Propshaft center bearing DIY with pics - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 12th January 2010, 22:54   #1
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Remove plastic undertray for gearbox.
Disconnect O2-sensors(mark them before removal) and disconnect EGT(exhaust gas temperature sensor) if fitted.
If the car has a one piece stock system,the whole exhaust system has to be removed.
Remove the heat shield for the propshaft.
Remove the nuts(16mm socket) on the Diff flange (replace with new ones tightening torque 70NM),mark the joint to the flange and pull the joint loose on the flange...
Mark the guibo and remove the three bolts(21mm socket) of the propshaft flange(new bolts and nuts,tightening torque 140NM)
Remove the nuts(13mm,tightening torque 21NM) of the center bearing while holding it in place.
Lower the propshaft on the center bearing,pull it out from the guibo,then from the diff.Do not let the velocity joint go in a too extreme angle to the propshaft,it could be damaged.
Mark the positions of both propshaft parts to each other.
Remove the bolt in the cross joint that holds both parts together(tighening torque 97 NM,use Loctite high strengh for assembly)
Pull the halves apart.Remove the shim infront of the center bearing.
Use claw puller or similar tool to remove center bearing.
Clean surfaces,new bearing slips in by itself.Don't forget shim when assembling.
For the new center bearing the Terostat sealant against vibrations on the chassis should be ordered( see parts catalouge).
Assemble everything,time for a beer....
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
The Following 14 Users Say Thank You to vantaam5 For This Useful Post:
5PEEDY (12th January 2010), ANiMOSiTY (29th November 2010), apetrov1x5 (23rd March 2012), ard (13th January 2010), CapeCodM5 (14th June 2010), chowdah (12th January 2010), Essixtytwo (12th January 2010), ger (30th September 2010), havasusteve03Beast (22nd January 2011), Katvis (13th January 2010), Mike S. (16th June 2010), Rocketracer (21st March 2010), TimInNOVA (22nd April 2010), Vector57 (22nd March 2010)
Old 12th January 2010, 23:02   #2
5PEEDY
5PEEDY's Avatar
You need to update your DIY links at the bottom of your signature.
However some might start to say your signature is getting too long, but I think it is a good thing.
Thanks!
5PEEDY is offline   Reply With Quote
The Following 2 Users Say Thank You to 5PEEDY For This Useful Post:
ard (13th January 2010), vantaam5 (12th January 2010)
Old 12th January 2010, 23:06   #3
vantaam5
vantaam5's Avatar
Thanks!
Good idea!
Then I should only remove the features of my beast in the signature,who cares about mods,anyway...
Old 12th January 2010, 23:11   #4
Essixtytwo
Essixtytwo's Avatar
Garage: 1998 E39 M5 Carbonblack
Again?? I'm liable to become a full fledged alcoholic following your DIY's....
Le Garage:
1998 E39 M5 (yes, that's right, going EXTREMELY strong and ZERO oil/rattle issues), Carbon Black/Caramel Full/Alcantara.
1985 E28 525i, Alpine White/Pacific, 12 yrs of ownership, DD during winter, most reliable car ever.
Essixtytwo is offline   Reply With Quote
Old 12th January 2010, 23:14   #5
vantaam5
vantaam5's Avatar
Only if you do all of them in a row maybe
Old 13th January 2010, 14:26   #6
vantaam5
vantaam5's Avatar
Will update this thread with changing velocity joint and the front bearing for the gearbox shaft in the prop shaft.
Ordered the parts yesterday and will tackle that down with pics next week.
Old 13th January 2010, 15:33   #7
1bad540
1bad540's Avatar
Garage: 2002 M5 Titanium Silver
Great write up! thanks
1bad540 is offline   Reply With Quote
The Following User Says Thank You to 1bad540 For This Useful Post:
vantaam5 (13th January 2010)
Old 21st March 2010, 20:55   #8
Rocketracer
Rocketracer's Avatar
Garage: 2001 M5 Le Mans Blue
excellent write up Vantaam, when i purchased my car the stealer told the old owner that it needed this bearing because of driveline vibes, and was quoted $500 for the labor, all it needed was a good wheel balance, so i saved 500
Rocketracer is offline   Reply With Quote
Old 21st March 2010, 23:54   #9
pimposh
pimposh's Avatar
Garage: E60 Sapphire Black
+1 great tutorial
i'm going to change my center bearing soon as it started to play annoying sounds...
pimposh is offline   Reply With Quote
Old 21st March 2010, 23:59   #10
vantaam5
vantaam5's Avatar
Send you a pm with my email!
If you could somehow help me out with that issue would be great!!!!!!!!!!!!
Rod Bearing DIY with pics inside vantaam5 E39 M5 and E52 Z8 Discussion 273 16th March 2012 18:46
Changing Rear Diff Propshaft Seal and Propshaft Bearing... pete_griff E39 M5 and E52 Z8 Discussion 12 29th December 2010 22:37
Center Bearing or Driveshaft michowen E39 M5 and E52 Z8 Discussion 18 23rd February 2010 16:27
Center support bearing B10 BT apbails ALPINABoard.com | BMW Alpina Discussion 1 29th April 2008 18:26
Giubo and center bearing replaced, now what... Larry's M5 E39 M5 and E52 Z8 Discussion 8 17th June 2007 20:51
