Old 20th September 2009, 16:13   #1
agreenrhino
Garage: 2003 M5 Titanium Silver
Recommend: Taller Gears w/ESS SC?
In conjunction with my near future ESS SC install I am planning to send my stock LSD to KMS for a partial rebuild: new clutches and their custom 30/90 ramps, all set up to 40% static lock. I am tempted to go with a full rebuild that would also include new gears, bearings, and seals...and the option to go to taller gears (there is no additional cost for taller gears). They have 3.07, 2.93, 2.81 and 2.65 available.
Do any of you with the ESS SC recommend taller than OEM gears? Please let me know, thanks.
Performance Tuning:
Exhaust: SS headers, SS high flow cats, SS X-pipe, Meisterschaft GT2 exhaust
Clutch/Gearshift: UUC SSK, UUC DSSR, UUC V12 Kevlar clutch, UUC lightweight flywheel
Suspension/Handling: H&R sway bars, front and rear, Beastpower rear sway bar brackets, Strong Strut strut brace, Koni shocks, H&R springs, Dinan monoball thrust arm bushings, Powerflex upper/lower control arm bushings, Ground Control adjustable camber plates
Wheels: 19" VMR V710
Brakes: Brembo BBK: 8 piston front calipers (380mm rotors), 4 piston rear calipers (340mm rotors)
Other: AA CAI, Conforti Shark Injector performance software, Rogue Engineering power pulleys, IATS
Aesthetic Modifications: Vorsteiner CF vented hood, Vorsteiner CF splitters, Vorsteiner CF diffuser, CF kidney grills, CF side view mirrors, CF rear spoiler, CF BMW roundels, matte black M5 badge, matte black custom paint: wheels, exhaust, & CAI intake rings, Ultimate Pedals aluminum race pedals & footrest, Hella Supertones horn, BMW foot-well mounted umbrella
Get out of Jail Free Card: Beltronics STi Driver Radar Detector, Blinder M47 Laser Jammer
Euro Spec Accessories:BMW front seat mounted Fire Extinguisher, BMW front seat mounted First Aid Kit, BMW Emergency Triange
agreenrhino is offline
Old 20th September 2009, 18:17   #2
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
Jerry has a 2.65 but hasn't quite got his ESS kit functioning properly so he will be able to provide direct input to your question. With the ESS kit installed on my car, my initial impressions are that the car is more sluggish at low speed/part throttle applications. Before, if I didn't quite come to a complete stop, I would leave it in 2nd and the car would easily pull away. Now, the car is much more likely to bog and I have to downshift to first. Whether it's the S/C drag, Vanos tuning, or what, I don't know. So, I wouldn't go any taller than a 3.15.
03 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C, Supersprint headers and Race cats, Dinan 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
ECB is offline
Old 20th September 2009, 18:50   #3
Asbjorn@ESSTuning
Company Representative for ESS Tuning
Garage: BMW
The ECU will need a few 100 miles to fully adapt and provide optimal response, it should feel almost identical to a stock car below 2500RPM when fully adapted. If it does not I would replace spark plugs to ensure 100% operation.
I do not recommend taller gears than stock with the SC. The SC is only a major power booster from 2500-3000 and on.
Asbjorn@ESSTuning is offline
The Following 2 Users Say Thank You to Asbjorn@ESSTuning For This Useful Post:
agreenrhino (22nd September 2009), herrubermensch (22nd September 2009)
Is there any other sports luxury car for taller people. stokesj19 GTBoard.com: General Sportscars 4 28th August 2008 18:23
Recommend CA in Tacoma? jcolley E60 M5 and E61 M5 Touring Discussion 0 18th January 2008 07:13
anyone recommend any of these upgrades? korea_7 E39 M5 and E52 Z8 Discussion 2 18th May 2007 20:25
M6 "taller" than 650...aaaargh! jkrutch E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 13th August 2006 17:35
Can someone recommend a SA from SF BMW? C43///M5 E39 M5 and E52 Z8 Discussion 3 7th June 2002 10:38
Page generated in 0.10185 seconds with 11 queries
