14th December 2009, 23:11
#1
2001 M5 Jet Black
Gunmetal or Silver
2001 ///M5 Jet Black on Caramel / Alcantara
Dinan CAI, Dinan Rear Sway Bar, Dinan Front Strut Bar, Dinan Exhaust, Dinan Brembo GT BBK 355mm Front - 345mm Rear, Evolve Alpha-N Tuning, Walbro 255HP fuel pump,
Ground Control Coilovers, Evolve "Medusa" headers, Magnaflow Cats, SuperSprint X-pipe, Magnaflow 10416 resonators, Beastpower Rear Sway Brackets, Gulf Oil Filter Housing w/ Fluidyne Cooler,
Custom Fluidyne Power Steering Cooler, Linea Corse Z2S 19" wheels w/ Continental DW tires, EVO U/D Pulleys, Reinforced Rear Subframe, Diff Viton O-rings,
RaceSkids Metal Underbody Panels, Custom Leather/Alcantara steering wheel door panels and front seats, 35% window tint, Valentine One Hardwired, ACS style splitters,
E60 SSK and ZHP Knob, "Shorty" clutch stop w/ start sensor mod, Carbon Fiber Wrapped Interior, BSW subwoofer kit, Competition 6.5" front speakers in custom baffles,
DICE/Intravee II iPod adapter, TEC Cupholder, E90 radio knobs, AC and USB powered plugs installed in center console, Full LED overhaul in cabin/footwells/trunk
DIY Accelerator Pedal Removal
My Custom covered steering wheel
My plug-n-play LED light upgrade
DIY adding AC and USB power outlets
DIY fix squeaking steering wheel adjustments
Shadow Chrome: A closer look
$6 DIY headrest in-car camera mount
M5 DIY for Dummies
14th December 2009, 23:17
#2
2000 m5 silverstone
Go with silver for the contrast.
14th December 2009, 23:24
#3
2003 M5 matte black
Also like the silver better!But you have to get happy with it!
Or paint them shadow chrome like the stock ones?
-rebuild in winter 2011/2012
-"submarine edition",a bit boost and some M5 parts...
14th December 2009, 23:45
#4
Anthracite M5
Silver. Gunmetal can look nice, but if you have curb rash or bend the wheel (not sure how unlikely in your case), then you'd need to repaint the whole wheel. If we're talking about gunmetal as a hyper color, that is.
Fighting Oil Threads since 2007
15th December 2009, 00:26
#5
2001 Carbon Black M5
From my understanding, both colors offered are either hyper gunmetal or hyper silver IIRC.
I had dark wheels before on my Carbon Black, and now have hyper silver wheels. Although the hyper silver does look nice I do prefer a dark wheel on my CB. But that's my personal preference. Go DARK
2001 Carbon Black ///M5
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete
Custom Software Tune
Bilstein PSS9 Coilovers
Ground Control Camber Plates
BBS CH in Custom Satin Black
Hankook Ventus V12 255/35/19, 275/30/19
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser V1
SLIMM Front Splitters
SLIMM 3.5" Fog Light Air Ducts
SLIMM OEM Euro Armrest
15th December 2009, 01:12
#6
2001 M5 Jet Black
VMR's site never mentions "hyper gunmetal" so I don't think it is. Diny, why is hyper such a PITA?
M55555, I currently have black wheels with chrome lip. I do like dark, but am curious what others think.
15th December 2009, 01:19
#7
Anthracite M5
Whereas most paint is just one color, hyper is for "hyper reflective." This gives the surface a metallic look without the "sparkle" of regular metallic colors like paint used on the chassis of our car.
The way reflective works is with a black undercoat (normally powdercoated) and then the silver is applied on top. The less silver that is applied, the darker the gunmetal is (I'm slightly hazy on that one part.....it may be darker the more paint applied, I'm not 100% sure). Still, imagine if you need to only paint a little bit of the wheel: You gotta lay down a patch of black and then blend that, and then blend the silver over it. It's impossibly impractical to do simple "patch jobs" with hyper colors.
Also, there is a risk of not having paint distributed evenly. It will look fine at first glance, but the flaws will become quite evident once the wheel starts turning. It'll look as if the wheel is dirty (uneven highlights and shadows). This is because, when the silver coat is applied, it is applied by hand by the painter. Small fluctuations in temperature, paint spray pattern, and just the way the painter paints means that the paint is not 100% evenly applied. It normally isnt a problem with most paints, but it is evident with hyper reflective colors. This is not a problem out of the factory because the paint is applied by machines that are programmed down to the millisecond with very precise angles of spray, stable environments, etc, etc.
I know all this because I went through the trouble of having 4 rims painted in a hyper color and had trouble with all 4 wheels being the same color first and, when they all matched, I saw the uneven paint when seeing my car rolling down the street (my father was driving it).
The Following 2 Users Say Thank You to Diny For This Useful Post:
16th December 2009, 19:25
#8
2002 m5 silver
silver looks better on black
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
