Old 9th October 2009, 23:19   #111
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
Originally Posted by vantaam5 View Post
I know for a fact that the oilpressure drops under harsh conditions(E30 track toy) to a critical level.The guy logged it and went after to a drysump system.
This would also explain the "cavitation" issue on my lower cyl8 bearing...
This is for an E30 with an S62 engine in it?
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 9th October 2009, 23:31   #112
vantaam5
vantaam5's Avatar
Garage: 2003 M5 black
Yep!Sorry,forgot to mention..
2003 M5
-Schrick cams -100 cell race cats -ECU remapped -Black kidneys -Schroth 4-point harness
-CAI - X-pipe -Alcantara steering wheel and shifter -lighter oem flywheel-Sachs performance clutch
mods not yet in:
-big bore throttle bodies -Alpha-N
-Brembo 4-pot calipers front with 2-piece discs-sleeved block
Rod bearing DIY: http://www.m5board.com/vbulletin/e39...cs-inside.html
Vanos solenoide removal:http://www.m5board.com/vbulletin/e39...des-video.html
Clutch DIY:http://www.m5board.com/vbulletin/e39...-diy-pics.html
Propshaft center bearing DIY:http://www.m5board.com/vbulletin/e39...-diy-pics.html
Chain tensioner DIY:http://www.m5board.com/vbulletin/e39...-diy-pics.html
ABS sensor DIY:http://www.m5board.com/vbulletin/e39...front-diy.html
Clutch line DIY:http://www.m5board.com/vbulletin/e39...ml#post1774788
vantaam5 is offline
Old 10th October 2009, 02:24   #113
nightkrawler
nightkrawler's Avatar
Garage: Lemans Blue M5
there is absolutely no need to replace the oil pump, unless you feel like spending another $1200 cause thats what they cost. i have had these pumps apart. they are very robust and really nothing inside them that should fail. you can fill it with oil and spin it over but i think you'll be fine just starting it normally
nightkrawler is offline
Old 12th October 2009, 21:27   #114
vantaam5
vantaam5's Avatar
Gents,time for another update.
Have now everything back together and did a solution for the bent oil tube...
only lower oilpan to install tomorrow,oil in and INPA connected for first start
All nice clean stuff waits to get back in:
I also ran into another intersting issue:
vantaam5 is offline
Old 12th October 2009, 22:04   #115
M5 London
M5 London's Avatar
Garage: M5 E39 Carbon Black/Caramel
Light at the end of the tunnel !!
What are the scratches on and from ?
Cheers
My E39 M5 Headers (Manifolds)
E39 M5-ESS Supercharger VT570*-VM Race Manifolds* VM Race Cats*-VM Exhaust System* Bilstein Sprint Dampers-Intrax Springs-Dinan Adjustable Rear Anti Roll Bar*-X5 Thrust Arm Bushings-IATS Relocation Kit-VM CAI Foglights Removed-Goodridge Brake Hoses-E60 550i SSK
MB SL500-Lexus LS400-VW Golf Rallye-VW Corrado 16V-E36 M3-Stolen
M5 London is offline
Old 12th October 2009, 22:24   #116
vantaam5
vantaam5's Avatar
Cheers
K,cam timing was ok
The scratches:Rattling noise at idle and engine shut off
vantaam5 is offline
Old 12th October 2009, 22:32   #117
M5 London
M5 London's Avatar
Good Good !
Old 13th October 2009, 19:31   #118
mailman
mailman's Avatar
Garage: E39 M5 (11/99), Carbon Black
Looked very nice today when I visited in VantaaM5's garage
I'm just waiting video from the first start after this project...
E39 M5 '00 Carbon Black
+ Supersprint Race Mufflers +
+ Supersprint X-Pipe +
+ Hella OEM Facelift Headlights +
+ Hella OEM Facelift Tail Lights +
+ Custom Clutch Stop +
+ LED Interior Lights +
+ Carbon Black Kidneys +
+ E60 Short Shifter Kit +
More to come...?
mailman is offline
Old 13th October 2009, 21:11   #119
vantaam5
vantaam5's Avatar
Gents,THE BEAST RUNS AGAIN!!!!!
Repaired also my power steering leak today and installed 2 E60 SSKs as well.
We started her up with INPA online(THANKS,sipi!) and I cranked her first with pulled fuelpump fuse and without spark plugs to get oil pressure.
Was rattling quite a bit due to no pressure in the Vanos,but after a few seconds everything was fine,no errors,leak,noises anything.
Video is crappy sound quality,sorry guys,not good enough to upload!
vantaam5 is offline
Old 13th October 2009, 21:40   #120
vantaam5
vantaam5's Avatar
A few pics from assembling the oil pump and lower oilsump parts...
vantaam5 is offline
DIY Spark Plugs, as requested. (Pics inside) rdm190 E39 M5 and E52 Z8 Discussion 66 25th November 2009 19:48
Help! Rod bearing problem? :( jrhaile E39 M5 and E52 Z8 Discussion 47 22nd August 2009 20:28
piston/rod bearing. bmwm5lover E34 M5 Discussion 8 26th August 2008 13:48
ROD bearing replacement rneedham1979 E39 M5 and E52 Z8 Discussion 17 22nd March 2008 05:26
Connecting rod bearing failure CTW E39 M5 and E52 Z8 Discussion 13 22nd January 2008 05:26
Page generated in 0.14413 seconds with 12 queries
