Old 20th September 2009, 22:00   #1
vantaam5
vantaam5's Avatar
Garage: 2003 M5 black
Anyone infos on Dinan MAF highflow kit?
Hi guys,
does anyone of you know if the Dinan MAF highflow kit is with the stock MAFs?
Thanks,
VantaaM5
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Schroth 4-point harness
-Castrol SRF brake fluid
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
-CAI with ram-air ducts
-custom built X-pipe
mods not yet in:
-Custom built headers
-custom built adjustable DSSR in T6
planned mods:
-Brembo calipers with drilled discs(only pots missing at the moment)
-custom built carbon fiber front splitter
-coilover suspension
-illuminated ZHP shift knob
Rod bearing DIY: http://www.m5board.com/vbulletin/e39...cs-inside.html
Vanos solenoide removal:http://www.m5board.com/vbulletin/e39...des-video.html
vantaam5 is offline
Old 20th September 2009, 22:08   #2
El Diablo
El Diablo's Avatar
Garage: 2002 M5 Carbon Black
Send a message via Yahoo to El Diablo
I'm pretty sure the kit does not come with MAF sensors only the larger diameter MAF housings. But to answer your question, it does utilize the OEM sensors.
-Roberto
'02 Dinan S2 M5 - Carbon Black/Black Nappa Leather/Sport Trim/M Audio/Rear Shades/PDC/Split Rear Seats. Dinan Headers/TB/VS/CAI, Stage 5 software, 3:45 rear diff, LTW flywheel, Stage 3 Dinan/JRZ suspension, Dinan SSK, Dinan Front Strut Bar, Supersprint X-Pipe and Evosport UDD Power Pullies. Aesthetic but functional upgrades include ZHP Gearshift knob, AA Lower Grille w/Brake Cooling Ducts, Progressive Window Tint, AC Schnitzer Pedals, Chromed OEM Rear Wheels with 275/35-18 PS2's all around, Predator Ice Angel eyes, Xenoflo 6000K with matching HID High beams and Fogs, TEC Cup Holder, Hardwired V1 Detector, Gen13 Bluetooth Module, MkIV Nav. v28
El Diablo is offline
The Following User Says Thank You to El Diablo For This Useful Post:
vantaam5 (20th September 2009)
Old 20th September 2009, 22:10   #3
vantaam5
vantaam5's Avatar
That's all I wanted to know
Have to do some milling and welding next week
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
mods not yet in:
planned mods:
vantaam5 is offline
Old 21st September 2009, 10:40   #4
ard
ard's Avatar
I assume you know that making custom larger MAF housings will require extensive testing and calibration- AND custom programming of the DME.
Unless you EXACTLY copy Dinan. Then you just need the programming. Pay attention to how the Dinan mafs taper...
ard is offline
Old 21st September 2009, 19:55   #5
vantaam5
vantaam5's Avatar
Thanks for that point,but I know what I do with that project
Want to go first that way,before it is time for an Alpha N solution....
And will need soon more air for the bored TB's anyway...
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
mods not yet in:
planned mods:
vantaam5 is offline
Want to buy E39 M5 SS headers and highflow cats. Klappi For Sale or Wanted 0 14th February 2009 01:37
FS: Dinan MAF Kit xr4tic For Sale or Wanted 4 20th July 2008 01:09
MAF Air ducts Insulation VS. IATS relocation kit?? BuDavid E39 M5 and E52 Z8 Discussion 0 4th August 2007 10:27
infos about 1series RickyT E60 M5 and E61 M5 Touring Discussion 13 4th February 2004 21:08
Mass Air Flow (MAF) kit for E28 M5... ? M5Glenn E28 M5 Discussion 1 21st April 2000 17:27
Page generated in 0.10935 seconds with 11 queries
