1st to 2nd gear shift.... - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 36 Old 21st October 2009, 11:57 PM Thread Starter
NJ.M5
NJ.M5's Avatar
I'm sure some of you will find this offensive, but my beast is my first manual car. I think I have gotten very good at driving stick, watching the old training videos in the FAQ and judging by the engine pitches and smoothness of the ride.
But my 1st to 2nd shift is still a little shakey. I saw another thread about this but shifting in to second isn't always as smooth as the other gears. There are times where I have the clutch pushed in and I will hear a quick grind when shifting from 1st to 2nd. Do I need to change my tranny fluid? I've never done this before and put about 7000 miles on the car since purchase. Is this an easy job?
Anyone else have the same troubles with 2nd gear? Seems to be worsened by the cold, but not sure.
NJ.M5 is offline
post #2 of 36 Old 21st October 2009, 11:59 PM
HarvesterOfBeer
HarvesterOfBeer's Avatar
Yes, second is often somewhat harder to get the stick into on my car as well. Sometimes it feels like 2nd and 3rd don't have fully functional synchros.
HarvesterOfBeer is offline
post #3 of 36 Old 22nd October 2009, 12:05 AM
blackxs
blackxs's Avatar
You may be relieved to hear that the Beast was also the first manual car I have owned The problem is probably your pressure plate. I have a feeling we both probably messed ours up a little bit in the intermediary process of getting accustomed to stickshift, and furthermore - adjusting to the very finicky clutches of our cars.
For further help on your thread please visit this thread:
Please help, trouble shifting off cold start
blackxs is offline
post #4 of 36 Old 22nd October 2009, 12:07 AM
Diny
Diny's Avatar
The M5 is also my first manual car. I learned on it and I didn't need to replace the clutch
But yea, I noticed that if you aren't in "sync" with the car, you can engage 2nd gear and get the car to do a hell of a shaky acceleration. There's also a lot of notchiness from 1st to 2nd, but this goes away by shifting at higher RPMs (4k, for example) and once the transmission is warm.
Fighting Oil Threads since 2007
Diny is offline
post #5 of 36 Old 22nd October 2009, 12:16 AM
DouglasABaker
DouglasABaker's Avatar
Here's the thing with our cars: Because they are high horsepower/torque, the synchros must be able to withstand the torque/hp associated with higher rpms. As a consequence, at lower rpms, the synchro's simply don't work as well.
There are 2 solutions to this problem:
1. Shift very quickly. If you don't let the engine rpms drop too much then you'll get smoother shifting. The longer you wait between shifts the better job you need to do modulating the rpms through gas pedal.
2. Shift at higher rpms. You'll still need to shift quicker, but the synchros will work better because of the higher hp/torque.
With all that said, you may have damaged your synchros but I'd be surprised if you did any damage to your clutch or pressure plate...
d-
DouglasABaker is offline
The Following 4 Users Say Thank You to DouglasABaker For This Useful Post:
blackxs (22nd October 2009), Busta (22nd October 2009), Jacob_Seattle (22nd October 2009), LoCalM5 (22nd October 2009)
post #6 of 36 Old 22nd October 2009, 12:18 AM
blackxs
blackxs's Avatar
Diny, isnt yours also significantly lower mileage? I am at around 90K now on the original clutch! Its overdue anyways...
blackxs is offline
post #7 of 36 Old 22nd October 2009, 12:20 AM
JohnAnthony
JohnAnthony's Avatar
you should let first run a little longer, don't just put your foot in it to go into the next gear
like the others said - your synchros are getting worn and youll need more inertia to ease their load
JohnAnthony is online now
post #8 of 36 Old 22nd October 2009, 12:23 AM
Diny
Diny's Avatar
I got mine at 60k and am now at 97k, 2 years later.
This isn't the original clutch, though. People before me beat the hell out of the clutch and (if my mind serves right), this is the 5th clutch that my car's seen. I'm the 3rd owner, too. I know that the clutch was changed a lot at first because I checked the service records.
Diny is offline
post #9 of 36 Old 22nd October 2009, 12:24 AM
HarvesterOfBeer
Right! As usual the answer is: flog it!
post #10 of 36 Old 22nd October 2009, 12:30 AM
blackxs
blackxs's Avatar
d-
I gotta ask, on point 1... at low speeds I find going into second its better to shift a little slower because when I shift really fast, the engine revs are higher than the wheel speed so it grips, bites, and shakes the car (very unsmooth shift) and thats when I hear the grinding. If I clutch in, shift, pause, clutch out - the revs fall and the engine speed matches the wheel speed, minimizing syncro wear (which is what I thought was going on) and the grinding is much more quiet. Are you telling me that by doing what makes it quieter and smoother is actually damaging my car? If so - boy howdy I am gonna start shifing much faster!
Also, my local indy said I was damaging my pressure plate. How would I have damaged the syncros? These transmissions are pretty beefy from what I understand, and the whole point of syncros is to alleviate wear is it not? Forgive me if this is a stupid question, I am just thirsty for knowledge I really dont want to mess up my syncros and have to get a new transmission for 4K since there is no rebuild for these...
5th clutch! My goodness, thats one every 20K miles or so! Hopefully yours will last longer, it certainly sounds like you know how to properly take care of it even if the previous owners did not...
blackxs is offline
m5 smg wont shift in 2nd gear endri sallata E60 M5 and E61 M5 Touring Discussion 12 31st January 2011 02:48 PM
Engine torque limiting in 1st/2nd gear? 4rotor E60 M5 and E61 M5 Touring Discussion 9 24th August 2006 03:28 PM
New Clutch grabbing hard in 1st & 2nd gear Goody4 E39 M5 and E52 Z8 Discussion 6 19th November 2005 11:37 PM
herky jerky shift from 1st to 2nd m5tackulous E39 M5 and E52 Z8 Discussion 28 8th March 2005 10:38 PM
1st to 2nd gear shift still rough? M Power E39 M5 and E52 Z8 Discussion 9 17th July 2003 02:18 PM
