BBK Install, Check! Early Morning Stoptech Brake Pad Bed-In, Check! IATS relocation, Check! - BMW M5 Forum and M6 Forums
Old 18th December 2009, 01:49   #1
jmlag
jmlag's Avatar
Garage: BonitaBeast '03 M5 Schwarz II/Caramel
So I picked up the ride yesterday after having the ST-40 front BBK installed. Initial observation was that the pedal engaged a lot earlier than stock (Maybe I was in need of a bleed with the stock brakes). Otherwise I couldn't really tell much difference because I couldn't really apply the brakes much until the bed-in
....Which brings us to the bed-in procedure. After months of reading Dave Z's Bed In procedure for new brakes, pads, rotors, etc I finally got try it out for real!
The first time I applied the brakes in the first cycle was kinda scary because the car didn't really want to stop.... After the 3rd and 4th, it started braking a little stronger. I noticed you really need "feel" the brake as you step otherwise the ABS will come on (which is something you do not want to happen during bed-in). The brakes didn't fade even after the 8th slow down.
After a full cool down of the brakes from the first cycle, I moved on to the 2nd cycle of stops. Midway through the second series of stops I noticed a much better feel and the brakes were coming on much stronger. Again, I didn't notice any fade even after the 8th slow down.
I may have to do one more cycle but I think I'm good to go!
The IATS relocation kit seems to be working fine. I put mine inside the passenger side brake duct. During this morning's run, ambient temperature didn't go more than 4 degrees celsius from the external temp.
Pics to follow
The Stable:
2003 DINAN E39 M5
2003 MB G55k....KLEEMANNIZED!!
BMW CCA NJ #416647
Mostly stock......looking
The Other Stable:
2012 Indy Fab Ti FLW
2011 Indy Fab Ti FLW MTB 29er
2007 Indy Fab Steel Deluxe SS 29er
1990 Gary Fisher Advance SS
jmlag is offline   Reply With Quote
The Following User Says Thank You to jmlag For This Useful Post:
jclyman (18th December 2009)
Old 18th December 2009, 02:38   #2
LFC09
LFC09's Avatar
Garage: CarbonBlack E39 M5
The IATS install was simple, yes? I still have mine sitting on the bench to do, the bit about tapping wires puts me off, as I am sure a quick job will turn into a longer one.
2002 M5 Carbon Black
Black/Grey leather
Brushed Aluminium trim
AiB 3.0 angel eyes
AiB xenon match fogs
BMW 545 shifter
Dinan rear sway bar
TCD rear sway bar brackets
X5 4.8 thrust arm bushings
Bimmernav Bluetooth upgrade
phone cradle V3xx modified
Solaris invisi-bulbs
MkIV Nav V31 custom splash
ex 1959 FC Holden sedan
LFC09 is offline   Reply With Quote
Old 18th December 2009, 02:50   #3
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (4)
Yes. It's a no-brainer. The instructions are very good, as are the various DIY pieces on the board.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
herrubermensch is online now   Reply With Quote
The Following User Says Thank You to herrubermensch For This Useful Post:
LFC09 (18th December 2009)
Old 18th December 2009, 02:53   #4
jmlag
jmlag's Avatar
The wiring of the IATS was actually the simplest part of install. There are a few threads on here with pictures of the actual wires that need to be cut and spliced which helped a lot.
IATS install, threw code 4d - Intake Air Temp Sensor
The most time consuming part was removing the bumper, drilling the hole in the brake duct and securing the sensor to the duct (Some people can do this in 5 minutes flat). While I was down there, I also cut out holes in the left and right plastic coverings on the front of the wheel wells so that air could flow to the brakes like in the euro M5's. At the same time, I drilled holes in the mesh grill on the bumper to let the air in from the front. I also ordered the proper plastic ducting to better direct the air from the bumper into the wheel wells. Again, there are a few posts on here that helped me out a lot. I need to take some pics and post them.
Old 18th December 2009, 03:01   #5
LFC09
LFC09's Avatar
No excuses now!
Old 18th December 2009, 03:26   #6
ard
Super Moderator
ard's Avatar
I never hear that ABS activation must be avoided!
Do tell....
Old 18th December 2009, 11:10   #7
jmlag
jmlag's Avatar
Do tell....
How to Bed-in Your Brakes - a knol by David Zeckhausen
Taken from the instructions above:
"Make a series of eight near-stops from 60 to about 10 mph. Do it HARD by pressing on the brakes firmly, just shy of locking the wheels or engaging ABS."
I'm guessing the instructions are trying to ensure a steady uniform pressure applied to the pads and rotors when doing the slow-down. When ABS is activated, the brakes are actually getting a series of short quick brake applications instead of the strong uniform pressure that's needed.
Old 18th December 2009, 18:08   #8
ard
Super Moderator
ard's Avatar
Huh... I just never paid attention to ABS and if it was activating or not... In my mind all I needed to do was superheat pads and rotors. Personally I don't think activating ABS is a problem. (Assuming you are on clear/quality roads.) What you definitely want to avoid is coming to a full stop with pads in contact with rotor when they are hot.. so after bedding, you need to drive for a while before hitting any stop signs or lights....
Thx
A
The Following User Says Thank You to ard For This Useful Post:
jmlag (19th December 2009)
Old 18th December 2009, 20:42   #9
herrubermensch
Sales Feedback: (4)
Thx
A
+1.
Old 19th December 2009, 01:27   #10
jmlag
jmlag's Avatar
Thx
A
Good to know. At least next time I don't have be so careful as I was and baby the pedal....
Maybe I could do another cycle for good measure? Maybe that's why I didn't experience any brake fade? Did I not heat them up enough?
Check engine light & check side lights? emma5 E39 M5 and E52 Z8 Discussion 5 19th February 2009 21:13
Need help, VIN check/ BMW service check MrMCoupe E39 M5 and E52 Z8 Discussion 0 9th July 2008 17:02
MAFs-- check... Spark Plugs--- check... gherardini E39 M5 and E52 Z8 Discussion 10 26th January 2008 19:12
Check out Britney's BBK beastunleashed Off Topic Forum 1 27th January 2006 06:30
How to check CHECK ENGINE lamp plisken E34 M5 Discussion 4 11th May 2004 02:41
