Old 4th November 2009, 00:10   #1
jmitdesign
jmitdesign's Avatar
Garage: M5 Carbon Black
Send a message via AIM to jmitdesign
Optimal way to do an electronic exhaust cut off?
Hey guys,
Not looking to debate how loud these cars should be, etc. Just looking for the optimal set up for exhaust cut offs. I have heard the two options are:
- Put an H-pipe before the secondary o2 sensors and install 1 cutoff. Better back pressure apparently?
- Install two separate cutoffs right before the mufflers?
Any opinions on what is the better option? Both are probably equally expensive as the labor is probably more intensive on option 1, but the valves are more expensive on options 2. Thanks guys
Jeff
jmitdesign is offline
Old 4th November 2009, 00:13   #2
drdre0728
drdre0728's Avatar
Garage: e39 m5 black
Haha Jeff this post also goes for me. Im thinking about doing the same thing. Talked with Theo about it last night.
drdre0728 is offline
Old 4th November 2009, 00:52   #3
Cantresjr
Cantresjr's Avatar
Garage: M5 LMB
I believe if you do option 1 it would give you a code since you will be bypassing the )2 sensors.
I have been thinking of doing this. the way i would do it is- two cutoff after a X pipe before the mufflers, around the area were the factory resonator would be.
which cutoff are you thinking of using?
Cantresjr is offline
Old 4th November 2009, 01:02   #4
jmitdesign
jmitdesign's Avatar
Hahaha nice Andrei! We should go together and drop off the beasts hahaha.
So doing it after the 02 sensors would throw a code? Did I write that wrong? I really have no idea what it looks like underneath the car unfortunately or what the stock setup looks like. Google images isn't really helping me either. Just figured someone must have done this before anyway and probably has a pretty good setup. Any real back pressure issues if its done before the mufflers? Summit has a cutoff package for 200, two cutoffs, gaskets, y pipes, etc. Probably doesn't matter to much with brand right?
Old 4th November 2009, 01:58   #5
Cantresjr
Cantresjr's Avatar
Garage: M5 LMB
Originally Posted by jmitdesign View Post
Put an H-pipe before the secondary o2 sensors ? Jeff
from the front of vehicle you have- exhaust manifolds to primary O2 to cats to secondary O2 to a lame Hpipe to resonator to mufflers.
if you put a valve "before" the sec O2 i believe you will throw a code.
Old 4th November 2009, 04:29   #6
jmitdesign
jmitdesign's Avatar
Ahh Gotcha. I think I meant to say after. I guess take out the lame H pipe and put a real one in that can have a valve on it? Does it not matter?
Electric exhaust cut out on E39 M5? acecar E39 M5 and E52 Z8 Discussion 2 17th August 2009 20:54
Where to cut factory exhaust? WildAZ E60 M5 and E61 M5 Touring Discussion 8 21st April 2009 06:45
Electric Exhaust Cut Outs Mavallone713 E60 M5 and E61 M5 Touring Discussion 14 19th November 2008 04:30
Optimal tire pressure? mmm6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 18th July 2006 16:41
What is the optimal outside temperature for ///M5 performance?? B-Pac E39 M5 and E52 Z8 Discussion 7 15th February 2003 08:46
Page generated in 0.09700 seconds with 11 queries
