Emissions Situation - BMW M5 Forum and M6 Forums
Old 3rd February 2010, 05:29   #1
phaze1zo6
Garage: E39 M5
Emissions Situation
So I take the beast to a local gas station for an emissions test and it failed. The tech said the on board diagnostic computer is malfunctioning and not able to connect to his computer. He said he has had several BMW's with the same issue and it's most likely a software glitch that came from the factory that does not recognize any OBD scanner other than dealer equipment. He said he has experienced several that had it covered under warranty. So I called the dealer, they ran my vin and said there are no recalls or tsb's.
They said I would have to bring it in for a possible reflash.
Anyone had the same issue?
phaze1zo6 is offline   Reply With Quote
Old 3rd February 2010, 05:49   #2
TCM
TCM's Avatar
Garage: 2001 BMW M5 Silverstone/Black luxury and 2001 M5 Jet Black/Black Luxury
Run a search and you should find that there is a TSB for all 2000-2005 BMW M models for this very reason. The government's new software cannot connect with the older BMW ecu software. Hope this helps.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
TCM is offline   Reply With Quote
Old 3rd February 2010, 06:39   #3
ard
Super Moderator
ard's Avatar
Read this:
http://www.m5board.com/vbulletin/att...mer_letter.pdf
Not sure why the dealer doesn't see you car as needing a programming...maybe done already? Maybe lazy? Maybe they'd rather charge you 2 hours for "reprogramming"
What year is you car anyway?
The Following User Says Thank You to ard For This Useful Post:
phaze1zo6 (3rd February 2010)
Old 3rd February 2010, 06:51   #4
phaze1zo6
Garage: E39 M5
Originally Posted by ard View Post
Read this:
Thanks, its a 00. Could he really lie like that? Jeez!
Old 3rd February 2010, 07:48   #5
phaze1zo6
Garage: E39 M5
Is this why he said it's not covered?
"Failure to have this free repair work performed could be determined as lack of proper maintenance of
your vehicle and could jeopardize your full protection under the emissions warranty provisions."
Old 3rd February 2010, 08:11   #6
ard
Super Moderator
ard's Avatar
No.
First, did you get a letter? No. So you cannot be held liable for not doing something they never told you.
Second, who knows what the guy looked up. You can ask a dealer service group the same thing on multiple phone calls and get different answers each time...
Old 3rd February 2010, 08:29   #7
Bobbis1
Bobbis1's Avatar
Garage: 2001 Le Mans Blue M5
whats the bulletin date?
Bobbis1 is offline   Reply With Quote
Old 3rd February 2010, 08:32   #8
phaze1zo6
Garage: E39 M5
Ok, thanks.
My Lease Situation..... avi8tir E60 M5 and E61 M5 Touring Discussion 4 13th August 2008 20:20
Help with Sirius situation... seriously!! Skateparks E39 M5 and E52 Z8 Discussion 5 24th May 2006 23:35
M5 Supply Situation TX todo E60 M5 and E61 M5 Touring Discussion 3 4th September 2005 22:38
Job situation in the US Mardeth Off Topic Forum 2 24th November 2004 19:50
Odd situation GregC E39 M5 and E52 Z8 Discussion 5 6th August 2004 20:50
