13th January 2010, 20:12
#1
2003 M5 matte black
ABS sensor replacement front DIY
Remove wheel
Turn wheel to opposite side you are working on
Open plastic cover of connector and disconnect it.
Remove the cable from front strut.
Remove bolt(s) from wheel speed sensor(early versions have 2 bolts,later ones only one,5mm in hex socket,tightening torque 10NM).
Remove wheel speed sensor.
Clean insert hole in the strut.
Grease new sensor a bit and bolt everything down.Takes about 20-30 minutes...
-rebuild in winter 2011/2012
-"submarine edition",a bit boost and some M5 parts...
