Brake pedal hard as a Rock! - BMW M5 Forum and M6 Forums
post #1 of 13 Old 9th January 2010, 06:07 AM Thread Starter
jsne39m5
jsne39m5's Avatar
I got in the car and the brake pedal won't move, and the brakes won't work. I let the car warm up and shut it off and same thing happened. I left it all day and it got above freezing (40 degrees), came home started the car and the pedal was firm then got softer and seemed sluggishly normal, I moved the car and it felt better, so I moved some more and drove. The brakes worked fine and then the problem came back after a little pumping. I had water get in the booster/master cylinder area after I had the fluid flushed. I tracked the car in Nov with fresh fluid with no problems. I got the water in before that. I drove the car last Sat night and everything was fine, didn't drive until Tuesday with three days below freezing, and now have this problem.
#1 Could moisture be in the booster and caused it to freeze?
My first thought is to get the system flushed Monday and go from there, any suggestions?
#2 Could moisture in the brake lines freeze and not allow fluid to move producing a hard pedal?
jsne39m5 is offline
post #2 of 13 Old 9th January 2010, 06:44 AM
blackxs
blackxs's Avatar
I think with extensive water in the lines it could easily freeze and resist movement.
blackxs is offline
post #3 of 13 Old 9th January 2010, 06:49 AM Thread Starter
jsne39m5
jsne39m5's Avatar
Also, The brake fluid does not appear to be contaminated or milky, but I hope it is just moisture and the flush will fix it.
jsne39m5 is offline
post #4 of 13 Old 9th January 2010, 06:55 AM
cab
cab's Avatar
I'm not sure if the M5 is the same as my wifes E39 530i (I'm just a prospective M5 owner), but in her E39 the brake booster is beneath the cabin fresh air intake box on the driver's side of the engine compartment. Remove that box and you will see the booster encased in a box of its own. This box can fill up with water when it rains if the 0.0000000000291 millimeter drain hole at the bottom (conveniently difficult to get to as it is under the booster) gets clogged up with debris. In my case that debris was decayed leaves, and one rainy night the brake pedal got hard and when pushed I got a squishy sound. Somehow the water had gotten into the booster itself (not sure how really). It ultimately stalled the engine and wouldn't start as it sucked water through the brake booster vacuum line. I had it towed home and was lucky enough to be able to remove the spark plugs, blow out the cylinders with some compressed air and all was good (I used the compressed air to blow out the drain hole too. If you got water in there and temps were below freezing it could have frozen...and then later thawed, etc.
Just my .02...
cab is offline
The Following User Says Thank You to cab For This Useful Post:
chowdah (9th January 2010)
post #5 of 13 Old 9th January 2010, 07:14 AM Thread Starter
jsne39m5
jsne39m5's Avatar
This happened to me also, but before I had the system flushed back in November. I am thinking there is residual moisture somewhere in the system and the cold temps have effected it.
jsne39m5 is offline
post #6 of 13 Old 9th January 2010, 01:49 PM
Essixtytwo
Essixtytwo's Avatar
My bet is on water in the booster too. Had this happen on an old style VW Passat, blocked drains. Booster had about 0.25L water in it, which would freeze at below zero temps, causing a rock hard pedal. Only thing to do about it is to replace the booster as the water attacks the metal housing, plate and spring inside) and include cleaning that drain plug mentioned above in your regular maintenance. I believe it's mentioned in the TIS too.
1999 E39 M5 Carbon Black/Caramel Full/Alcantara
Essixtytwo is offline
post #7 of 13 Old 9th January 2010, 06:15 PM
RichardP
RichardP's Avatar
I agree with water in the servo (booster). I had this and the brake pedal was rock hard, it also pulled itself on when braking so just touching the brakes caused an emergency stop!
RichardP is offline
post #8 of 13 Old 9th January 2010, 06:19 PM
kindanutz
kindanutz's Avatar
It's water in the booster... Below freezing it turns to ice and makes the pedal rock solid.... I've seen it a number of times... Good luck
kindanutz is offline
post #9 of 13 Old 10th January 2010, 07:52 PM Thread Starter
jsne39m5
jsne39m5's Avatar
Thanks guys, I am getting it to my indy tommorrow. I am going to see what they say since that cavity filled with water after they worked in that area. The water was dripping straight into it and not going out of the drain. We had a but load of rain last month here in AL (ROLL TIDE), and I got water in the back seat floor. This is how I found the source of the water leak. I would say at least 8 inches of water in that area around the booster. Great design to allow water in so easily with a drain hole the size of a pin! At least the rest of the car is well engineered and produces many grins!
jsne39m5 is offline
post #10 of 13 Old 5th February 2010, 12:40 AM
android604
Once the drain is unplugged, how do you get the water out of the brake booster? or is that just it, done?
Thanks,
Andrew
android604 is offline
I need it rock hard, but it is soft! Brad Simpson E34 M5 Discussion 2 24th April 2008 10:59 PM
Just changed Brake Pads. Brake pedal is REAL soft now..... Tim W E39 M5 and E52 Z8 Discussion 6 22nd March 2003 03:46 PM
OT: Is driving a car pedal to the metal hard on the engine, etc? kag E39 M5 and E52 Z8 Discussion 11 13th June 2002 10:24 AM
Mintex Brake Pads Rock! blue max E39 M5 and E52 Z8 Discussion 29 18th February 2002 11:10 PM
brake pedal travel Paul@M5 E39 M5 and E52 Z8 Discussion 1 7th June 2000 12:11 PM
