ACS (Replica) Roof Spoiler Install Problems - The Unofficial BMW M5 Messageboard (m5board.com)
Old 18th September 2009, 22:12   #1
REKIII
REKIII's Avatar
Garage: 2001 Jet Black M5
Sales Feedback: (6)
So last winter I got a replica of the spoiler. I got it painted which promptly showed me the flaws of the replica. The paint brought out the knit lines of the plastic as well as the poor seams where the mold came together.
So, I took it back to the painter and they worked all that stuff out and repainted, it looks pritine.
Flash forward to this summer when I try to install it. I went and purchased a couple rolls of the3M automotive double sided tape, cleaned the spoiler and windo with alchohol, did some test fiting and find that the spoiler doesn't perfectly match the curvature of the roof, its a bit flatter, so the center touches before the sides. Now worries as with just a bit of force it flexes into place. I apply tape to all the raised surfaces and stick the spoiler on without removing it to reposition, just aligned and on.
Next morning I coume out and both sides have sprung. I think to myself, wow, you're stupid bob, you know twin stick takes a while to stick. So I grabbed my roll of blue painters tape and tapped the whole spoiler down, painers tape held it no problem. I left it like that for 24 hours.
Pulled the tape off, and within a hour the spoiler had spring. So, I remove it figuring the tape at the end had lost their sticky from being exposed overnight. Wow was the center hard to get off.
A couple weeks later I decide to try again. This time I put tape all over it, and even put 2 layers on the ends creating a taper to combat the spring in the spoiler. I immediately apply painters tape and leave it on for 2 Days, when I removed it, the spoiler was allready pulling a bit and stretching the tape.
I pull the tape off and later that day the spoiler is sprung. I waited a week to pull it off this time and the center was nearly impossible to get off but it came off without kinking or blemishing the spoiler at all.
So now what do I do? There has to be a way to make this thing work, it's so close.
Ideas from those that have installed? Am I using the right stuff? I've alread spent over $30 on stupid tape.
Thanks for any help.
Bob
2001 Jet Black M5
2008 Raven R1
2007 Black Sierra Denali
2006 Black Jeep Grand Cherokee Limited 5.7 HEMI
REKIII is offline   Reply With Quote
Old 19th September 2009, 00:20   #2
cknaak
cknaak's Avatar
Garage: Anthracite M5
I had the same problem with a carbon fiber ACS replica spoiler. I think you have to buy a heat gun and get it real hot so that you bend it to the contour of the rear window. This probably should have been done before paint.
I never got around to mine and still have the spoiler in the garage. Good Luck.
_______________________
Anthracite M5
DINAN Stage 1 suspension
DINAN CF Cold Air Intake
DINAN Stage 2 software
DINAN Short Shift Kit
DINAN Front Strut Brace
DINAN Pedal Set
Brembo 355 BBK w/Euro brake duct mod
Magnaflow 14186's with custom X-pipe and resonator delete
Linea Corse Lemans wheels wrapped with Toyo T1R's
cknaak is offline   Reply With Quote
Old 19th September 2009, 00:34   #3
azaytsev
azaytsev's Avatar
Garage: 996 C4S 6MT
Go to your local BMW dealer and buy a Betalink
___________________
BMW CCA MEMBER#409490
Previous BMWs
2001 M5
1997 528i
1990 535i
1977 320i
azaytsev is offline   Reply With Quote
Old 19th September 2009, 01:02   #4
Mfreakin5
Mfreakin5's Avatar
Garage: 2003 M5 Le Mans Blue
seems like your only option is a heatgun and a little patience. That's the great thing about plastic, it'll bend however you want with a little heat and force.
Originally Posted by Greco View Post
...There seems to be less logic and more hot air in this white paper, maybe to sell more of his products...
White paper.... more like toilet paper.
Mfreakin5 is offline   Reply With Quote
Old 19th September 2009, 01:03   #5
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
pics of what it would look like improperly installed?
my genuine ACS fits like a glove...glad i didnt get aftermarket.
razahyde is offline   Reply With Quote
Old 19th September 2009, 01:04   #6
azaytsev
azaytsev's Avatar
Garage: 996 C4S 6MT
here is the BMW part number for betalink glue 82-69-9-408-866
Old 19th September 2009, 03:41   #7
m5_2nv
m5_2nv's Avatar
Garage: 2000 BMW M5 Titanium Silver
I also have a ACS replica roof spoiler and it went on fine.
I bought there side molding tape (I know you already said there automotive tape but it could be different from what I used??) because mine sticks like glue.
EDIT: I forgot to mention that mine was a little bowed too, and i doubled up the tape on the sides, cant really notice it and it makes up for the tension on the ends so it wont spring back up on you.
It also holds on my genuine ACS side skirts and sticks thru rain/snow and whatever wisconsin throws our way!
Is this the tape you used??
'00 Ti Si/Black Leather (SOLD )
'88 Porsche 944 Turbo (LS1 Engine Swap)
m5_2nv is offline   Reply With Quote
Old 19th September 2009, 04:11   #8
Hdhntr23
Hdhntr23's Avatar
Garage: 2002 TiAg E39 M5
Sales Feedback: (13)
This is how I did it. I wish I wouldve done the same for my trunk spoiler. Im having the same issues as you with that. I only used painters tape and 4 pressure clamps to hold it down. The ends of my trunk spoiler are still wanting to come up a bit.
The roof spoiler Timmay77 and I used ratchet tie down straps and painters tape. I left it in the sun for a day, in the garage at night back out in the sun all day the next day and in the garage again. We used 1 strap on (hehe I said strap on) the length of the spoiler into the car... thats what the blue blanket is for. We used a second one in the middle to pull it down because it wanted to walk up to the top of the car. We secured the hooks into the cargo net hooks in the trunk. We also used the pressure clamps on the sides of the car to insure it wouldnt walk there either.
Sorry, forgot to add.... COPIOUS amounts of the 3M heavy duty double sided tape in the above post was used on it too. That mofo isnt going anywhere!!!
Air Jordans for sale!! Size 13 << Click the link!!!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline   Reply With Quote
Old 19th September 2009, 04:15   #9
Hdhntr23
Hdhntr23's Avatar
Edit.
Old 19th September 2009, 07:22   #10
JCM5
JCM5's Avatar
Garage: H5
I got a replica ACS roof spoiler as well few years ago. Believe me not worth it ...what you pay is what you get... it's horrible, uneven surface,flimsy and won't fit perfectly I regret it, few days later I throw it in the trash can. Get the real thing it's crazy expensive but well worth it for a M5.
JCM5 is offline   Reply With Quote
Acs replica roof spoiler bkms1 Parts / Other For Sale or Wanted 13 28th October 2008 23:32
Where can I buy ACS roof spoiler and truck spoiler? kcphuah E60 M5 and E61 M5 Touring Discussion 4 11th July 2008 14:34
E60 ACS Style Rear Spoiler & Roof Spoiler 07M5NJ Parts / Other For Sale or Wanted 13 14th May 2008 08:50
ACS Replica Roof Spoiler-NEW Unpainted E39 Racerxjling Parts / Other For Sale or Wanted 7 18th March 2008 06:06
ACS roof spoiler? Gene E39 M5 and E52 Z8 Discussion 27 4th June 2002 23:02
