5th January 2010, 14:07
#3
E39 M5 Titan silver
Common problem cured very simply. The electronics constantly monitor the circuit resistances to see if the bulbs are OK. If the contacts are slightly corroded or the bulb is on it's way out then it will be fooled into thinking the bulb is faulty even if the bulb is working.
I suspect poor connections seeing as you have more than one bulb circuit misbehaving.
