A Few Problems with the Installation of the ESS VT550 SCer Kit - BMW M5 Forum and M6 Forums
Old 1st September 2009, 18:16   #1
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (4)
I am about 75% of the way through the installation now, having spent two half-days on the project, and here are the issues I have run into and their resolution.
First, the ESS crank pulley does NOT work with the Evosport crank pulley. It doesn't sit flush on the face and, thus, extends about a half inch further out on the Evosport than stock. Resolution: Put the stock pulleys (which I kept!) back on. Further problem: Power steering pulley won't come off, and two bolts broke off in my water pump. In any event, with the stock crank pulley, there IS sufficient clearance for the Zionsville overflow tank, so that will NOT have to be relocated. Whew!
Second, the ESS crank pulley does NOT fit with the Zionsville SPAL fan in its normal location on the aluminum shroud. It DOES fit if you simply rotate the position of the fan on the shroud up and over about an inch. This allows you to use one of the existing threaded locations on the shroud for the fan bolts; just need to install three others. So this is a relatively easy fix as well. Whew!
Third, when I installed the new fuel injectors, the fuel rails are lifted up from their stock location and, thus, their bolt holes do not line up with the screw mounts. Now, the ESS people recognize this as a possibility and include spacers and bolts to make up the difference. PROBLEM: The spacers (basically thick washers) do NOT FIT. The washers are too big. Moreover, even if they were the right size, the fuel rails are now at an angle to the screw mounts, so they are not going to fit no matter what. I am emailing Roman about this today, as this is an engineering failure that prevents the kit from achieving its "bolt on" goal. I'll post some pics tomorrow that show exactly what I'm talking about. Has anyone run into this problem? If so, how did you solve it? Raza? Edwin? Jerry?
Fourth, my radiator hoses are getting the heck squeezed out of them by the SCer bracket, not so much that they are closed, but they clearly have been narrowed by compression. The ESS manual says not to worry about this, but I am a little concerned. Essentially it is the return hose for the radiator, the hose for the overflow tank and the air conditioning line that all are squeezed pretty tightly together. It took a real he-man effort to get the lower bracket bolts and the tensioner bracket bolts in all the way.
Other than the foregoing, I have to say the bracketry and the overall engineering of the kit is quite good, right down to one of the spacers for the bracket having one edge ground down to clear the VANOS oil line on the passenger side. Nicely done. If I can just get the spacer situation for the fuel fails resolved, I'm pretty close to having the ESS part of the equation done!
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim with some great mods and a blown, balanced and blueprinted S62
herrubermensch is offline   Reply With Quote
Old 1st September 2009, 18:47   #2
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
Originally Posted by herrubermensch View Post
Edwin?
Install starting tomorrow.
Peter-
Thanks for your input. I'm assuming my Rogue crank pulley will not be compatible either. That's interesting about the fuel injectors.
Raza- any issues with your injectors?
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 92mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, RK Autowerks/Evolve tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete, Dinan 17mm rear sway bar,
TCD sway bar brackets, Ultimate Pedals, Euro Armrest, Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,
Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
04 M3 Jet Black/Black Nappa/6 spd
Evolve Alpha-N tune, SGT Headers, Rogue SSK, Dinan Muffler
ECB is online now   Reply With Quote
Old 1st September 2009, 18:52   #3
herrubermensch
Sales Feedback: (4)
Peter-
Don't know for sure about the Rogue crank pulley, but the ESS crank pulley clearly has been designed to work with the stock pulley, and each aftermarket pulley maker has a slightly different edge on the face of their crank pulleys.
Old 1st September 2009, 19:04   #4
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
go to home depot or something like that and get spacers that do fit, i ran into the same thing and even though it looks a little mis aligned, everything still works fine. im ghetto and used the rubber rings from my oem fuel injectors as spacers....
i thought the same thing at first, but if you have the hoses right behind where they should be, it works just fine and flow is just fine.
--Peter
-R
razahyde is offline   Reply With Quote
The Following User Says Thank You to razahyde For This Useful Post:
herrubermensch (1st September 2009)
Old 1st September 2009, 19:10   #5
Mfreakin5
Mfreakin5's Avatar
Garage: 2003 M5 Le Mans Blue
am I the only one who thinks you shouldn't have to ghetto rig anything on a kit that costs $10k? I'd be interested to see what ESS has to say about this...
Originally Posted by Greco View Post
...There seems to be less logic and more hot air in this white paper, maybe to sell more of his products...
White paper.... more like toilet paper.
Mfreakin5 is offline   Reply With Quote
Old 1st September 2009, 19:19   #6
Roman@ESS
Company Representative for ESS Tuning
Garage: ESS Supercharged E92 M3
The kit was designed to work on a stock car. We do not guarantee any compatability with other aftermarket parts. The fuel rail spacers we supplied can be modified to work or the rail can be spaced easily with shims. Our test car has different injectors then the 2002+ US cars. This was something we found out right before we starting shipping. The spacers we made seem to be a little off. We will have a fix for this ASAP and it will be included in kits very soon. we will also send the revised spacers to any customer that has recieved a kit and wants them.
Email: Roman@esstuning.com
Web: ESStuning.com
facebook: ESS-facebook
Roman@ESS is offline   Reply With Quote
The Following 3 Users Say Thank You to Roman@ESS For This Useful Post:
ard (1st September 2009), havasusteve03Beast (4th September 2009), herrubermensch (1st September 2009)
Old 1st September 2009, 23:46   #7
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Thanks Peter. Very helpful info.
I am planning to start the install Friday, and I have most of the long weekend to compete it.
I note the EVosport pulley issue, I have the same. I think I saved the original, I will have to hunt it down. Any reason the Evo pulley can't be machined slightly so the SC pulley sits flush? Since I do not have Zionsville, is the slight difference any concern, or is it an issue regarding belt alignment? Raza? Roman? AJ?
Will do a Home Depot run if necessary for spacers if necessary, although I like Raza's solution.
Will try to take some pics also.
Old 1st September 2009, 23:51   #8
razahyde
razahyde's Avatar
i wouldnt call it ghetto rigging, it is essentially the same thing as getting rubber spacers. everything else pertaining to the kit was spot on, if you saw how precise everything was you would know how much work went into it.
Old 2nd September 2009, 00:07   #9
herrubermensch
Sales Feedback: (4)
Hey Jerry. I thought about trying to work with the Evosport pulley, but I'm not sure that even machining the lip is going to work, as the ESS pulley sits a good 1/2-1" from the bottom of the crank pulley when inserted. I would be worried about allignment even with machining. It just doesn't fit, and I didn't want to spend the time or money to figure out exactly why. I liked my original water pump pulley better anyway, so this just gave me an excuse to put all of the original pulleys back on. Would have been great except for the two bolts that broke off in the water pump and for the power steering pulley that seems irrevocably fused to the power steering pump! I've tried everything on that damn pulley to no avail. I may have to replace the power steering pump just to replace the pulley!
The real problem with my fuel rails is not just a spacing issue, it's an offset issue. The rails with the new injectors installed are not just higher than the bolt holes, they are offset by about half an inch. I want to see what ESS is going to do for me on this point with the new shims, though, like you, I like homemade solutions such as Raza's and may very well have to resort to that.
Old 2nd September 2009, 00:10   #10
razahyde
razahyde's Avatar
get some spacers from home depot and call it a day, it really doesnt need to be thought about more then that. ESS is going to send you the same thing, spacers. Or if you were fed up with your car as i was, 2 of th Orings from the oem injectors work just fine for each screw...
ESS Kit Arrived... Need Divorce Attorney Recommendations ECB E39 M5 and E52 Z8 Discussion 42 7th December 2009 15:50
my ESS kit is finally here!!! razahyde E39 M5 and E52 Z8 Discussion 469 10th September 2009 11:28
how many are installing their own ESS SC kit? razahyde E39 M5 and E52 Z8 Discussion 50 19th August 2009 21:35
ESS VT550/570 VS. CA RK550 Superchargers alquazi E39 M5 and E52 Z8 Discussion 12 14th April 2009 21:35
Does anybody know if the ESS supercharger kit comes with everything included? T0RQUE E39 M5 and E52 Z8 Discussion 6 26th March 2009 15:06
