Chain tensioner change DIY with pics - BMW M5 Forum and M6 Forums
Like Tree7Likes
Old 12th January 2010, 00:53   #1
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Remove upper air filter box with MAFs and intake tube on Bank1.
Remove lower airfilter box,one screw(10mm socket) and the clamp for the tube of the intake funnel under the headlight.Push airbox towards engine to get it out.
Under the Vanos unit above the A/C compressor the screw for the tensioner is located(don't remember if it was 19mm or 21 mm socket,but you will see on the screw of the new tensioner which size it is).
A mirror is quite handy to get the socket on the screw head,otherwise feeling it with the hands works also well.
Put a towel or something like that on the A/C unit,a bit oil comes out when the tensioner is removed.
Bolt in the new tensioner and tighten it down with 50NM.
Assemble the air filter box again.
There will be a bit rattle from the chain for about 30 seconds until the tensioner is filled with oil.
Check for leaks and get yourself a beer
This is how the tensioner looks in all its glory,the aluminium crusher has to be ordered seperately.
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
The Following 26 Users Say Thank You to vantaam5 For This Useful Post:
5PEEDY (12th January 2010), alquazi (20th September 2010), atiyeh (3rd September 2011), bono (24th November 2010), CapeCodM5 (14th June 2010), chowdah (12th January 2010), CPI (9th February 2011), Don Incognito (14th June 2010), Frye (15th July 2011), Hdhntr23 (12th January 2010), Katvis (12th January 2010), klunk (1st October 2010), Leezamonkey (8th March 2011), M5 London (12th January 2010), meepmeep (25th October 2011), Mike S. (12th January 2010), Need4Spd (10th February 2011), pureretro (9th February 2011), saturnuranus (10th August 2012), sor118 (10th August 2012), steveM5 (13th April 2012), Terabass (3rd September 2011), Tiauguinho (12th January 2010), Vector57 (13th June 2010), wilsodh (12th January 2010), Wurger (22nd November 2010)
Old 12th January 2010, 18:34   #2
vantaam5
vantaam5's Avatar
The last pic shows how the tensioner has to assembled for installation.
The spring inside sometimes breaks and causes chain slap or even worse destruction as a few board members seem to have unfortunately experienced.
Costs about 150$...
Old 12th January 2010, 19:07   #3
Mfreakin5
Mfreakin5's Avatar
Garage: 2003 M5 Le Mans Blue
Thanks for posting this. So all you need to change this is the chain tensioner itself, part No. 11311406261 + 1 crush washer Part No. 07119963355? Together they're like $103 from Tischer, that's not bad....
Originally Posted by Greco View Post
...There seems to be less logic and more hot air in this white paper, maybe to sell more of his products...
White paper.... more like toilet paper.
Mfreakin5 is offline   Reply With Quote
Old 12th January 2010, 19:12   #4
vantaam5
vantaam5's Avatar
Yep,all that is needed.
Can save higher milage engines from expensive costs.Worth to consider,IMHO....
The spring aging also looses tension and rather changing it than having a broken chain guide or two....
Old 12th January 2010, 19:35   #5
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Define "higher mileage", if you would please Is this something that should be changed at 75K? 250K? something else?
d-
DouglasABaker is offline   Reply With Quote
Old 12th January 2010, 19:37   #6
Hdhntr23
Hdhntr23's Avatar
Garage: 2002 TiAg E39 M5
Sales Feedback: (13)
Nice write up.
Air Jordans for sale!! Size 13 << Click the link!!!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline   Reply With Quote
Old 12th January 2010, 19:46   #7
vantaam5
vantaam5's Avatar
d-
...I knew it!
Personally I would start to consider change at about 100k or so.....
Old 12th January 2010, 20:02   #8
DouglasABaker
...I knew it!
Thanks!
Every part has a useful life - just trying to figure out what they are for some of the lesser known ones
d-
Old 12th January 2010, 22:46   #9
jburnham
Garage: 540i/6 Topaz + 540iA Topaz
Timing Chain Tensioner Replacement (M62TU) - Bimmerforums - The Ultimate BMW Forum
Looks like it's the same as the M62, but twice the price
My only tip is to get TWO crush washers. They are a one shot deal. If it doesn't make a good seal the first time you put it in, it will drip until you get another crush washer. Ask me how I know |[
jburnham is offline   Reply With Quote
The Following User Says Thank You to jburnham For This Useful Post:
5PEEDY (14th September 2010)
Old 12th January 2010, 22:57   #10
vantaam5
vantaam5's Avatar
Looks like the same,but different part number than M62.
Chain Tensioner SteveT E34 M5 Discussion 13 20th November 2006 04:01
DIY Oil change with pics. Jamie140 E60 M5 and E61 M5 Touring Discussion 14 6th April 2006 05:47
Chain tensioner.. bay E34 M5 Discussion 27 5th April 2006 18:41
chain tensioner? Sebring NL E34 M5 Discussion 15 11th December 2005 20:01
Chain Tensioner TBrown E34 M5 Discussion 4 15th February 2004 11:27
