Old 6th November 2009, 20:11   #1
CU'09
CU'09's Avatar
Garage: 2001 LMB M5
Strange Whine When Shifting
I recently had the clutch, guibo disk, and center support bearing replaced. My clutch pedal has become MUCH lighter and I now have a strange whine when I shift gears. It seems to happen as I shift the lever out of one gear but before I engage the next gear. I am going to change my transmission fluid to Royal Purple and see if that quiets it down but the sound is fairly concerning. Any ideas on what this could be?
CU'09 is offline
Old 6th November 2009, 20:27   #2
Leezamonkey
Leezamonkey's Avatar
Garage: BMW M5 E39 Avus Blue
i have a very faint whine too, not sure what clutch I have though, i think it is standard, it still bites very good, no slipping at all. sorry to say I'm not gonna be able to help you but I'm interested to find out what this is too!
Leezamonkey is offline
Old 6th November 2009, 20:31   #3
CU'09
CU'09's Avatar
Garage: 2001 LMB M5
I have the Luk clutch from Pelican Parts, says its OEM. It has good bite although I have not been rough with it as I am still breaking it in. It is concerning/annoying to hear a little whine when shifting around town though.
CU'09 is offline
Old 6th November 2009, 22:35   #4
CU'09
CU'09's Avatar
Garage: 2001 LMB M5
I have done searches for this issue but could not find any related threads. I don't want to keep driving if the problem could lead to transmision damage. It doesn't seem normal to have this noise. Any ideas on the cause?
CU'09 is offline
Old 8th November 2009, 21:55   #5
CU'09
CU'09's Avatar
Garage: 2001 LMB M5
Has anyone ever heard a whine when shifting gears? Could it be synchro related?
CU'09 is offline
Old 9th November 2009, 00:47   #6
///msaleem
///msaleem's Avatar
Garage: bmw 2002 M5
is it something like this
YouTube - 99 bmw 528 first gear issues
///msaleem is offline
Old 9th November 2009, 04:11   #7
CU'09
CU'09's Avatar
Garage: 2001 LMB M5
Sort of but it happens as I pull the lever out of gear and its very brief. A faint, quick, high pitched whine. Cold shift from first to second is crunchy. Im going to replace the tranny fluid with RP Synchromesh and see if that helps. Anyone experienced similar sounds?
CU'09 is offline
Old 9th November 2009, 05:19   #8
Randy Ray
Garage: 2000 Black M5
It could be the throw out bearing, does the whine go away with the clutch depressed???
Randy
Randy Ray is offline
Old 9th November 2009, 05:53   #9
CU'09
CU'09's Avatar
Garage: 2001 LMB M5
I will play with it some more but I just had the clutch replaced which should have included the throw-out bearing. The clutch is in when I do this as the noise is present just as Im shifting out of gear.
CU'09 is offline
My M5's SMG transmission is shifting very rough among other strange things CaliJames E60 M5 and E61 M5 Touring Discussion 15 18th September 2009 12:40
Whine at 70/80mph M5 AHU E39 M5 and E52 Z8 Discussion 1 18th March 2008 03:48
Strange whine during acceleration/cornering Mark_m5 E39 M5 and E52 Z8 Discussion 13 10th September 2006 07:46
Strange starter problem and even more strange explanation from dealer intense321 E39 M5 and E52 Z8 Discussion 12 12th February 2004 23:18
m5 whine markburns E39 M5 and E52 Z8 Discussion 8 3rd January 2002 21:44
Page generated in 0.10042 seconds with 11 queries
