Clutch change DIY with pics - BMW M5 Forum and M6 Forums
Like Tree11Likes
Old 12th January 2010, 02:10   #1
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
For you,Peter!
These are pics from my beast when I changed the flywheel and rms 2 weeks ago.Also some pics from last weekend's clutch,rms and propshaft refurb of a boardmember's beast...
A car lift is very handy for this one,but it also works on jack stands(as seen in the pics)
First disconnect the battery.Remove both plastic undertrays.
Disconnect the O2 sensors(mark the connectors to plug them right together again).
Remove the exhaust(if you still have the original one piece from the manifolds back,congratulations,you need an extra pair of hands then!).
Also a thing to consider is to cut the exhaust after the resonators and connect it later with suitable clamps again(so at least the mufflers stay in the car).
Remove the heat shields that cover the propshaft.
Mark propshaft position to the diff flange and to the guibo and remove the nuts and bolts(new ones for attachment recommended).Bolts on the guibo 140NM tightening torque.
Remove the nuts from the center bearing of the propshaft and pull the propshaft out.
Disconnect the neutral switch and reverse switch.
Remove the wiring harness from the gear box and remove the rpm sensor.
Remove the clutch slave cylinder(now a good time to install a new one).
Disconnect the shifter rod(the support arm comes later when engine and gearbox are already lowered,is easier to get the pin of the support arm on the gearbox out then).
Support the gearbox(with a jack or a lifter if you use a car lift) and remove the gearbox support bolts from the chassis.
Use a flat pice of wood under the oilpan(important,otherwise the engine rests on the center steering linkage when it is lowered).
Lower slowly engine and gearbox(pay attention to the slave cylinder and the wiring loom that it won't be damaged.
Remove the pin of the shifter support arm.
loosene all bolts that connect gearbox and engine,including bolts for starter!All of them are Torx E12 exept the small ones on top of the gearbox,they are E11.A set of a few long and short extensions and joints for the ratchet is quite handy here!
After removing the bolts,pull the gearbox out(sometimes you need a large screwdriver to seperate engine and gearbox from each other and pay again attention that you don't destroy andy other parts or wires or lines while pulling it out.
Remove the pressure plate(tightening torque:25NM) and disc.
Change the throw out bearing(use the clutch grease on the sleeve),clean with brake cleaner new pressure plate and flywheel,if the flywheel has some heat spots,sand it a bit.Center the clutch disc and bolt down the new pressure plate(over cross,step by step),remove the locking plate from the pressure plate.
Put in gearbox and bolt down all removed parts.
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
The Following 25 Users Say Thank You to vantaam5 For This Useful Post:
5PEEDY (12th January 2010), allsmiles (12th January 2010), alquazi (14th February 2011), Beemer Guy (12th January 2010), Blue Angel (12th January 2010), chowdah (12th January 2010), DARK6mt (12th January 2010), deejaywasp (13th January 2010), doc$holliday (13th February 2011), doe (13th January 2010), Frye (12th January 2010), havasusteve03Beast (12th January 2010), herrubermensch (12th January 2010), JDMM5 (18th July 2011), Katvis (12th January 2010), KevinM (13th January 2010), KGNash (22nd November 2012), M-Alex (12th January 2010), Mike S. (12th January 2010), sbacchus (12th January 2010), sor118 (8th December 2010), t2ribena (12th January 2010), Terabass (12th January 2010), tranck (2nd April 2011), ur20v (12th January 2010)
Old 12th January 2010, 02:28   #2
vantaam5
vantaam5's Avatar
Changing flywheel and rear main sealing....
See the steps for changing the clutch.
There is a special tool needed(BMW part no:114180 ) or grind down a long Torx T60 by yourself for it.
I do not use the flywheel lock tool for it to block the flywheel,but one of the bolts that hold the tranny in place and a screwdriver on the teeth for starter.
Tightening torque of the bolts:105NM
Rear main sealing change:
Remove engine oil.
Remove the bolts that hold the cover in place and pull out cover with Sealing.
The sealing is quite easy to push out with hammer and screw driver.
To get the new sealing in,use a piece of wood and hammer it careful in.
Use a new gasket for the housing.
Tighten the M6 bolts with 10NM,the M8 bolts with 22NM.
The Following 18 Users Say Thank You to vantaam5 For This Useful Post:
5PEEDY (12th January 2010), alquazi (14th February 2011), blackxs (14th January 2010), chowdah (12th January 2010), Clemster (12th January 2010), doc$holliday (13th February 2011), havasusteve03Beast (15th February 2011), herrubermensch (12th January 2010), JDMM5 (18th July 2011), Katvis (12th January 2010), KevinM (13th January 2010), MasaK (14th December 2012), Mike S. (12th January 2010), Neil.D (12th January 2010), sor118 (8th December 2010), t2ribena (12th January 2010), Terabass (12th January 2010), Wisky (5th June 2010)
Old 12th January 2010, 02:39   #3
V8MPower
V8MPower's Avatar
Garage: BMW M5 [E39]
One question, in the signature indicates that it has "custom built X-pipe, but the pictures seem to have two separate tubes and no x-pipe, can confirm?
V8MPower is offline   Reply With Quote
Old 12th January 2010, 02:40   #4
balmo
balmo's Avatar
Garage: 01 E39 M5 Carbon Black
nice job! pretty straightforward. almost like a clutch job on my ae86 but im sure much heavier!
question, e39 m5 flywheel cannot be re-surfaced?
balmo is offline   Reply With Quote
Old 12th January 2010, 02:51   #5
Hdhntr23
Hdhntr23's Avatar
Garage: 2002 TiAg E39 M5
Sales Feedback: (13)
I believe in his OP he said it was a friends beast he was working on and thats what the pix are from.
Air Jordans for sale!! Size 13 << Click the link!!!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline   Reply With Quote
Old 12th January 2010, 02:54   #6
Chris_M5
Garage: 2000 M5 Titanium Silver, 2002 996TT Lapis Blue
Great write up! Thanks for all that you contribute to this board.
Chris_M5 is offline   Reply With Quote
The Following User Says Thank You to Chris_M5 For This Useful Post:
vantaam5 (12th January 2010)
Old 12th January 2010, 02:55   #7
vantaam5
vantaam5's Avatar
The exhaust pics are from the other beast.And the tubes are connected on this one also
But you can not see it because the angle of the two pics is bad.
Old 12th January 2010, 03:28   #8
Blue Angel
Blue Angel's Avatar
Garage: 2000 BMW M5-Gone but not forgotten
Definitely a great time to change the rear seals.
Its something a lot of people over look not to mention the part is cheap.
Nik
00 Avus Blue ///M5
98 ///M3
For sale: AC Schnitzer Shifter Knob: http://www.m5board.com/vbulletin/sal...-knob-new.html
Blue Angel is offline   Reply With Quote
The Following User Says Thank You to Blue Angel For This Useful Post:
Old 12th January 2010, 03:31   #9
vantaam5
vantaam5's Avatar
Even if the rms is not leaking I always change it with a clutch change.Is way cheaper to do it when you are there than pulling the whole stuff againwhen it fails.An half an hour more work and 40$ material do not matter then anymore,anyway!
Old 12th January 2010, 03:35   #10
Blue Angel
Blue Angel's Avatar
We need more write ups like these.
Chain tensioner change DIY with pics vantaam5 E39 M5 and E52 Z8 Discussion 101 15th January 2013 04:04
My first DIY Oil Change billrM5 E39 M5 and E52 Z8 Discussion 43 11th January 2008 02:01
DIY TPS Change?? Richbob E39 M5 and E52 Z8 Discussion 3 18th December 2007 21:06
DIY Oil change with pics. Jamie140 E60 M5 and E61 M5 Touring Discussion 14 6th April 2006 05:47
DIY oil change dick bergen E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 4 7th February 2002 04:19
