Propshaft center bearing DIY with pics - Page 4 - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 29th December 2010, 21:56   #31
stpotash
Garage: 2002 M5 silver
Driveshaft diy
Wish I would have seen this before I did mine on 02 m5! can anyone help I did not mark nut to shaft now what?
stpotash is offline   Reply With Quote
Old 29th December 2010, 21:58   #32
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
You mean you did not mark the two halves of the shaft?
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 30th December 2010, 21:22   #33
stpotash
pinion nut torque
No, I am refering to the pinion shaft to nut position.I lost my head did not mark nut to shaft before removal of pinion nut to replace rearend input seal.The shaft has a "+" and "2" ,the nut has an "m" scribed into it.Should I USE these marks or a torque value? Thanks for replying!
Old 30th December 2010, 21:34   #34
vantaam5
vantaam5's Avatar
Look in the other thread you asked,I replied there....
Old 22nd January 2011, 15:41   #35
Ribs
Ribs's Avatar
Garage: Individual e39 M5 Aegean Blue/ Champagne Leather
What sort of timescale are we looking at here? I don't have access to a lifter so looks like I'm going to have to take it to a garage and get it sorted for a £xx/hour rate..
Ribs is offline   Reply With Quote
Old 10th May 2011, 21:55   #36
olly22n
Garage: E39 M5 Silverstone Blue
would a worn centre bearing make a rattling noise? I have a rattle coming form this area and was wondergin whether the centre bearing could be my problem?!
olly22n is offline   Reply With Quote
Old 10th May 2011, 22:02   #37
Ribs
Ribs's Avatar
Mine turned out to be the bolts securing the centre bearing had become loose so unfortunately I paid a bit on labour to find out It didn't need changing! If you can jack yours up I believe from looking at other posts that you can just about get to the bolts if that is the case..
Old 10th May 2011, 22:10   #38
olly22n
INteresting. thing is the noise goes away after the car gets up to temperature - did yours do this?
Old 11th May 2011, 17:28   #39
Ribs
Ribs's Avatar
Hmm no.. I'm afraid I'm not sure what that could be then..
Mine rattled at low rpm.. As the shaft spins faster at higher rpm it's rotational force straightens it out (That's how I figured it anyway!)
The typical problem so I've heard is that the rubber round the top of the centre bearing wears away, leaving it vibrating on the body work.. But as mentioned above it was discovered that mine had already been changed.
I'd advise doing a search for it.. Useful information other people may want is mileage, maybe wether it rattles at stationary/ in gear etc.
Sorry couldn't be more help!
Old 13th May 2011, 17:33   #40
Mfreakin5
Mfreakin5's Avatar
Garage: 2003 M5 Le Mans Blue
So the only part that needs to be replaced is the "center mount" or number 7 on the Realoem diagram?
Has anyone ordered the full driveshaft and just replaced the whole thing? It's about $760 shipped from Tischer but it includes a Guibo and the CSB so its only an extra $550 and you save the hassle of having to press in/out the CSB and you get a fresh driveshaft and universal joints.
Thoughts?
Originally Posted by Greco View Post
...There seems to be less logic and more hot air in this white paper, maybe to sell more of his products...
White paper.... more like toilet paper.
Mfreakin5 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Rod Bearing DIY with pics inside vantaam5 E39 M5 and E52 Z8 Discussion 273 16th March 2012 18:46
Changing Rear Diff Propshaft Seal and Propshaft Bearing... pete_griff E39 M5 and E52 Z8 Discussion 12 29th December 2010 22:37
Center Bearing or Driveshaft michowen E39 M5 and E52 Z8 Discussion 18 23rd February 2010 16:27
Center support bearing B10 BT apbails ALPINABoard.com | BMW Alpina Discussion 1 29th April 2008 18:26
Giubo and center bearing replaced, now what... Larry's M5 E39 M5 and E52 Z8 Discussion 8 17th June 2007 20:51
