Rear axle bearing replaced (driver's side) UGH! *PICS* - Page 5 - BMW M5 Forum and M6 Forums
Like Tree5Likes
Old 2nd July 2012, 03:46   #41
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (8)
This thread is painful to watch, esp considering the 100+F temp. Good luck sorting it!
bimmerule is offline   Reply With Quote
Old 2nd July 2012, 03:49   #42
Flyin-m5
Flyin-m5's Avatar
Garage: '02 E39 M5 Sterling Grey-Sport Interior
Sales Feedback: (3)
Remove axel from diff before getting it to move because it was tight to get it away from the diff.
Note: Axel was rotated forward to get out of the diff.
If you have moved it at all it might require the nut going back on to reseat it to the bearing for enough clearance at the diff.
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Loose nut behind the wheel
Lidatek LE-30 Laser Diffuser
Evolve Alpha-N Tune with IAT Relocation and CSD.
Michelin Pilot Sport A/S on Beyern Rapp 18x9.5 et25 Black w/polished
H&R 10mm Spacers
Tinted windows/Sunroof
Alcantara Wrapped Steering Wheel
Dice Mediabridge
OEM E60 Short Shifter.
OEM BMW Rubber Trunk Liner
OEM BMW Sun Screen
Slimmbones Finned Rear Diffuser.
Slimmbones Front Lip.
SlimmBones XL Foglight Covers
Slimmbones Alcantara Shifter Boot
Slimmbones P-Brake Alcantara Boot
.....TBI Soon.......
Slimmbones BigMouth Grille Openings
Dinan Sway Bars
Dinan Springs
New Koni Sport shocks
Monoball control arm bushings.
Flyin-m5 is offline   Reply With Quote
The Following 2 Users Say Thank You to Flyin-m5 For This Useful Post:
datnewnewm5 (2nd July 2012), jamiepeers (2nd July 2012)
Old 2nd July 2012, 04:02   #43
Georgia M5
Georgia M5's Avatar
Garage: 2003 Jet Black M5, 1997 Black 540 Sport, 1997 Black M3 4 door
Originally Posted by Flyin-m5 View Post
I didn't think my axel was going to move either then it moved about 1/2mm........20 solid hits later it was out.
If you remove the axel,the carrier will then hold the bearing and flange so that you can remove the flange from the bearing and then unbolt the bearing.
If you take off the bearing/flange you then have to find a way to hold it to remove the bearing(I thought it was easier to let the car hold it for me).
Then when you reassemble the carrier will hold the bearing so that you can press the flange back into the new bearing(I used a harbor freight front wheel bearing remover to do this).
Another trick that I would add that I found in another DIY:
You need something to hold the hub while removing the inner and outer chases while turning the jaw puller. The easiet thing to do is take your wheel and lay it flat on the ground. Reinsert two lug bolts into it and thread into the hub to keep the hub from turning while you turn the jaw puller.
I can't remember, but I don't think you need to mount it in the rotor like the pic.
Peter
Georgia M5 is offline   Reply With Quote
Old 2nd July 2012, 04:02   #44
datnewnewm5
datnewnewm5's Avatar
Garage: 2000 TiSi
oh btw what is the tightening torque of the 6 axle bolts is it 64nm or 100nm?
datnewnewm5 is offline   Reply With Quote
Old 2nd July 2012, 04:04   #45
datnewnewm5
Garage: 2000 TiSi
You need something to hold the hub while removing the inner and outer chases while turning the jaw pullers. The easiet thing to do is take your wheel and lay it flat on the ground. Reinsert two lug bolts into it and thread into the hub to keep the hub from turning while you turn the jaw puller.
Thanks but I have a new hub and wheel bearing so once I remove the old rusted hub and wheel bearing im throwing them away
Old 2nd July 2012, 04:08   #46
datnewnewm5
Garage: 2000 TiSi
my only problem right now is removing the axle from the hub. Its the original axle thats been in the car for 12 years. no wonder why its being such a PITA. Once I remove it the rest should be cake.
Old 2nd July 2012, 04:14   #47
Georgia M5
Georgia M5's Avatar
Why would you spend $100 x 2 on new hubs? It's not necessary.
If you already have the jaw pullers and bearing separators you have everything necessary to remove the inner and outer chases from the hub. There is nothing wrong with the hubs, only the bearings are bad.
You might think about taking the extra step to remove the chases from the original hub. It's only an extra ten minutes per hub. If you kept your receipts you can return the new hubs and get your money back.
Old 2nd July 2012, 04:16   #48
datnewnewm5
Garage: 2000 TiSi
I only bought one new hub. My brother stripped one of the lug holes on the hub so I have to replace it.
Old 2nd July 2012, 04:18   #49
datnewnewm5
Garage: 2000 TiSi
thats the last time I let him near my car with an impact gun haha
Old 2nd July 2012, 04:18   #50
Georgia M5
Georgia M5's Avatar
Whether you use the old or new hubs, apply plenty of anti-size to the axel splines when you remount it.
If you still haven't got the hub off the axel yet, Advance and the other auto stores carry the PB Blaster and are still open depending on your time zone.
The Following User Says Thank You to Georgia M5 For This Useful Post:
WTB: 1 OEM rear caliper (E39 M5, driver's side) vics Parts / Other For Sale or Wanted 0 20th October 2008 20:51
WTB: 1 OEM rear caliper (driver's side) vics Parts / Other For Sale or Wanted 0 16th September 2008 19:00
Rattle from driver's side rear? bng4god E39 M5 and E52 Z8 Discussion 2 15th August 2007 00:47
Troubleshooting rattling rear driver's side door? nixter E34 M5 Discussion 12 19th January 2007 02:11
Driver's Side Rear Tire Being Cut By Fenderwell... Ben Carufel E39 M5 and E52 Z8 Discussion 6 31st May 2006 01:18
