I blew the engine...lessons learned. - BMW M5 Forum and M6 Forums
Old 21st September 2009, 03:21   #1
PAUL HUGHES
PAUL HUGHES's Avatar
Garage: 2001 M5 Lemans Blue
I think I blew a rod bearing cap through the oil pan or block.
I was at Monticello Motor Club, a great technical track, and on my 4th time out for the day, coming around a turn, full acceleration in 3rd - maybe 4000 - 6000 rpms, and blue smoke out the front right wheel well, then loss of power, loss of power steering, etc.
at first I thought I blew a tire, then I thought I busted the fan belts. but after I got out of the car, I saw a trail of oil, and oil coming out from under the engine. tires were fine. fan belts fine.
the flag man said he saw flames under the car when it happened.
the Porsche driver in back of me said he saw a ball of flame coming out from under the car.
I assume it was engine oil hitting hot exhaust pipe.
I found a 2" x 2" piece of oil pan or engine block when we rolled the car off the flatbed.
interestingly enough, the dip stick still shows being only 3/4 of a quart low on oil.
i'm not sure what turns when i engage the starter motor, but it is not making compression to start the motor.
what probably happened:
a rod bearing was bad, and it blew under the constant pressure of running up gears 2, 3 and 4 to close to redline.
in the week or 2 before track day, I heard a tapping at startup, occasionally when cold.
I kept thinking it sounds like a rod bearing, but then would think maybe it's gear lash (that usually happens, buy only when warm).
it made no sense to me that a rod bearing would be bad.
I also heard continual tapping occasionally, in first gear, 2000 - 3000 rpms, under very light throttle.
prior to that last circuit, I think I heard it as I was moving forward in the line of cars getting ready to go out on the track.
but I kept thinking .."it can't be"...
so the car is at Motor Works West in Wyckoff, NJ.
I will get an update from them when they put it up on a lift.
Lessons learned:
When the car tells you something, listen to it!
Stop and fix the problem, before it gets worse!
Try not to rationalize something as something other than what the facts are telling you.
i placed a "wanted to buy" for a used engine in the "wanted/for sale" threads, because it will probably be less expensive than repairing the 58,000 mile motor.
if anyone knows where i can put my hands on one, please let me know.
Stoptech ST-40 BBK
Track pads - Hawk DTC-60 front/HT-10 rear
UUC dssr
EVO 3 ssk
TC Design rear sway bar brackets
Borla 20203 exhaust tips (muffler delete)
Dunlop Direzza Sport Z1 Star Spec tires
PAUL HUGHES is offline   Reply With Quote
The Following 6 Users Say Thank You to PAUL HUGHES For This Useful Post:
100%Cocoa (21st September 2009), ard (21st September 2009), Chadderz2010 (1st July 2010), CSBM5 (21st September 2009), herrubermensch (21st September 2009), JL21ah (1st July 2010)
Old 21st September 2009, 03:31   #2
malexgcab
malexgcab's Avatar
Garage: M5 CB
Doesn't Razahyde have a spare engine?
malexgcab is offline   Reply With Quote
Old 21st September 2009, 03:35   #3
PAUL HUGHES
maybe - i will PM him.
thanks.
Old 21st September 2009, 05:14   #4
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel; 2007 Z4M Coupe
So sorry to hear...Stock redline or raised? Do you know the history of oil changes (when and with what oil)?
GL with the engine replacement.
Kevin
2007 Z4M Coupe (#2) Silver Gray/Black
Too many kids' cars...
KevinM is offline   Reply With Quote
Old 21st September 2009, 05:18   #5
wentouch
Garage: 03 E39 M5 JB/B/Al
There's also this option:
Cheapest M5 yet?
wentouch is offline   Reply With Quote
Old 21st September 2009, 05:19   #6
PAUL HUGHES
stock engine/redline. i change the engine oil every 5 - 10,000 miles, 5 - 30 synthetic, but i only owned it for 20,000 miles.
i did change the engine oil and filter, transmission oil and brake fluid, etc. in preparation for track day.
Old 21st September 2009, 05:21   #7
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
2 of them to be technical....
razahyde is offline   Reply With Quote
Old 21st September 2009, 05:23   #8
PAUL HUGHES
Cheapest M5 yet?
good thought, but i question the high mileage. i might consider if i give up having fun with tracking the car.
Old 21st September 2009, 05:29   #9
qwyjibo
qwyjibo's Avatar
Garage: '03 M5
how many miles on car when this happened?
qwyjibo is offline   Reply With Quote
Old 21st September 2009, 05:31   #10
PAUL HUGHES
58,000.
i don't know what could have caused the rod noise, though.
Tags
engine for sale, engine rebuild, engine swap
Autocrossed it! Learned some lessons.. took some pics.. Anzir E39 M5 and E52 Z8 Discussion 14 22nd February 2005 02:41
Re: M5 Totalled, Update & Insurance lessons learned. chunpng E39 M5 and E52 Z8 Discussion 24 18th February 2005 23:00
Blew the engine BradM5 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 2 13th October 2004 13:06
Golf Lessons jamesnj Off Topic Forum 3 11th July 2002 00:43
Management Lessons... CarlT Off Topic Forum 2 15th May 2002 08:24
