Old 12th March 2002, 19:27   #1
SWing
SWing's Avatar
Garage: 2000 Black 911
Send a message via AIM to SWing Send a message via Yahoo to SWing
Do you Warm up your engine?
Hi Guys,
I am just wondering whether you guys warm up your engine before driving in the morning. I thought I read somewhere that you can drive right away after starting your car but another buddy of mine with a M3 said that I need to warm my engine for at least a couple of mins.
What's your thoughts on it?
Cheers
Sugi
2000 Imola Red M5 (~Gone~)
2000 Black Aero 911
SWing is offline
Old 12th March 2002, 19:30   #2
GNALUZU
GNALUZU's Avatar
Garage: '01 M5 Carbon Black
There is no need to let the engine warm up in these cars. However, you should not push the engine into the higher RPMs until the oil temp rises, or the tach lights go out.
GNALUZU
'03 M3 w/ SMG
-SuperSprint Race Exhaust
-Ground Control Street/Race Adjustable Camber Plates
-RRT Brake Cooling Kit
-PowerSlot Slotted Rotors
-Cobalt Friction Spec VR race pads (track use only)
-18x9.5 Comp SSRs wrapped in Dunlop Super Sport R Compound (track use only)
GNALUZU is offline
Old 12th March 2002, 19:44   #3
chazzy
Garage: '01 M Coupe - Sapphire Black
On page 62 of the '01 M5 manual, it states:
Do not allow the engine to warm up by leaving it running while the vehicle remains stationary. Instead, begin driving immediately at a moderate speed.
'01 M Shoe, Sapphire Black Metallic
368S/4
chazzy is offline
Old 12th March 2002, 19:45   #4
Digi
Digi's Avatar
Garage: 2006 M5 Silverstone II
NO NO NO! Read the manual. This is the worst thing you can do to your engine. The manual says to start driving immediately at moderate speeds until the engine warms up. To do otherwise, you will foul up you engine with added carbon and contaminants, plus it puts increased wear on the components because it stays below optimum operating temperature longer.
Digi is offline
Old 12th March 2002, 19:51   #5
Charlie
Garage: BMW M3
Never let the engine warm up before driving!!! Better let the engine get to it's working temp by driving with low revs. It all has to do with exhaustfumes and our environment. Just keep in mind that you keep the revs low when the engine hasn't reached it's optimum temp. Take care,
Charlie
M3 '01
205 GTI 1900 '91
Charlie is offline
Old 12th March 2002, 21:28   #6
Philip
Garage: Pinto--Black
Send a message via ICQ to Philip
I always let it warm up for at lease a couple minutes before driving. Of course the politically correct manual and EPA advise against it. Guess you know what motivates them!
Philip is offline
Old 12th March 2002, 22:35   #7
Diamond Dave
Diamond Dave's Avatar
Garage: 2000 Ford Expedition
I believe it's pretty common for our cars to idle rough when cold, no? Mine does at least, but not excessively so.
I start her up in the morning and take 30 seconds to clean my glasses. By then, the roughness is gone and I drive away smiling. Keep those revs low until the tach lights go out.
My two pennies...
DWP
Diamond Dave is offline
Old 13th March 2002, 08:51   #8
Bart Carter
Bart Carter's Avatar
Garage: 2002 M5 Bluewater/Caramel
You don't have to warm up the engine.
You do have to let the oil circulate completely throughout the engine, coating everything before you start driving.
I usually turn on the engine and release the clutch pedal while in neutral.
Then I push my Accept button, select sport, put on my sunglasses and seatbelt, turn on my mobil phone.
Then I drive gently until my guages start to show the engine is warm.
If you follow a pattern like this, I feel you are doing the best you can for longevity.
-Bart
2002 Bluewater/caramel
Any other car is a compromise
Bart Carter is offline
Old 13th March 2002, 15:40   #9
BlueBiturbo
BlueBiturbo's Avatar
Garage: BMW
Re: Do you Warm up your engine?
Cheers
Sugi
Is your friend with the M3 an Indonesian too? Every Indonesian that I know always warm up their engine. Me on the other hand are always in a hurry (read: late in the morning) thus I only let it idle for 30 seconds of so but never higher than 3,000 rpm before the temp needle stays in the middle.
Every driver in Jakarta warm up their engine in the morning after washing the car, I guess it's a wrong habit huh?
Cheers,
Taffy
BlueBiturbo is offline
Old 13th March 2002, 18:13   #10
tfung
tfung's Avatar
Unless you plan to floor the car out of your garage, I think it's unneccessary to warm the engine up for more than a minute.... for the M5, you just have to wait till the idle comes back down to 600rpm before you drive....
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 62 28th December 2009 22:44
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
Break In period Joe Lapicki E39 M5 and E52 Z8 Discussion 21 29th March 2001 22:23
Page generated in 0.27565 seconds with 11 queries
