Old 20th September 2009, 18:55   #1
nightkrawler
nightkrawler's Avatar
Garage: Lemans Blue M5
Anyone want to do me a big favor? :)
i need to know the wire colors that go from the pedal potentiometer to the other side of the plug. the plug is under the dash on the left side. i need to know which wire colors go to which on both sides of the plug. anyone wants to check this for me give me a call, i'll make it worth your while. thanks, dave 570 357 1077.
nightkrawler is offline
Old 20th September 2009, 19:52   #2
nightkrawler
cmon guys, it will take all of 5min to check this, i help everyone on this board whenever i can.
Old 20th September 2009, 19:57   #3
MrCrashRR
Garage: 2003 Alpine White M5
Is it under the kick panel? I'm away from home so I can't take that off to look, but if its not behind that let me kknow and I'll go run to my car. If its behind the panel, I can do it later tonight If someone hasnt stepped up.
2006 Phantom Grey Tundra 4dr
2004 La Mans Blue CBR1000rr track bike
MrCrashRR is offline
Old 20th September 2009, 20:53   #4
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
happy to help if you can give me a bit more info on where the plug is....?
100%Cocoa is offline
Old 20th September 2009, 21:10   #5
vantaam5
vantaam5's Avatar
Garage: 2003 M5 black
Give me a few minutes,just have to find a flash light and go to the car..
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Schroth 4-point harness
-Castrol SRF brake fluid
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
-CAI with ram-air ducts
-custom built X-pipe
mods not yet in:
-Custom built headers
-custom built adjustable DSSR in T6
planned mods:
-Brembo calipers with drilled discs(only pots missing at the moment)
-custom built carbon fiber front splitter
-coilover suspension
-illuminated ZHP shift knob
Rod bearing DIY: http://www.m5board.com/vbulletin/e39...cs-inside.html
Vanos solenoide removal:http://www.m5board.com/vbulletin/e39...des-video.html
vantaam5 is offline
Old 20th September 2009, 21:23   #6
NJ.M5
NJ.M5's Avatar
Garage: 2001 LMB with Black/Blue interior
I already helped him with this.....so if anyone's fishing around under there, problem has been solved!
NJ.M5 is offline
Old 20th September 2009, 21:27   #7
Hdhntr23
Hdhntr23's Avatar
Garage: 2002 Titanium Silver E39
Sales Feedback: (12)
Send a message via MSN to Hdhntr23 Send a message via Yahoo to Hdhntr23
Nightkrawler,
Is this for your usb to i-bus project?
One can be spelled as NEO.
There is no spoon.
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77), C-Fiber Kidney Grills, ACS C-Fiber Roof Spoiler, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece door sills, 7 Piece C-Fiber Blue/Grey Roundels.
Current Performance Mods: Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan)
Planned Exterior Mods:
Stainless vented custom Fog-Light frames (Awaiting fabrication), C-Fiber ACS Flipper style Front Splitters (Awaiting delivery and install), PIPEDREAM.... Vorstiener vented CF double sided hood
Planned Interior Mods:
Scosche BlueTooth 2.0 A2DP Adapter, Backlit Door Sills, Hardwire V-1, Stealth One, Replace instrument cluster (Pixels dropping out), Add a dedicated amp for the "M" Subs, Euro-Style Armrest
Planned Performance Mods:
Dinan Front Tower Brace, Headers (Looking for input)
Hdhntr23 is offline
Old 20th September 2009, 21:36   #8
vantaam5
vantaam5's Avatar
Have just put everything under there back together and wrote colors of the wires down...
Just in case someone else want to know it(all from sensor to car wiring loom)
brown to brown/green, yellow to brown, green to yellow/green, pink to yellow, green to white, white to white/green
2003 M5
-Schrick cams
-100 cell race cats
-Ecu remapped
-Black kidneys
-Ferrodo pads
-Custom clutch stop
-brake air ducts
-545i E60 SSK
mods not yet in:
planned mods:
vantaam5 is offline
Old 20th September 2009, 23:31   #9
nightkrawler
thanks NJ M5 and the rest of you guys for your help. i was running a 540i pedal module for a while trying to figure out a problem with jumpy throttle response. i had to remove the pins from the connector on the pedal pot side of the plug. i didnt write them down cause i figured the wiring diagram would show them. unfortunately it only showed the one side of the connector, not the side i needed. all fixed up now though, thanks again.
Need a big favor.... PLEASE! H8Rain E39 M5 and E52 Z8 Discussion 9 4th June 2008 17:41
Big Favor to anyone in/near Fairfax, VA jamesR E39 M5 and E52 Z8 Discussion 6 7th January 2006 23:17
A huge favor to ask. Jamie140 Off Topic Forum 7 30th April 2004 17:50
Favor Bigtime007 E39 M5 and E52 Z8 Discussion 9 15th January 2004 02:17
Do yourself a favor greg E39 M5 and E52 Z8 Discussion 5 23rd June 2000 18:28
Page generated in 0.12454 seconds with 11 queries
