1st to 2nd gear shift.... - Page 3 - BMW M5 Forum and M6 Forums
 1Likes
post #21 of 36 Old 22nd October 2009, 01:17 AM
gsfent
gsfent's Avatar
Originally Posted by blackxs View Post
Talking about upshifting to 2nd. I let the revs fall an extra second depending on what rev I left first gear. This prevents any nose dive or bucking and the car moves like silk. Its only when I shift FAST that I get that bucking motion. For example, if my normal shift takes 1.5 seconds, I wait another .5 seconds during my shift from 1-2.
That should work fine. The 1-2 shift is notchy on our cars, and this is NOT my first clutch. I find that I either have to be slow (and when cold I actually pause in the neutral gate for a split second), or do it quickly AND firm. This is not like a Toyota (no offense) but there are some pretty beefy gears and synchros as noted above to handle the power. So firm and quick works well for me. Kind of like showing it who is boss.
[qoute]
I no longer feel comfortable downshifting to second - it bucks too much, even seemingly when revs are matched perfectly I feel a harshness in the driveline. Its either syncros or the pressure plate banging around from the rev and downshfit. Thats why I dont downshift to 2nd anymore - I hit 3rd and if that wont cary me through, into N I go![/QUOTE]
Try the older style of double clutch downshifting. 3-2. That means blipping the throttle and going to neutral, then blipping again and slipping it into second. If you are still getting grinding, there is something wrong. The double clutch downshifting should take (almost)all the load off the synchros, depending on how well you do it. Doing it right, you won't even feel the gearchange.
Bucking is different then grinding; if the car is "bucking", it is not synchros.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is offline
The Following 2 Users Say Thank You to gsfent For This Useful Post:
blackxs (22nd October 2009), Vector57 (28th October 2009)
post #22 of 36 Old 22nd October 2009, 01:48 AM
DouglasABaker
DouglasABaker's Avatar
Ok Jerry, I've been driving stick for a long time, know what double-clutching is, and I'm still confused by your sentence "Try the older style of double clutch downshifting. 3-2. That means blipping the throttle and going to neutral, then blipping again and slipping it into second." so I can imagine the new guys are as well.
The traditional double-clutching is the simple repetition of engaging and releasing the clutch pedal after the car is out of gear while holding the engine at the appropriate speed, but not through blipping. The idea being to get the input shaft (driven by the engine and controlled by the throttle) to spin at the same speed as the gears (which is driven by the wheels and therefore turning at a constant speed) before putting the transmission in gear.
The part I don't understand is how blipping the throttle will help while double-clutching? I blip when I downshift to rev-match, but I'm shifting very quickly and I'm already in neutral.
Secondly, I'm really confused about blipping the throttle before going to neutral. The engine is already spinning at the speed as the gear he is in, so blipping the throttle seems like it would be counter-productive. Neutral -> blip -> release & re-engage clutch -> blip -> shift seems like it might work if the clutch work and the shifting were performed while the revs were up and the blips both took the engine to the same speed.
Not trying to be critical, just trying to better understand the suggestion - I don't double-clutch since I find it cumbersome, but perhaps that is because I do it wrong?
d-
DouglasABaker is offline
post #23 of 36 Old 22nd October 2009, 02:21 AM
blackxs
blackxs's Avatar
Originally Posted by DouglasABaker View Post
What you are describing sounds to me as if you are not releasing your foot from the gas until after the clutch is depressed.
Not to sound condescending, the shift process looks as follows:
1. Release gas
2. Depress clutch
3. change gears
4. Release clutch
5. Engage gas
These are sequential steps. No portion of these should be done in unison unless you have a desire to put in a new clutch and/or transmission. Note that it is entirely possible that you may need to push the gas during step 3 if you shift too slowly as the revs may fall to quickly, but this should only be performed between steps 2 and 4, not during. In case it isn't clear, pushing the gas pedal during steps 2 and 4 is "slipping the clutch" and will shorten its life.
So, with all that said, if your revs aren't falling fast enough, then odds are good you aren't releasing the gas before depressing the clutch and in the process you are damaging your pressure plate. Unless you are lightning quick, which isn't likely for a new manual driver, you should not have this problem (I've been driving stick forever and I still can't shift quickly enough to have this issue).
The synchros are there to match the speed of the input (engine) and output shafts - if shifting quickly causes a clunk you may already need to replace them.
d-
I do understand how to shift (that process you noted) but to be honest there has been some times where I have noticed that as I put the clutch in, I didnt let off the throttle fast enough, and this slips the clutch from what I understand and if you say this hurts the pressure plate then that would explain why my pressure plate is damaged. There was one instance where I didnt let the clutch hook up before giving throttle again, and the revs rose without moving the car anywhere. This is slipping the clutch, correct? It happened once or twice. At the very least, I may not be the best working a clutch but I definitely do know when I am doing damage so in both instances where I did that, I quickly pushed the clutch in and went to Neutral and then rev-matched back into a gear. I think that slipped the clutch and wore the pressure plate. I have not done this for a very long time, both times I did it were some of the first times I was getting on the gas and revving it out (which is why it took so long for me to feel comfortable enough to redline my car again)
With that being said, there have been times where I have had the clutch in too long (while shfiting something happened so I brake and leave clutch in, etc..) but I do understand how important rev-matching is. I think you may be right that I am not letting off the gas quick enough but I also have another theory..
lets say in 2nd gear at 20mph you are @ 2600 revs.
first gear will take me up to lets say (all these numbers will be totally incorrect - I am just discussing theory) 20mph at 3500 revs
i go to shift to second really fast, but by the time it comes to let the clutch back out - i am only at 2800 revs and i get a "buck" if i let it out
so what i do to correct this, is hold the clutch in another moment, let it fall to 2600 revs (revs matched) and then let the clutch out. this way, it is a smooth shift.
that is what i am talking about. there are often times where i even make sure i let off the throttle early before pushing the clutch in that it doesnt seem the revs fall fast enough on their own.
I hope this is an example, because 1.5 seconds to shift is about 1.25 seconds longer than it should take you...
d-
Yes, I can shift rather quickly - I just didnt want to say .25 second shift and have someone go "no way anyone can shift that fast" ...so i just used a number. I really have no idea how fast I shift but I can get that gear knob moving pretty fast...
Just that moment pause in the neutral gate is how I correct it. I will try the double-clutch downshift into second sometime. When I downshift though I normally heel-toe it/just single clutch it (throttle out, clutch in, shift gear, throttle blip, clutch out, throttle). heel toe is obviously for slowing down while downshifting whereas single clutch (though heel toe and single clutch are the same i use the term to differentiate conditions in which they are used) I use for just cruising when I want to get going a little faster I throw it in a lower gear and get on it
d-
i am confused about this as well. the only benefit i could possibly see is if it took a significant amount of time for the revs to climb (ie by keeping revs up you dont spend as much time revving it to match it - you just tap the throttle, tap the throttle - and you are at your desired rev range instead of doing the clutch, getting into N by which point your revs are at idle and THEN having to really rev it to your desired rev speed) but that doesnt make sense since our Beasts rev pretty damn quick
Thank you all for your advice so far, this has been very helpful to me (and hopefully OP lol). Dont think I am a terrible driver... these mistakes I am discussing here are some of the only ones I really have made. I do get the jist of manual driving, and I understand the importance of rev-matching, I just dont understand what to do in absolutely every scenario that is presented to me.
I have a question not related to me for you experts out there. My buddy drives a GTI and often times he will put his car in N before a turn, then clutch in - set gear to 2, wait until after the turn, then rev-match and let the clutch out. is this damaging his car? what else can he do (he also has a notchy second, and third gear and doesnt like to downshift into it)
blackxs is offline
post #24 of 36 Old 22nd October 2009, 03:53 AM
gsfent
gsfent's Avatar
d-
Thanks Doug. After rereading, I didn't get it exactly right!
Put car in neutral, (stick in neutral, clutch out) THEN blip throttle while clutch is out, then clutch in, then blip again and the gear should snick right in. I was not taught to hold throttle at a set point and put in neutral, clutch in, clutch out, clutch in, move gear lever. It is actuallly harder to think about how I do it and write about it then just do it.
Of course, maybe Skip Barber teaches it differently because the Formula Fords they used have no first gear synchro, and the entire chassis flex will upset the ability to do smooth shifts. Holding the throttle at a particular point may work, but I would think the longer you hold the throttle at one point with no load, the harder it will be to keep the revs close to the range you want for the downshift. The engine will keep revving.
In any event, thanks for catching the timing error.
gsfent is offline
post #25 of 36 Old 22nd October 2009, 03:59 AM
gsfent
gsfent's Avatar
I
Single clutching is fine.
But I think your timing is off. I believe it is throttle out, clutch in, throttle blip, shift gear, clutch out....
The lever moves the gear, the clutch simply keeps it from engaging. So if you move the lever, the gears are trying to line up, although the clutch hasn't been released yet.
I could be wrong, but my order works for me!
gsfent is offline
post #26 of 36 Old 22nd October 2009, 04:14 AM
TMcNasty
TMcNasty's Avatar
Back on topic here:
Changed Transmission and Differential Fluid today [Pictures]
I just posted on pg. 2 NJ. Lemme ask you...was your 1st-2nd better when it was summer? My car always shifts nice until it gets cooler out then I have notchy shifting until the tranny fluid warms up. I said 'F' it and went to the Royal Purple yesterday because rumor has it that solves the problem. Hard for me to confirm though because it was warm yesterday. I need a nice cool night to confirm.
The fluid change is actually pretty easy.
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline
post #27 of 36 Old 8th January 2015, 06:31 AM
3point0cs
like a few of you on the thread the m5 is my first manual car as well. this has not only been tremendously helpful but has provided a great deal of relief as well. cheers!
3point0cs is offline
post #28 of 36 Old 8th January 2015, 07:37 AM
68FB
Relief because you found it was pretty normal the M5 first to second gear shift is crap with cold oil, regardless of the oil?
I store mine over the winter and I'm kinda glad I do because that shift is not cool.
There was a thread on here featuring owners with ultra low mileage M5's a while back. I should have asked them how the 1-2 shift was below 5C.
68FB is offline
post #29 of 36 Old 8th January 2015, 08:01 AM
MAZI
Amazed that Some of you guys have "learn" to drive "stick"
Here in the UK you take your driving test on a manual car and you have the option of taking an auto test but then cannot drive manual.
Also most if the cars on the road are manuals.
MAZI is offline
post #30 of 36 Old 8th January 2015, 03:47 PM
chuffykow
I learned to drive on a manual transmission vehicle. I'm an exception in my circle of friends / my wife's family.
2002 ///M5 Chiaretto Red/Caramel
  • Handling: DINAN Stage 2 Suspension / Front Strut Tower Brace
  • Performance: Evolve stage 2 S/C with billet aluminum plenum / Aeromotive 11140
  • Ear candy: DINAN Free Flow Exhaust / Intravee II / KCA-420i / 30GB iPod
  • Eye candy: 20% 3M Ceramic / Opti-Coat 2.0 by mzarif / Technical Graphite trim / Storm Motorwerks products / Nappa shifter / Slimmbones armrest
chuffykow is offline
m5 smg wont shift in 2nd gear endri sallata E60 M5 and E61 M5 Touring Discussion 12 31st January 2011 02:48 PM
Engine torque limiting in 1st/2nd gear? 4rotor E60 M5 and E61 M5 Touring Discussion 9 24th August 2006 03:28 PM
New Clutch grabbing hard in 1st & 2nd gear Goody4 E39 M5 and E52 Z8 Discussion 6 19th November 2005 11:37 PM
herky jerky shift from 1st to 2nd m5tackulous E39 M5 and E52 Z8 Discussion 28 8th March 2005 10:38 PM
1st to 2nd gear shift still rough? M Power E39 M5 and E52 Z8 Discussion 9 17th July 2003 02:18 PM
