Oil Temperature Sensor/Gauge problem - Page 4 - BMW M5 Forum and M6 Forums
Old 17th December 2009, 17:50   #31
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Originally Posted by Envisage0 View Post
Coolant temperature gauge going off-scale is instantaneous Doug.
Bad sensor or possibly an air bubble trapped under the sensor
Oil temperature gauge climbs to 100 degrees C gradually.
Which implies that the oil is actually getting hot
Suddenly (longer trip than I'm used to) we lose heating.
Which means either your heating core is gone, or something is preventing it from getting hot water. Usually an air bubble.
This is weird.
Or maybe it's just BEASTLY.
I see three different issues, all related to the coolant system and all with a possible root cause of an air bubble. If I were you I'd bleed my system ASAP...
d-
DouglasABaker is offline   Reply With Quote
Old 17th December 2009, 18:06   #32
Envisage0
Garage: E39 M5 Avus Blue
I trust your expertise Doug.
Thanks for your view.
Why would these symptoms arise in such a random way?
I can go months without a gauge going off-scale and then I get three incidents within an hour. Then I get a new symptom that doesn't persist. I suspect it is, like the others, lurking.
**** it, let's do it - Australian proverb
"If you are in control, you're not going fast enough."
Mario Andretti
Envisage0 is offline   Reply With Quote
Old 17th December 2009, 18:28   #33
DouglasABaker
All depends on where the air bubble(s) is in the system. Modeling the turbulence of even a simple system like our cooling is complicated, but basically it may be that the bubble gets trapped somewhere for long periods and then dislodges when something silly happens. What and where is beyond me...
d-
Tags
gauge, oil, sensor, temperature
Problem: Engine oil Level sensor Leet Pro E34 M5 Discussion 3 26th May 2009 16:11
Oil temperature gauge wiring H36 E34 M5 Discussion 3 22nd March 2009 13:40
Coolant temperature off scale. Why does oil temperature gauge slowly rise? Envisage0 E39 M5 and E52 Z8 Discussion 8 28th October 2008 00:44
Oil temperature problem. Tifosi79 E34 M5 Discussion 1 16th August 2004 15:31
Oil temperature sensor M540i LE E34 M5 Discussion 2 31st July 2004 01:06
