O.E Reverse Camera Kit - Page 11 - BMW M5 Forum and M6 Forums
Old 18th April 2012, 16:53   #101
M5 Russ
M5 Russ's Avatar
Garage: BMW M5 v8
Originally Posted by Slippery View Post
I might take you up on that Greg, i live near Canterbury so not far away. Many years ago i used to work at Newmans BMW and left just before it became Broadoak BMW so i know most of the guys at Broadoak.
Richard thanks for that link its exactly what i'm looking for.
Russ can't believe you've had that camera kit sitting in the box for over 2yrs !
Simon.
I know. Its sitting next to a box that contains a full bluetooth kit that I have also had for around 2 years ! Thats another job to do as well as the illuminated door sills that I purchased a year ago !
It will all be fitted this year !
BMW E39 M5 - 2001 Le Mans Blue
Evolve equal length headers
Evolve high flow 100-cell cats
Evolve centre H pipes
Evolve GT rear exhausts with burnt titanium tips
Evolve AlphaN tune
AP Racing Brakes
Bilstein PSS9 coilovers
Uprated front and rear sway bars
Dinan strut brace
19" LM Reps
Intravee 2
Bluetooth upgrade
Mk 4 DVD sat nav
M5 Russ is offline   Reply With Quote
Old 9th May 2012, 17:14   #102
Reefin Dude
Garage: 540it Steel Blue
kevin300z-
to you still have a SoundGate's VIDBMW1V4 available?
thanks,
G~
Reefin Dude is offline   Reply With Quote
Old 13th May 2012, 06:05   #103
Reefin Dude
kevin300z- sorry for the delay getting back to you. i do not seem to have enough posts to reply to your PM's. i will see if i can be chatty somewhere.
does the SoundGate have stereo inputs for one of the inputs?
G~
Old 16th June 2012, 14:32   #104
StreetDragster
StreetDragster's Avatar
Garage: 2001 E39 M5 LeMans Blue
Just a quick question on this kit, i'm halfway through installing it.
The cable from the tail light to the control box in the bootlid, it has a green cable that seems to be separate in the loom in the boot, but in the bootlid it seems to be intergrated with the loom at the plug end, and then moves to outside the loom.
I've wired this into the 3rd pin of the tail light plug as instructed in the manual.
But the other other says this-
"Insulate Branch A2, GN Cable (Green), and tie it back"
Do I extract this cable from the loom at the control box, cut and insulate it? Why do you wire it in at one end, and then insulate it at the other? Is there a connection mid way in the loom or something?
StreetDragster is offline   Reply With Quote
Old 16th June 2012, 16:40   #105
RichardP
RichardP's Avatar
Garage: E39 M5, Carbon Black
Can't remeber exactly, but I think the wire you insulate and tie back is on the other part that goes inside the boot lid. I can double check if you're still unsure.
RichardP is offline   Reply With Quote
Old 16th June 2012, 17:55   #106
gregh86
gregh86's Avatar
Garage: M5 Sapphire Black
I've just looked at the instructions and if you have the TV option you tie it back and without the TV module you connect it to the tail light.
gregh86 is offline   Reply With Quote
Old 17th June 2012, 09:40   #107
StreetDragster
Hi Chaps,
GregH86 I'm afraid thats not quite right, section 9 says ""Insulate Branch A2, GN Cable (Green), and tie it back" which is the green wire at the control box which i'm talking about, and then section 10, step 10 says "Connect branch A3, GN (Green) cable, to the WS/GE cable from plug X319 (PIN3) using miniature connector 1" which is the tail light connection.
But looking at the table at the start, i think i should be cutting this wire in the boot lid, even though its connected, it must have some sort of joint in the middle of the loom so i'll do it, but do it in a place that's easy to repair if its wrong.
Thanks Guys
Matt
File Type: pdf e39 Backup camera retrofit instructions.pdf (795.2 KB, 116 views)
Old 17th June 2012, 10:26   #108
RichardP
RichardP's Avatar
You should not cut anything.
I'm pretty sure that the wire A2 is already loose, I think it's designed to tap into the reversing lights if they are part of the boot lid as in some other cars, X3 and X5 for example, with those cars you would tie back and insulate A3.
Old 17th June 2012, 10:32   #109
StreetDragster
That makes sense, i'll pull back the insulation and see if the green wire on the outside of the loom in the bootlid is connected to anything at the plug end. Standby
Old 17th June 2012, 10:50   #110
StreetDragster
Now i'm really confused.
The thick green wire, that runs on the outside of the loom, is connected to a thin green wire, that runs in the loom. This connection is at the plug end, as pictured....
At the other end, the thick green wire is terminated to the tail light, as described in the instructions. So where has the thin green wire gone? I can only assume the following from the diagram, do you agree that i should leave the wire uncut and as is? There is no mention of this thinner green cable anywhere, only the thicker 0.75mm one
DIY Guide - Wires to tap when installing a reverse camera and VSM... TorqueDog E39 M5 and E52 Z8 Discussion 11 9th May 2012 05:08
Anyone interested in OEM style back up camera kit? Kris@MMN E60 M5 and E61 M5 Touring Discussion 83 30th July 2011 05:07
Wanted to buy: Rear view camera kit OEM sidneyj Parts / Other For Sale or Wanted 0 26th December 2008 23:40
Picture: This BMW M5 Touring has reverse and front camera (BMW optional accessory) Gustav E60 M5 and E61 M5 Touring Discussion 6 11th December 2008 10:37
OT: Lookin for reverse camera ??? Pelle E39 M5 and E52 Z8 Discussion 4 5th May 2002 19:53
