9th December 2009, 18:41
#1
2k M5, Imola Red
Driveline vibration getting worse....Had BMW check, they dont know!
Ive already searched but cant find the symptoms I'm having. My car starts vibrating in 3rd gear under any rpm all the way to 6th, and keeps vibrating until about 90-100mph where it backs off. Shakes my visors, and I can feel it strong in my butt! It doesnt do it under braking, and I cant feel it through the shifter or steering wheel. Ive checked and replaced my flex disc/guibo (just replaced my clutch), replaced tranny bushings, sway bar brackets/bushings and just had my tires balanced. It seems like it gets worse going around corners under throttle/ accelerating. One of my back rims was bent when I had them balance them. they said they balanced out. I also just replaced all 4 rotors and pads (started well before, so i know they're not bent) and all 4 cps.
Car has 80k on it.
Could this be:
bad wheel bearings
Drive shaft
Thrust arm bushings
9th December 2009, 20:03
#2
Moderator Emeritus
Car has 80k on it.
Could this be:
bad wheel bearings
Drive shaft
Thrust arm bushings
If you press the clutch in, does it go away?
9th December 2009, 23:32
#3
E39 M5 - Titanium Silver
A friend of mine had a vibration in a E36 325 turned out to be the flywheel. It needed a new one as the balance had gone. I have no idea why though.
10th December 2009, 00:07
#4
Alpine White E39 M5
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_0 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7A341 Safari/528.16)
Could be your rear wheel still. I've had bent rims that balance out initially but a day later they are out of balance again. Also check tires for a shifted steel belt.
2003 E55 AMG - Obsidian Black/Black, Eurocharged ECU reflash, 84mm SC pulley, CM30 IC Pump, FTP Heat exchanger, Needswings Dual CAI, Custom exhaust, Forgestar F14's, Lowering links, E63 Spoiler, CF Front lip
2000 BMW M5 - Alpine White/Silverstone Extended Leather/BBS LMs 245.35.19, 285.30.19/Evolve Alpha-N/Tubi Exhaust/AA Intake/Ducts/Dinan Springs - RIP
2001 Yamaha R6 - Yamaha Blue, Yamaha GYT-R Exhaust, Factory Pro +4 Ignition Advance, Factory Pro Jet kit, 03R6 Airbox/Filter, Clear Alternates and fender eliminator, puig windscreen, Yamaha Solo seat, APE CCT
2000 Durango SLT+ - 5.9 V8, 3.92 LSD, 32x11.5 BFG All Terrains, Airaid intake, Hughes F1 Airgap, SCT Tuner, Flowmaster 50 Series, Fully rebuilt 46RE, 2" torsion lift
Glock17 9x19|Vz.58 7.62x39|Mossberg 500
10th December 2009, 16:27
#5
2k M5, Imola Red
E55AMG2:
Not all the way but it gets better.
It does it more accelerating/constant speed. Goes away a bit slowing down in gear.
Jt2ma71:
Took it back to the tire shop where it was balanced at, they told me Belt seperation on my back tires. That may be true, but why would it get better slowing or w/ clutch in?
10th December 2009, 16:59
#6
Moderator Emeritus
E55AMG2:
Jt2ma71:
That means it isnt in the driveline, it's likely your wheels. Is there anyone local you could swap rears with to test it out? I would help, but you're 2 states away.
10th December 2009, 17:27
#7
M5 2002, LeMans Blue
any leaks in the driveline like near the Diff?
is the guibo ok?
if you have the original bushings replace them
you have to get a new tire anyway so have them roadforce balance the new one.
I've had all these done + got new wheels but there's still some slight vibration at speed.
good luck.
2002 M5 Lemans Blue
10th December 2009, 17:38
#8
Super Moderator
Wouldn't the tire manufacturers DEFECT warranty (NOT MILEAGE warranty) cover such a defect? If a qualified tire shop tells you the tire is defective, and there is a warranty, and they are an authorized rep for that tire...well...
A
10th December 2009, 19:09
#9
2k M5, Imola Red
Ill check to see if I can replace them under warranty.
Too bad there is no one close to see if diff. rear wheels would fix it.
Guibo is new, all seals new/no leaking, replaced tranny bushings....
10th December 2009, 19:21
#10
Sold my baby!
Is it worse when the car is cold? Does it come and go at all or is it always there?
2006 Lexus LS430 (my old man car)
2009 Acura TSX (wifey)
2002 M5 Carbon Black/ Caramel lightly modded (gone - SOLD to board member)
Biding my time for another M...
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
