Old 20th September 2009, 19:33   #1
Neil.D
Neil.D's Avatar
Garage: E39 M5 - Titanium Silver
Oil leak diagnosis help (pictures inside)
Hi Guys...
I have got a drip, drip, drip of an oil leak. Its yet to hit the floor but is collecting in the plastic belly pan. One side of the engine is wet with oil but I cant really see where its coming from. The front RHS (US passenger side) is the affected.
I took off the belly pans and looked up under the car, the epicentre of the leak if you like seems to be shown in the photo and the hose 'junction'. Sadly I have no idea what this part is, or if indeed it is oil related. It is just by the aux drive belts. Can anyone identify the part shown? It seems to be where the leak is coming from. Real OEM doesnt help me.
Thanks guys!
Neil
2000 M5 Titanium silver
Neil.D is online now
Old 20th September 2009, 20:31   #2
jt2ma71
jt2ma71's Avatar
Garage: Alpine White E39 M5
I think that steel valve type thing is the check valve for the secondary air system. Can you take more pictures from a little farther away?
My suggestion for you would be to clean all the old oil off and see if you can see a trail after driving it for an hour. Right now it looks like it could be the Vanos O-Ring on the adjustment unit or maybe yout timing cover is leaking? Have you checked your Oil lines from the filter housing/Powersteering lines for leaks?
2000 Alpine White M5
Performance: Custom CAI, Tubi Exhaust, Open Brake Ducts, UUC Evo3 + DSSR
Exterior: Euro Mirrors, Black kidney grilles, MY01+ Updated, Mtec 3W AE, Altec retractable license plate
Interior: 16:9 Nav, MK3 Navigation, MY01+ dash, Silverstone Leather
Wheels: Volk CE28N Time attacks 19x10.5 275/30/19, 19x8.5 245/35/19 Pilot Sport PS2
1999 Ranger XLT 4x4
2" Lift, 33's, 4.10LSD, Locked front hubs
jt2ma71 is offline
The Following User Says Thank You to jt2ma71 For This Useful Post:
Neil.D (20th September 2009)
Old 20th September 2009, 21:30   #3
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Probably going to turn out your valve cover gasket on that side. I assume the top of your motor is dry? Like your oil cap and all the grommets that hold the valve covers down? I agree with the above. Clean that off with some good engine degreaser and a brush and let it dry. Try idling/revving for a few minutes and look for the leak before driving. Engine bay wind can really make the oil swirl around. If you need to drive go real slow to keep the wind down.
Members:
If you want your oil pan repaired (see http://www.m5board.com/vbulletin/e39...rain-plug.html) instead of buying a new one or attempting the repair yourself PM me and we'll work something out. Thinking $60 profit is worth it. You pay all shipping of course. At the moment I have four remaining Timesert inserts looking for homes. If the demand is there I'll keep doing them. If not the tool goes on eBay minus one insert.
TMcNasty is offline
The Following User Says Thank You to TMcNasty For This Useful Post:
Old 20th September 2009, 22:20   #4
Neil.D
Neil.D's Avatar
Hi guys!
Thanks for the advice. I have tried to clean it up but to be honest it is all so filthy I cant really get it clean enough to see new trails!
Valve cover gaskets are a good shout. Can you detect them weeping with the engine running? Im guessing you have to slide your hand right down the side of the block?
Old 20th September 2009, 22:32   #5
vantaam5
vantaam5's Avatar
Garage: 2003 M5 black
You can also easiely take off the cover of the solenoides,then you see if the O-rings are leaking and cause that problem.Have just done that on saturday on another board member's car to see where it was leaking.In our case it was the O-rings...
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Schroth 4-point harness
-Castrol SRF brake fluid
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
-CAI with ram-air ducts
-custom built X-pipe
mods not yet in:
-Custom built headers
-custom built adjustable DSSR in T6
planned mods:
-Brembo calipers with drilled discs(only pots missing at the moment)
-custom built carbon fiber front splitter
-coilover suspension
-illuminated ZHP shift knob
Rod bearing DIY: http://www.m5board.com/vbulletin/e39...cs-inside.html
Vanos solenoide removal:http://www.m5board.com/vbulletin/e39...des-video.html
vantaam5 is online now
The Following User Says Thank You to vantaam5 For This Useful Post:
Old 20th September 2009, 22:53   #6
Neil.D
Neil.D's Avatar
Hi,
Yes I have been reading the instructions for removing the solenoid covers. From your first hand experience is it quite easy to simply remove + inspect?
Presumably when the cover is off you can see a deterioation or a break in the O ring.
Neil
Old 20th September 2009, 23:00   #7
vantaam5
vantaam5's Avatar
It is easy to do,let her cool down and open the coolant cap to remove the pressure from the water hose,makes live easier!
You have to pull the solenoides to see anything more on the O-rings,like the DIY thread says...
But to see if they are causing your oilleak,it is enough to pull the cover!And don't forget to tighten the blots again with 19NM torque....
Be careful when you remove the covers that you don't break their gasket if you don't have a new one...
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
mods not yet in:
planned mods:
Old 20th September 2009, 23:16   #8
Neil.D
Neil.D's Avatar
OK thanks. So its worth just buying the gaskets + 16 O rings in preperation by the sounds of things. Bearing in mind they are not expensive and will need doing at some point in the future anyway.
I will start there. Appreciated.
Neil
Old 20th September 2009, 23:25   #9
vantaam5
vantaam5's Avatar
Is worth it!Just try the cover first and see if it is leaking there.Changing the O-rings and removing the gauze filters and cleaning them is not such a hard job,have done that last week on my beast finally.
We will do quite soon with some of the finnish boardmembers a "Group O-Ring Change Event" on their cars...
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
mods not yet in:
planned mods:
Old 20th September 2009, 23:31   #10
M5 London
M5 London's Avatar
Garage: M5 E39 Carbon Black/Caramel
Yo Neil,
Are you sure the oil is leaking from the Vanos Solenoids ?
Its going to be quite obvious/apparent if its from there surely ?
Check this out while I find the other stuff you pm'd me about, in case its leaking from the actual VANOS Adjustment Units :
Vanos Adjustment Units, Refurb-Parts List
Oh yeah just for my/our piece of mind check your PAS fluid level please.
Cheers
EDIT : Courtesy of DR Vanos (attached)
My E39 M5 Headers (Manifolds)
E39 M5-ESS Supercharger VT570*-VM Race Manifolds* VM Race Cats*-VM Exhaust System* Bilstein Sprint Dampers-Intrax Springs-Dinan Adjustable Rear Anti Roll Bar*-X5 Thrust Arm Bushings-IATS Relocation Kit-VM CAI Foglights Removed-Goodridge Brake Hoses-E60 550i SSK
MB SL500-Lexus LS400-VW Golf Rallye-VW Corrado 16V-E36 M3-Stolen
M5 London is online now
The Following User Says Thank You to M5 London For This Useful Post:
Oil leak through the new oil cap teropa E39 M5 and E52 Z8 Discussion 26 17th August 2009 20:56
Pictures of the Vanos line oil leak? rayt E60 M5 and E61 M5 Touring Discussion 8 25th December 2005 05:53
Engine Oil Leak Suspected - Non-Linear Oil Usage 507bhp E60 M5 and E61 M5 Touring Discussion 12 10th December 2005 22:05
Persistent Oil Leak Fixed w/New Oil Pan JonB E39 M5 and E52 Z8 Discussion 2 14th June 2002 01:04
oil leak from oil cap calbobba E39 M5 and E52 Z8 Discussion 7 31st August 2001 00:19
Page generated in 0.16166 seconds with 12 queries
