Old 4th November 2009, 19:43   #1
czarmar
czarmar's Avatar
Garage: '02 M5 Jet Black
What will new vanos seals/new splines do for me?
Does the O ring kit that Dr. Vanos sells for our cars help out the ticking problem or the rough running problem?
I think I have both issues and I'm trying to eradicate both of them. Dr. Vanos also sells a splined gear that is supposed to solve the ticking problem, do people have experience with the modified spline gears to be able to recommend them in order to quiet the engine?
Are there issues for which no CEL is thrown, and no OBDII code is found but the Peake will find a specific BMW code that will direct me to my problem? I have a generic OBDII reader, and I'd consider buying the Peake, but I'd like a more full featured PC based diagnostic tool that could do some data logging and maybe some more advanced diagnostics such as a cylinder power balance test. Any recommendations? My guess is the GT1 will do everything the Peake does and more - is there anything feature wise between the Peake and the GT1?
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Last edited by czarmar; 4th November 2009 at 20:01. Reason: trying to get Youtube video to embed #2
czarmar is offline
Old 4th November 2009, 21:05   #2
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silverstone/black interior
I don't think it's the ticking problem the new VANOS solve - they decrease the 'deisel' kind of sound. - 'Ticking' - can be a lifter, or god forbid - a rod...
your video sounds normal to me...
Rough running - look at the MAFS...
MarkQC is offline
Old 4th November 2009, 21:47   #3
czarmar
czarmar's Avatar
I've read the horror stories about rod bearings, but I'm pretty sure I don't have it. The vid I posted is not the best quality, but it captures the noises I'm hearing. Since it is a cheap, easy & recommended fix; I think I'll do the vanos solenoid seals and report back with before/after video.
czarmar is offline
Old 4th November 2009, 21:57   #4
vantaam5
vantaam5's Avatar
Garage: 2003 M5 black
Bit rough running,like Mark mentioned,but just Vanos noises.....
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Schroth 4-point harness
-Castrol SRF brake fluid
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
-CAI with ram-air ducts
-custom built X-pipe
mods not yet in:
-Custom built headers
-custom built adjustable DSSR in T6
-Drexler differential stock ratio
Rod bearing DIY: http://www.m5board.com/vbulletin/e39...cs-inside.html
Vanos solenoide removal:http://www.m5board.com/vbulletin/e39...des-video.html
vantaam5 is offline
Anyone do their own diff seals? nightkrawler E39 M5 and E52 Z8 Discussion 5 1st September 2009 15:50
Thanks to Josh, Chad, Mike, Shadowman, & AllSpeed… What its all about [El Diablo vanos seals] wilsodh E39 M5 and E52 Z8 Discussion 25 5th May 2008 08:32
Door Seals ... ateles E60 M5 and E61 M5 Touring Discussion 14 25th August 2007 20:53
Problems w/Vanos system (After Vanos lise replaced) patq E60 M5 and E61 M5 Touring Discussion 10 23rd March 2006 09:42
Seals richardDG ALPINABoard.com | BMW Alpina Discussion 1 6th February 2002 00:27
Page generated in 0.09583 seconds with 11 queries
