Old 16th November 2000, 16:33   #1
daniel
Post
Tom,
ME is right that the M5 is not normally offending is this department... my last car was a Viper GTS and followed every seam in the pavement. Maybe an alignment might not be a bad idea... not likely, but maybe you your car needs a bit of toe-in up front. And I belive that the alignment is free in the US for the first few thousand miles, and BMW should do it for under $100 anyhow. Let us know. Dan
daniel is offline
Old 16th November 2000, 22:08   #2
Tom M5
Garage: 2001 Jet Black M5
Post
I'm running Michelin Pilot Sports and have confirmed 40lbs in the front and 44lbs in the back. Have about 100 miles until 1200 mile service. I will have BMW check the alignment.
Tom M5 is offline
Old 17th November 2000, 01:50   #3
Tim W
Tim W's Avatar
Garage: Porsche 996TT Blue
Send a message via Yahoo to Tim W
Had the problem with mine. It was real annoying. THey checked the alignment and the Toe is was off by a bit. they set it correctly and the car is much easier to drive.
Tim W.
Tim W is offline
Old 17th November 2000, 01:51   #4
Tom M5
Post M5 tracking grooves in the road
I have noticed the M5 trackes the grooves in the pavement alot more than any other car I have owned. Any comments.
Tom M5 is offline
Old 17th November 2000, 01:55   #5
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
Post
Most performance cars will do this to some extent. I think its due to a combination of big fat sticky tires in the front as well as relatively "quick" steering. I find that relative to "true sports cars" the M5 is pretty easy going in this department. If you think its excessive you might want to check your tire pressures. It could also be the road- on some roads by me you can see where the pavement has sunk in from the weight of vehicles and I can easily feel this in the M5s steering. Out of curiosity, what kind of tires are you using? I have the Dunlop 8080s. I think they're decent, but I plan on replacing them with the michelin pilot sports.
ME
MEnthusiast is offline
Old 17th November 2000, 05:42   #6
alpywhite
alpywhite's Avatar
Garage: 2003 BMW M5, Titanium
Post
I feel it's more the width of the wheels than the tires; still the same issue.
alpywhite is offline
Old 18th November 2000, 01:07   #7
DrJimM5
DrJimM5's Avatar
Garage: 2000 Titanium silver M5
Post
I think Alpy is correct. Tramlining is the term I've heard and because of the width of the tire it feels unbalanced as part of it is higher and part of it is lower. The car therefore wants to get even(gravity), so it tracks right down into the valley of the road. This is probably made worse by things like faulty pressure or misalignment. You should probably find better roads to enjoy.
Jim
DrJimM5 is offline
Old 18th November 2000, 01:31   #8
bob
Post
I had the same problem on my 2000 M5. The technical people in Spartanburg told me to set the alignment to the minimum toe-in specification (that is, make it more toe-out). I never did try this since the car is sold (2001 expected in Janaury) but I'd be interested if anyone has. The roads here in Oregon are full of ruts because studded tires are legal six months of the year.
bob is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4496 Today 09:15
favorite SCENIC ROUTES alpinadvl Regional Forums and Events and group meetings for M5, M6 and Alpina owners 20 1st September 2009 05:30
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 13:24
E34 M5 owners weekend (5 till 8 September 2003) raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 5 28th September 2003 09:32
Page generated in 0.12800 seconds with 11 queries
