M5 aerodymanic underbody panels - Page 2 - BMW M5 Forum and M6 Forums
Old 23rd December 2009, 15:43   #11
firebird400
firebird400's Avatar
Garage: Sold&missed - 2001 M5
Sales Feedback: (5)
I think this is an awesome idea. A lot of people don't realize how how significant a low drag underbody can be. I bet at high speeds (over 130 mph or so) the difference would be night and day between stability. Our cars already feel awesome at high speed, but I'm confident they can be improved upon a lot. Even a completely flat underbody would be a big improvement, but if you add in venturi's then you get into downforce. On race cars, the underbody can produce more downforce than those huge wings you see. Go for it!
2001 ///M5 - SOLD
Eisenmann Sport | Supersprint headers | SuperSprint X-pipe | Ground Control | Stoptech ST-40 front brakes | Powerchip | Rogue 280mm clutch | JB Racing lightweight flywheel | Rogue short shift | Dinan rear Swaybar | OEM 9.5" all around with Star Specs | Cosmo Racing CAI | Opened brake ducts
firebird400 is offline   Reply With Quote
Old 23rd December 2009, 16:23   #12
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Originally Posted by PedM5 View Post
A while back there was a guy who got the fastest stock E46 M3 pass in the quarter mile when the car was relatively new. He did so by taking the seats and tool kit, and all the extra weight out. He even went so far as to use the valet key instead of the regular key. What difference does it make on its own? Who knows, but every little bit helps. When you do rolling starts on the freeway, high speeds come fast and just like people put lightweight batteries in their M5's to get that little bit of help, so shall I seek a way to get an underpanel that will aid the aerodynamics of my car so it can cut through the air more readily. Without going in to too much detail, anything over 165mph sounds like you are in a tornado, you really see that power can only get you so far before aerodynamics halt your acceleration. There are people who remove their side mirrors for drag racing purposes, all I'm after is to replace my stock piece with something a little more appropriate for my needs. Please don't turn this into a "why drive fast" thread, I have a modded M5 not a 528 and furthermore, I would probably not be around if I tried to hit 200mph on a daily basis. Every now and then I line up with a car that is just so close to me in speed that I had to think about what might be holding me back. Regardless of opinions, my search will continue
I think my point is, try doing the more tried and tested performance gain methods before tackling your underbody panels with the aim of improving downforce and/or reducing drag....
Please keep us posted on your findings !
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 23rd December 2009, 16:33   #13
kindanutz
kindanutz's Avatar
Garage: 03 M5 Jet black
it is very nessesary to have the belly pans on the M5.... not only does it aid in aerodynamics but it also is a very imperitive piece in controlling underhood temps as well as coolant and oil temps... the belly pan is designed to creat a vacuum and pull out hot air and aid in pulling in cool air from the kidney grills... if you leave it off while driving around you will notice oil and coolant temps alittle higher then normal... try it... good luck!!
kindanutz is offline   Reply With Quote
The Following 2 Users Say Thank You to kindanutz For This Useful Post:
jclyman (23rd December 2009), m5 deamon (23rd December 2009)
Old 23rd December 2009, 16:39   #14
m5 deamon
m5 deamon's Avatar
Garage: 2003 e39 m5 carbon black on black sport interior
good point also if you look at the belly pan of our cars it also directs air to the transmisson for cooling
2003 m5 Carbon Black, Black sport interior,
Evolve stage 3 Alpha N with power tune buh bye pc93 tune
Evolve cold air intake
Evovle heads with shrick cams
Raikku Modded Throttle Bodies
SS Headers going to make the jump to evolve headers real soon as soon as a certain some one on this board buys them lol you know who you are!
Zionsville Radiator with spal 2 speed fan
UUC Light Weight Fly Wheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmission mounts
Steel braded clutch line
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braided brake lines
Dinan rear sway bar
Dinan rear stress bar
Custom built M5 front stress bar
Tc sway bar brackets
Stop tech St 40
Kw v3 suspension
Rouge blue control arms
Ground control camber caster plates
L I custom Adjustable sway bar links front and rear
Predator ice v3 angel eyes
Bimmian black kidney grills
VVME xenon 4300k fog lights
Solaris amber bulbs
led lic plate lights
Exotics tunning rear cf finned diffuser
Vorsteiner front splitters
v1 hardwire
m45 blinders updated version
Slimbones xl foglight covers
Euro tail lights with rear fogs hooked up
Bsw Stage 1 with there subwoffer package
Alcanterra shift boot and ebrake boot from leather z
Alcanterra ebrake handle from a m3 csl
Illuminated zhp shift knob
Alcanterra custom wrapped steering wheel
Custom interior orange led in door pockets and handles
To Come... Evolve headers and race cats, this list seems to be shrinking!
m5 deamon is offline   Reply With Quote
The Following User Says Thank You to m5 deamon For This Useful Post:
Old 23rd December 2009, 16:53   #15
sor118
sor118's Avatar
Garage: 2002 Carbonic Blackalicious M5
Sales Feedback: (4)
Perhaps I'm over simplifying the manufacturing process but I don't see how this can be that difficult to achieve. You could use a large piece of cardboard as a template, find areas on the underside that you can tap into for securing the final product, source suitable lightweight but rigid material, and use the template to make the final piece.
Ya, that is way too simple. You also have to take into account air flow to the components that would be covered up like exhaust, rear diff and create air channels just like the OEM cover has to the tranny. Shouldn't be too hard right?
It sounds like a good challenge to come up with something but I would have to wait for warmer weather before tackling anything like this. Don't take this post as me volunteering to do this for everyone like Timmay is doing for his custom exhaust tips though!
2002 Carbon Black BMW ///M5 (Black Extended Leather, Anthracite Alcantara, Titanium Trim, M-Audio with Enhanced Bass, PDC)
Conforti Shark Injected with M5Board Tune, CMS Custom Muffler Delete with OE Tips, AFE Pro Dry S air Filters, ACS rep CF Front Splitters, Flat Black Kidneys, Open brake ducts with Flat Black Brake Duct Rings, Stainless Steel Braided Brake Lines, Shorty Clutch Stop, Lighted ZHP Knob, Custom Pure White Angel Eyes (Predator Ice housing and Rebel Tri-Star LED's driven by PowerPucks), Umnitza V4 ION License Plate Lights, Fogs color matched to HID's, Oil Pan Pad Heater for winter, 3M Clear bra on hood, Flat Black Style 65's on Nitto NT555's, Style 66's on Conti Extreme WinterContact's for the other 6 months, Interstate MTP-H9 Battery, Sybesmas remaned rearview mirror, Boomerang Espion Alert LoJack, MKIV Nav with 2010 maps.
http://www.cardomain.com/ride/2964057/1
http://www.bmwmregistry.com/detail.php?id=7570
sor118 is online now   Reply With Quote
Old 23rd December 2009, 18:44   #16
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Now we are talking about one of my favorite topics!
Sorry,what you wrote is completely wrong!!!!!!!!!!!!!!!!!!!!
The last thing you want under the car is hot air(given its density you reverse the downforce effect)!The M5 has no openings to "suck" away the hot air from the engine bay!This is why race cars have openings in the hood to release the air from the radiators and engine bay!Why do you think hot air is on race cars always tried to get it above the car or on the side of the car?
The closed undertray the M5 has is as efficient as it can be made in a large production car.
The only way to make it more efficient would be to add side skirts and a real diffusor(I am not talking about that bolt on stuff for the bumper that is sold,this is only optics and nothing else).I am talking about a diffusor that starts with fins in bottleneck style(Venturi effect,to accelerate the air) at about the middle of the rear axle.
Downforce is about channeling and accelerationg airflow to create a "vaccum" under the car.
Then also getting away the hot air out of the wheel arches starts getting an issue(see race cars).
All these mods have to be tried in the wind tunnel,otherwise it is only a waste of time,money and resources...
And then you still have a 1.8 ton heavy pig that will be maybe with these mods and a pro driver .2 seconds(if) faster on the track...
As I stated,The M5 will never ever be a real race car,no matter how much money and time you invest!
The best you can get out of it is having a "track toy" and nothing else!
But before starting with all that aerodynamics,money is better invested in suspension and brake parts and semi-slick tires......
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
The Following 2 Users Say Thank You to vantaam5 For This Useful Post:
jclyman (23rd December 2009), Rhino (23rd December 2009)
Old 23rd December 2009, 19:50   #17
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
This whole conversation is interesting, but ultimately pointless without a wind-tunnel. Does anyone have one of those laying around that we can use? Because trust me, the theoretical design and the real-world design are not the same for something like this. You simply cannot model the underbody aerodynamics of our cars unless you are the mfg OR have a crapload of time to put into building a full 3-D CAD model. And even then... you need a wind-tunnel to prove your design.
The manufacturing process is not the hard part of this equation. Creating something that is better in practice than the stock body panels is the hard part...
d-
DouglasABaker is offline   Reply With Quote
Old 23rd December 2009, 19:59   #18
vantaam5
vantaam5's Avatar
It is not only pointless without a wind tunnel,it is also pointless for this car!
The Following User Says Thank You to vantaam5 For This Useful Post:
jclyman (26th December 2009)
Old 23rd December 2009, 20:40   #19
firebird400
Sales Feedback: (5)
d-
I have access to a small wind tunnel at college Would be cool to find a scale model and do some testing
Old 23rd December 2009, 21:06   #20
JohnAnthony
JohnAnthony's Avatar
Garage: Silverstone
you can't squeeze your car in it?
anyone have a scale car they want to donate? ... E39 M5 scale models NEW!
JohnAnthony is online now   Reply With Quote
UnderBody Panel kosmo E39 M5 and E52 Z8 Discussion 2 11th August 2008 14:46
UnderBody Panel kosmo E39 M5 and E52 Z8 Discussion 1 10th August 2008 20:22
Underbody panels-How to tighten kosmo E39 M5 and E52 Z8 Discussion 3 17th June 2008 10:31
Cracked underbody plastic bob barringer E39 M5 and E52 Z8 Discussion 11 24th May 2006 22:57
Neon underbody lights AFRM5 Off Topic Forum 12 2nd April 2005 00:07
