18th December 2009, 00:02
#3
2003 M5 matte black
Sounds like you have either a broken clutch slave cylinder(usually they die before the master cylinders) or some broken springs on the pressure plate of the clutch.Mechanic should pull out slave first and see if it is leaking(2 nuts 13mm wrench on gearbox).
Good luck!
-rebuild in winter 2011/2012
-"submarine edition",a bit boost and some M5 parts...
