Old 7th November 2009, 20:46   #1
oltarmac
oltarmac's Avatar
Garage: m5 99 silverstone blue
e39 m5 brake problem..please help!
hi,
ive been having an annoying re occuring problem that i thought i had finally solved. left hand speed sensor front. so after replacing the abs sensor twice,my mechanic discovered that underneath the oil filter housing the wires had "chaffed" through,this was due to the oil filter housing being snapped off its brackets.
so tonight i collect the m5 and straight away when i brake the pedal is pulsing up and down,but no lights.so i ignore the problem..then on the motorway i give it a bootfull,bang, on come the lights.
the lights are now back out again but the pedal is pulseing.
any ideas??
oltarmac is offline
Emergency brake problem tranck E39 M5 and E52 Z8 Discussion 6 20th March 2008 18:23
Brake Problem? 2002m5BGM E39 M5 and E52 Z8 Discussion 2 21st March 2007 00:12
New Brake pad Problem! jeshie7 E39 M5 and E52 Z8 Discussion 4 20th October 2005 22:21
Sticky brake problem?? baldy_bonce E39 M5 and E52 Z8 Discussion 0 12th March 2005 19:08
Brake Bleeding Problem rango E28 M5 Discussion 1 25th June 2002 03:52
Page generated in 0.10199 seconds with 11 queries
