post:
post #4 of 14 Old 21st February 2010, 05:14 PM
jclyman
In Memoriam
jclyman's Avatar
As Easy E said, the front looks like it has be making love to curbs, but NOT too much "love."
The rear camber is OK, for most NON-spirited drivers ... Lower NEGATIVE camber will give better rear tire wear ... less rear inside wear, wear which is common for factory settings. However, I don't understand why the rear Toe-in is so great ... large amounts of rear Toe-in would increase rear wear I would think, and possibly make the rear tires "humm" more loudly. I would think it offsets the wear advantage of less negative camber.
I am NOT an expert, but I would be thinking along those lines.
- Daniel Boorstin
jclyman is offline
The Following User Says Thank You to jclyman For This Useful Post:
post #5 of 14 Old 21st February 2010, 09:42 PM Thread Starter
TimInNOVA
TimInNOVA's Avatar
Thanks for the replies everyone. I didn't watch them do the "alignment" as I dropped the car off and picked it up after the fact. I wasn't expecting a miracle from these hicks, as their lack of BMW knowledge was to be expected. I honestly just wanted to get the alignment values so I could then determine if the work of an expert was needed. Looking at the right front caster as well as the rear toe, I think I should start looking for this expert.
Can anyone recommend an alignment expert with e39 experience in the Northern Virginia / DC area?
Thanks!
post #6 of 14 Old 21st February 2010, 10:17 PM
intrepid one
intrepid one's Avatar
I am of the thought that alignments are better done by a knowledgeable dealer as opposed to a tire retailer..The average tire retailer may not see too many of our cars in a year, and you may not want them "learning" on your car..Just my thoughts
intrepid one is offline
post #7 of 14 Old 21st February 2010, 10:21 PM
jclyman
In Memoriam
jclyman's Avatar
... I wasn't expecting a miracle from these hicks, as their lack of BMW knowledge was to be expected ...
Don't worry TOO much about their lack of BMW knowledge. From the looks of the printout, they are using a machine where you key in the type of car (BMW M5, for example) and year, and the alighment computer compares the Actual numbers to the Appropriate numbers for your car. But, in your case, I am still puzzled at the rear toe. They maybe had a reason for that setting ... you should point it out to them and ask.
The alignment machines available today, don't take any brains, other than setting the steering straight, or resetting it and knowing how to compensate for the change (herein, could be problems for people who are dummies), and knowing what to adjust to change the settings ... You or I could do it just fine, with 5 minutes of training.
- Daniel Boorstin
jclyman is offline
post #8 of 14 Old 21st February 2010, 10:46 PM
Easy E
Originally Posted by wsfm5 View Post
Also, make sure they weight the car per BMW spec. Procedure includes weight in the front, rear and the trunk.
Dunno if I'd make sure they do it per spec......but I'd learn.....& think about it some.......all because 4 wheel independent suspension.
Spec is for a pretty much loaded up car....
I'd get it aligned for how it's driven most of the time.
For me......175 lbs in front seat....half tank of gas
Easy E is offline
post #9 of 14 Old 22nd February 2010, 03:44 AM Thread Starter
TimInNOVA
TimInNOVA's Avatar
The rear toe has me concerned and just as soon as I locate the best shop I will get it aligned again.
I'm starting to think the out of spec caster on the right front might have been a bad pot-hole I hit recently. Pot-holes are sprouting up around here like mad due to the snow plows. Could a bent strut or control arm cause this negative caster?
Thanks for all of the advice everyone.
post #10 of 14 Old 22nd February 2010, 03:44 AM
havasusteve03Beast
havasusteve03Beast's Avatar
Here is a sheet I used to determine alignment on my car:
In addition, here is a very good thread on the alignment discussion with regards to the rearend and weight in the car:
Alignment Question
Pay special attention to CSBM5 (Chuck) & Ard in their theories and recommendations....
Between all of that info, I sat down and wrote out the parameters I wanted the car aligned too.
Hope this helps
03 TiAg Biest; 565 RWHP via Dynojet - SOLD
03 CB Biest; 549 RWHP via Dynojet - SOLD
havasusteve03Beast is offline
The Following User Says Thank You to havasusteve03Beast For This Useful Post:
Easy E (22nd February 2010)
Wheel alignment: dj leethal E34 M5 Discussion 6 22nd January 2010 12:35 PM
throttle body alignment questions roortube E34 M5 Discussion 1 7th July 2009 03:15 AM
Questions Regarding Camber Plates & Alignment for our e39M5 bng4god E39 M5 and E52 Z8 Discussion 1 9th June 2008 12:50 AM
Advice with wheel alignment questions...? 507bhp E60 M5 and E61 M5 Touring Discussion 3 7th September 2006 09:58 AM
Wheel Alignment M5e3438 E34 M5 Discussion 7 17th November 2004 12:00 PM
