Strong Oil Smell Under Hard Acceleration - BMW M5 Forum and M6 Forums
post #1 of 15 Old 17th February 2010, 04:31 AM Thread Starter
CU'09
CU'09's Avatar
I had my valve cover gaskets replaced three or four months ago which cured this problem for a while but it is now back with a vengance! Hard acceleration and high rpm driving in general produces a strong oil smell in the cabin. I replaced the oil filler cap with an M3 piece which seems to have cured that leak. I looked in the plenum today, very clean. What other parts could be leaking oil or causing this stench?
CU'09 is offline
post #2 of 15 Old 17th February 2010, 05:38 AM
jclyman
In Memoriam
jclyman's Avatar
I would recommend, cleaning the engine area up, drive it hard, then remove the underbody panel and look for leaks.
- Daniel Boorstin
jclyman is offline
The Following User Says Thank You to jclyman For This Useful Post:
intrepid one (18th February 2010)
post #3 of 15 Old 17th February 2010, 05:41 AM
Tortuga
Tortuga's Avatar
Oil separator hoses? After Jon from the M shop suggested checking these, I found mine about the consistency of cold pasta...I would think those could stink, they vent the crankcase don't they?
00 E39 M5 BZ96901 Ti Silver Black Interior SOLD
[B][U][SIZE=1]06 E60 M5 B584518 Indianpolis Red/Black FOR SALE-SOLD!
New BMW Battery, New front end bits, New rod bearings 51k, ALL fluids serviced, Fuel Filter replaced
Euro SMG SW, S04 Pole Position Tires, some fun coding...Mainly Stock
Superformance Cobra MkIII Ford 427 stroker, Holly 850, roller cam & lifters, MSD Ignition, Tremec 5 speed CR, 550 HP 575 Tq, wilwood 4 pot f 2 pot rear, 5 pt harnesses, Bugs in the teeth, hair on fire motoring...
Tortuga is offline
post #4 of 15 Old 17th February 2010, 07:16 AM Thread Starter
CU'09
CU'09's Avatar
I swapped out two of the oil separator hoses and cleaned up the plenum (though there was not much in there at all) today but it still smells. I think I will clean more of the engine and see if that helps. Will oil that may have been spilled on the engine eventually burn off or will it remain there and smell every time it is heated up? Is it safe to use throttle body cleaner to get rid of oil spilled on the engine? I know it is flamable but does it evaporate off after a few mins?
CU'09 is offline
post #5 of 15 Old 17th February 2010, 09:45 AM
M5 London
M5 London's Avatar
Rear Main Seal perhaps ....
Also how good are you cabin air filter 90 degree bend connections, with the bulkhead ?
Good Luck
F06 M6 Gran Coupe 2015 - Imperial Blue Xirallic / Silverstone Merino
E39 M5 1999 - Carbon Black Metallic / Caramel Nappa Heritage Leather - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
E34 M5 1995 - Arctic Silver / Black Leather
E30 M3 1987 - Diamond Black Metallic / Black Leather
M5 London is offline
post #6 of 15 Old 17th February 2010, 10:10 AM
blackxs
blackxs's Avatar
Does it smell in the cabin? Or is it when you park and stop you smell it?
Sometimes after a long spirited drive if I get out I smell the exhausts I can smell a faint oil smell. I think these high-compression engines just do that. If you smell it when driving it may just need new cabin filters or to ensure they are securely connected. If there is oil that has dropped somewhere, it will burn and smell almost immediately, I doubt it will stay there and linger and burn and smell again every time you drive the car. Perhaps you have a minor oil leak dropping oil onto the exhausts, like others said I would drive the car and then check for leaks. What I would do is clean the engine thoroughly, then when you stop after some spirited driving, run a dry white towel around the block to check where the oil may be leaking from. By no means is this a very... professional way to test, but it is definitely a cheap and effective way to test for leaks and where the source of leaks may be.
Is it possible your VCG's were replaced with cheaper units that are not up to par and have started leaking again?
blackxs is offline
post #7 of 15 Old 17th February 2010, 12:25 PM
BlueThunder
BlueThunder's Avatar
Have you checked in front and below of the VANOS units? I had worn O-rings which resulted in oil slowly dripping out and onto various parts in the engine bay area. ie: hoses etc. The oil smell was evident, but the removal of the under-tray allowed me to pin-point the area in question and onto this board I went searching, and sure enough other members have had it happen to them also.
Good luck. You'll find it.
BlueThunder is offline
post #8 of 15 Old 17th February 2010, 02:49 PM
jclyman
In Memoriam
jclyman's Avatar
Buy a can of Engine Cleaner and FOLLOW THE DIRECTIONS.
If oil is dripping on "something" hot, it isn't likely to stop ... sure it will burn off in time, but NOT if it is still dripping.
- Daniel Boorstin
jclyman is offline
post #9 of 15 Old 17th February 2010, 04:28 PM Thread Starter
CU'09
CU'09's Avatar
Thanks guys I will try those ideas, it probably is time for new cabin filters so that can't hurt to do anyways.
CU'09 is offline
The Following User Says Thank You to CU'09 For This Useful Post:
post #10 of 15 Old 18th February 2010, 12:08 PM
100%Cocoa
100%Cocoa's Avatar
Are you certain it's leaking oil and not just oil burning in the combustion process? I'm just wondering if it's not just a completely normal side effect of hard acceleration. Most cars smell a bit of oil if you give them a good spanking, and my M5 more than any other I've had.
On the other hand, I've spilled oil when filling up, which has then dripped down the side of the engine, and you get a much more acrid smell coming into the cabin as it burns on the exhaust header. You also get a cabin full of seriosuly nasty smoke if you spill enough! (oops!)
Is it possible it's just normal?
100%Cocoa is offline
The Following User Says Thank You to 100%Cocoa For This Useful Post:
jclyman (18th February 2010)
Hesitates under hard acceleration stellastreet E39 M5 and E52 Z8 Discussion 3 13th June 2006 12:48 AM
Is this normal during hard acceleration? M5at E39 M5 and E52 Z8 Discussion 6 7th March 2006 05:15 AM
Supper strong Leather Smell.....Caramel Cars Only? Tim W E39 M5 and E52 Z8 Discussion 13 30th July 2005 10:18 PM
Strong sulfur smell after hard runs boostmiser E39 M5 and E52 Z8 Discussion 16 24th February 2005 01:22 AM
Missfire under hard acceleration Webby E39 M5 and E52 Z8 Discussion 16 27th June 2003 04:54 PM
