Okay, I've done a bit of searching, but this will be faster. Where, besides the trunk, can I get an iBus connection? Got my USB interface, time to play. I'd like to be able to more permanently mount it for poking around.
I saw the trunk/changer connector, and read up on the one by the LCM bundle behind the glovebox. The LCM bundle just seems like trouble waiting to happen as people have used t-splice connectors for the Stealthone. Eek.
The LCM is a very easy location to get to, and takes maybe 5-10 minutes to tap and replace the glove box. I can't imagine there's a much easier spot besides the trunk. Should have no problems splicing into it.
I wanted to avoid the t-splice/scotchlok method. I'd rather repin something to an adapter that I built. Seemed to me (from the pictures) that getting into the LCM wiring bundle would be much more difficult for this method. Guess I'll stick with reworking the CD changer.
Does the phone have an ibus interface? If so, do cars without the phone have the wiring for ibus in the armrest?
Thats what I was going to suggest. Although based on your question Im assuming your car isnt prewired for a phone. If thats the case then I dunno if you can hack into that in your arm rest. Def worth a look tho.
If you get there let me know cause Id love an easier way myself.
One can be spelled as NEO.
There is no spoon.
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS
Current Performance Mods: Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan)
Just curious, but why would you go through the trouble of repinning some existing connection? Just don't like using a t-splice?
Easiest place is the center console, especially if you ditched the Startac, you can modify the phone's harness to use with your ibus interface. In my harness repin, the wires are as follows: White/Grey = ibus, Orange = +12v, Brown = Ground
If you don't have the Startac-side wire harness, just use that pinout to find the appropriate wire on the vehicle-side
That's the answer I want. Two questions:
1) does this wiring exist if I didn't have the phone option (like my car)?
2) if it does exist, or I want to go looking, whereabouts in the center console?
It should be there, underneath your armrest.
Two phillips screws hold your factory armrest in place (pop out rear passenger cubbyhole, pop out rear passenger A/C vent). Underneath, where the storage compartment SHOULD be, will be the plug. It may be tucked / recessed.
