is this alternator or alternator belt? - BMW M5 Forum and M6 Forums
Old 18th December 2009, 14:13   #1
DARK6mt
DARK6mt's Avatar
Garage: 2001 E39 M5 Jet black
I noticed last night when I was showing my car for the first time to a friend. He recently traded his 335 for 530 (baby on the way) and was very very depressed
anyhow so I am showing him everything about the beast and we turn on the courtesy light to show him the interior of the car then notices the light is kinda dimming every 3 second intervals.
Right away I remember the sound at the engine bay which is like a hiss sound, that I thought was the serpentine belt, is most likely alternator belt and even worn pulley?
Met with member here name Striker, nice guy!, and his car didnt have the hiss sound of my car so its def abnormal.
thanks to the board
james
DARK6mt is offline   Reply With Quote
Old 18th December 2009, 15:31   #2
Strike
Strike's Avatar
Garage: 2002 Jet Black
Hey James - it was good to meet you. Two things I'm thinking you could do to check this out. If you've got access to a multimeter, set it to volts and put the probes on the connections used to jump-start the car. You should be able to read the battery voltage from there. If not you'll have to put the probes on the battery terminals in the trunk. When the car is off you should have about 12.6 volts. When at idle it should read between 13.5 and 14.5 volts. If it's lower than that, the alternator may be failing.
Another guick thing you could do to check it is locate the alternator and spray a small amount of WD-40 or rust penetrant on the bearing behind the pulley. If it makes that light whistle go away chances are the bearing is failing and that's the cause of that noise we heard.
2002 Jet Black/Imola Red Sport
Dinan Stage I Software
K&N Filters - Brake Ducts
K40 Undetectable
AXXIS ULT pads
Black/White CF Roundels
Body Color Grills
Greyscale ///M Logos
Smoked Tails
30% Tint
Intravee II
Strike is offline   Reply With Quote
The Following User Says Thank You to Strike For This Useful Post:
DARK6mt (18th December 2009)
Old 18th December 2009, 16:26   #3
DARK6mt
DARK6mt's Avatar
Thanks Scott, I will try that this weekend since the snow is coming I will be stuck at home. Although I will be tempted to try driving her like grandma, um... bad idea with summers on ay?
I will let you know the results regarding the voltage and after the quick spray, need to find the diagram so you can pin point exactly where I should spray.
btw, great seeing you last night, we should have a philly M5 mini meet!!
james
Old 18th December 2009, 16:47   #4
Strike
Strike's Avatar
I'm down for it - I know there are several in the area.
I say go for it. If she's not going to be garaged and will be exposed to it anyway you should definitely take it for a ride. One of the UK members just posted about his first snow drive. I only worry about the other people on the road, never myself. I used to be a strong opponent of electronic driving aids, in fact, this is the first car I've ever owned that has ABS because I used to be so strongly against that sort of stuff. That said, you've gotta experience just how good the DSC can be. Leave it on and drive normally in the snow, at reasonable speeds of course, and you'll be amazed at how it does its job. You can literally feel it correcting you if you push too hard, really quite impressive.
Cracks in alternator/water pump belt... sdietric E39 M5 and E52 Z8 Discussion 6 11th May 2009 22:01
Alternator belt N2OCapri E34 M5 Discussion 2 8th January 2009 19:51
Alternator belt change - advice - workshop manual images? M5_blues E34 M5 Discussion 7 16th October 2007 13:28
used alternator m5 atlien2422 Parts / Other For Sale or Wanted 0 14th January 2005 05:41
Alternator Mmm-Five E34 M5 Discussion 10 17th October 2004 22:28
