removing vanos solenoids - BMW M5 Forum and M6 Forums
Old 1st September 2009, 11:24   #1
himiler
Garage: M5 Avus Blue
Hi,
Triad to remove the solenoids to replace hte o-rings. Got the covers off, but can not make the solenoids budge - grabbing the ends with pliers and pulling/wiggling - nothing - some slightly rotate a few degrees, others seem stuck in place. How hard is it? Dop not want to break things. Any suggestions?
himiler is online now   Reply With Quote
Old 1st September 2009, 11:47   #2
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Originally Posted by himiler View Post
Hi,
Repeat the above, but adding 15%/20% more pulling power !
They will come out, and I had the same thought process as you above
Good Luck !
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Any tips on removing stubborn vanos solenoid captiva E39 M5 and E52 Z8 Discussion 11 21st August 2009 14:44
Retrofitting New Style Vanos Solenoids M5 London E39 M5 and E52 Z8 Discussion 5 8th July 2009 23:56
Vanos Solenoids and those Diodes???? hipresr E39 M5 and E52 Z8 Discussion 1 25th March 2009 12:25
Removing VANOS?! derheilige82 E39 M5 and E52 Z8 Discussion 5 3rd August 2007 18:35
Problems w/Vanos system (After Vanos lise replaced) patq E60 M5 and E61 M5 Touring Discussion 10 23rd March 2006 08:42
