Old 7th November 2009, 05:48   #41
Randy Ray
Garage: 2000 Black M5
No I would just polish them up with mothers polish, If you get all the finger prints off before you put everything back together, they won't tarnish bad.
Randy Ray is offline
Old 7th November 2009, 05:54   #42
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (3)
So it won't oxidize? Do you think I might be able to get away with not clear coating the aluminum? I have one of those vintage copper fire extinguishers and...well, actually I have 2. One of them is polished and clear coated and flawless. the other one is polished but not clear coated and it needs to be polished every now and then or else it starts to turn dull and green.
Cristian
Anthracite///Black
For Sale: Sumitomo HTRZ III for 19s
For Sale: 2 GoPro Motorsports Wide Cameras
Diny is offline
Old 7th November 2009, 06:03   #43
Randy Ray
It will 50 years from now. but a good coating of polish will last years, especially since once you put it all back together you won't be touching them and adding any contaminant from cleaners or oils off of your fingers. I would put them back in the lathe.....spin them up to 2000-3000 RPM polish with mothers mag wheel polish and a soft cloth (will look like chrome) and wipe off with thinner after assembly.
Will look good for years.
Randy
Old 7th November 2009, 06:09   #44
Diny
Diny's Avatar
Sales Feedback: (3)
Randy
Will that only work with mirror-finishes? I want the brushed look that I have going on. can I use the same treatment or will the brushed look give me trouble?
Cristian
Anthracite///Black
Diny is offline
Old 7th November 2009, 06:19   #45
Randy Ray
For a brush finish you use scotch brite (I like the maroon\purple grade) and leave it just raw metal, once again clean it with thinner last step to remove oils ect. If your are really worried about it shoot a light coat of krylon clear from a spray can usually seals it pretty well......but getting things to stick to raw aluminum is difficult without a zinc primer first......I would just leave them raw.
Randy
The Following User Says Thank You to Randy Ray For This Useful Post:
Diny (7th November 2009)
Old 7th November 2009, 06:23   #46
Diny
Diny's Avatar
Sales Feedback: (3)
Randy
That is good to know. I'll give them a run with the scotch brite before cutting them off the main piece in the lathe.
Cristian
Anthracite///Black
Diny is offline
Old 7th November 2009, 16:54   #47
Randy Ray
Polish them up and deburr them with the lathe.....but for a brush finish it will look better if you apply the finish so to speak by hand
with the scotch brite on a table and kind of swirl the part in a circular direction. Keep playing until you get the finish you desire, brushed
finish really means you are not getting rid of all the scratches. You also might try pin pointing a small piece of scotch brite and spinning it with a pencil eraser in small circles right next to each other.....this will give you the multi swirl look you see on dashes and such. Just keep playing until you get the look you desire, if up you screw up put it back in the lathe for a quick polish.....and try again.
Hope this helps, and you understand my ramblings...
Randy
Old 7th November 2009, 17:25   #48
Diny
Diny's Avatar
Sales Feedback: (3)
So you're saying to polish them up to a mirror finish while still on the lathe and then go to town with the scotch brite when they're off?
Cristian
Anthracite///Black
Diny is offline
Old 7th November 2009, 17:34   #49
Randy Ray
Yes this will give you the most uniform finish.....I know putting scratches back on the part.....that's why mine will be mirror finished, and I don't think I will put any spot drill points on mine, just a pretty shinny ring.
Have fun.
Randy
piston rings? springer454 E39 M5 and E52 Z8 Discussion 8 22nd February 2009 09:13
Want to buy Gauge Cluster - Or just the black gauge graphics - from 2000 M5 Diny For Sale or Wanted 4 28th January 2009 19:06
Help! I need hub rings for these... [Source for hub-centric rings for BBS RX wheels?] kirbanana E39 M5 and E52 Z8 Discussion 11 30th December 2007 16:43
two intake rings swingkat420 E39 M5 and E52 Z8 Discussion 11 6th May 2005 19:16
Chrome gauge rings Mr Blitz E39 M5 and E52 Z8 Discussion 6 9th October 2001 18:19
Page generated in 0.10685 seconds with 11 queries
