Old 20th September 2009, 22:04   #1
ChaoticZen
ChaoticZen's Avatar
Garage: 2002 Carbon Black ///M5
Help! How to remove shifter cup without the cup removing tool?
Hi all,
I decided to do my 545 shifter today on the ///M, everything went real smooth until I am about to remove the shifter, I don't have the BMW cup removing tool, is there anyway I can remove it without the tool or I just have to put everything back and order one?
thanks,
Ping
The search of that perfect E39 M5 has ended...
ChaoticZen is offline
Old 20th September 2009, 22:07   #2
vantaam5
vantaam5's Avatar
Garage: 2003 M5 black
You mean the white plastic bushing around the the ball on the shifter?
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Schroth 4-point harness
-Castrol SRF brake fluid
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
-CAI with ram-air ducts
-custom built X-pipe
mods not yet in:
-Custom built headers
-custom built adjustable DSSR in T6
planned mods:
-Brembo calipers with drilled discs(only pots missing at the moment)
-custom built carbon fiber front splitter
-coilover suspension
-illuminated ZHP shift knob
Rod bearing DIY: http://www.m5board.com/vbulletin/e39...cs-inside.html
Vanos solenoide removal:http://www.m5board.com/vbulletin/e39...des-video.html
vantaam5 is offline
Old 21st September 2009, 00:00   #3
ChaoticZen
ChaoticZen's Avatar
Yeah I tried the two flat head screw driver trick and it didn't budge, I put everything back already and unless someone has one that I can borrow I guess I would just have to buy one.
Old 21st September 2009, 00:26   #4
vantaam5
vantaam5's Avatar
If it does not move out of the support arm,turn it with the screwdriver clockwise and pull on the lever.Sometimes it is a bit tricky,but works!After that if you want it off the ball,rest it upside dowm with the bushing on a bench vice and push the lever out.
Have done it many times that way and never used a special tool for it.
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
mods not yet in:
planned mods:
vantaam5 is offline
Old 21st September 2009, 02:01   #5
M5 London
M5 London's Avatar
Garage: M5 E39 Carbon Black/Caramel
+1 !
My E39 M5 Headers (Manifolds)
E39 M5-ESS Supercharger VT570*-VM Race Manifolds* VM Race Cats*-VM Exhaust System* Bilstein Sprint Dampers-Intrax Springs-Dinan Adjustable Rear Anti Roll Bar*-X5 Thrust Arm Bushings-IATS Relocation Kit-VM CAI Foglights Removed-Goodridge Brake Hoses-E60 550i SSK
MB SL500-Lexus LS400-VW Golf Rallye-VW Corrado 16V-E36 M3-Stolen
M5 London is offline
Old 21st September 2009, 03:36   #6
gzig5
Garage: 2000 M5 Carbon Black
I used a needle nose pliers opened up to contact the two raised tabs and had no problem turning the bushing until it woul pull out.
gzig5 is offline
Old 21st September 2009, 23:36   #7
graffix000
graffix000's Avatar
Garage: Jeep GC, 03 M5, 05 Yukon Denali
I also used the needle nosed pliers. It was one of the easiest parts of the job for me.
2003 Sterling Grey M5
Dinan Front Strut Brace, Rear Sway Bar & CAI
Eisenmann Race & X Pipe
UUC Evo 3 & DSSR
GC Coilovers
Confronti Shark Injection 93 Octane
Brake Duct Mod
Intravee II
Rear Wheels Up Front (275's all around)
Ultimate Pedals
V1/S1
graffix000 is offline
Old 22nd September 2009, 05:30   #8
ChaoticZen
ChaoticZen's Avatar
Cool I will try that this weekend, I have already ordered a new bushing so if I can't get it out I will just slowly taking it apart.
Do you guys remember if it was counterclockwise or clockwise from inside the car? Thanks!
How to remove cup holder mount AlpineMsix E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 24th June 2008 09:23
Americas Cup? Gustav Off Topic Forum 4 16th November 2002 12:50
World Cup KRM Off Topic Forum 10 19th June 2002 05:52
A Coffee Cup that fits into E39 cup holders jds E39 M5 and E52 Z8 Discussion 6 17th February 2001 20:45
The best cup holder for you M5 Mattar E39 M5 and E52 Z8 Discussion 1 15th February 2001 23:02
Page generated in 0.12850 seconds with 11 queries
